My recent experience with spark plugs - JeepForum.com
post #1 of 7 Old 09-17-2017, 11:26 PM Thread Starter
dflewelling
Hey all heres the scoop.
I recently decided to change the plugs on my 5.9 ZJ. Advance gave me some Champion RC12LC4's. Upon changing these, i tore 2 secondary ignition wire boots, so I got those brand new. All the sudden after a few days, it started running terribly at around 2k rpm under moderate throttle and load. Felt like a miss or severe ping, so initially i thought i was losing fuel signal or maybe spark signal (i had previous issues with my crank sensor, so i replaced that too). So after testing everything else to be good, i determined that she was being picky with plugs. So luckily i saved my old plugs for reference, which were NGK ZFR6F11's. Bought a set of those, threw em in and shes back to her old self, no missing, cutting out, backfire. I was amazed because i believe the Champions were only 1 heat range hotter over the NGK. So i know what im sticking to.
So everyone, my question for you is...
What spark plugs have worked best for you in your magnum motors?
Sent from my SM-G935V using Tapatalk
dflewelling is offline
post #2 of 7 Old 09-18-2017, 04:45 AM
Uniblurb
Uniblurb's Avatar
Interesting. We just had a discussion about a month ago about the not-so-good quality control on Champion plugs lately. This isn't in regards to the magnum engines but Champion plugs in general.
Below is a photo Josh posted on his 4.0 Champion plugs and how the side electrode bends are 'all over the board' affecting the gap on some.
http://www.jeepforum.com/forum/f13/s...l#post38768345
Sure they'll probably work but guess the quality and tolerances of the NGK plugs are a lot better.
I have 8 brand new Champion plugs down my basement for my 04 4.7 WJ and I'm kinda noticing the same thing on looking at them closely. Guess it's not surprising since I've been seeing the Federal-Mogul owned parts companies (Champion, Moog, Wagner brakes, etc.) parts quality going down hill through the years.
That's a little different part number (ZFR6F11) you have for your NGK plugs and thought the 98 5.9 uses the NGK 7252 (FR5-1)? At least that's what Rockauto and the NGKplugs site is showing for the copper core NGK plugs.
Regardless, thanks for the info and glad to see the NGK plugs are making your 5.9 run a lot better.
PS. I just ordered 8 NGK copper plugs from Rockauto for my 4.7 WJ. I'll probably say phooey on those new Champion plugs I have since I'm trying to get rid of a miss. Not saying all those Champion plugs are bad but time for a change...
96 4.0 ZJ Laredo, 2004 4.7L WJ Limited, 96 4.0 XJ (son's)
Uniblurb is online now
post #3 of 7 Old 09-18-2017, 06:10 AM Thread Starter
dflewelling
Yeah i think the zfr6f11 is just one heat range colder than stock. Runs great, i definitely plan on running them in the future. All my champions looked pretty ordinary, nothing remarkable in particular, but the NGK even look better constructed out of the box. Now for NTK O2 sensors!
post #4 of 7 Old 09-19-2017, 03:01 AM
Timo_90xj
Timo_90xj's Avatar
I'm currently running NGK BKR6E on my niner, gapped to .035"
Edelbrock aluminum heads and mild cam. Jeep works a lot better with those plugs compared to the OEM- spec. Champion plugs. As for Champion quality: I had tightened all eight plugs with a torque wrench, according to Edelbrock specs. using copper paste/ anti-seize. They had been in my Jeep for just one year, and around 7k miles. Three of the plugs cracked to pieces when pulling them.
I know I'll be sticking with NGK plugs, no more Champion plugs for me..
***Under construction***
Timo_90xj is offline
post #5 of 7 Old 09-20-2017, 11:26 PM
rep-tile
Cash 4 Clunkers Survivor
rep-tile's Avatar
Interesting because they switched over to NGK at some point on the WJ for the replacement OEM plugs. You can technically use either on the Jeep as long as they are copper core. The NGK are by far superior in quality.
04 WJ 4.0 - Avital 4103, DB-ALL
91 XJ 4.0 - Avital 4103, Stage-2 aFe intake system, BBK high flow Throttle Body, Jones Exhaust A3518M-5
rep-tile is online now
post #6 of 7 Old 09-22-2017, 05:39 AM
jeepjeepster
This is certainly news to me. I've always read that champion plugs were the best to use in the 4.0/5.2/5.9.
Wasn't there a 400 page thread on the WK forum about the jeeps randomly shutting off? Seems some people were thinking the plugs were a possible cause... Not sure what the outcome was if there was one...
1994 ZJ-I6 w/216,000 mi
1998 ZJ 5.9 w/65,155 mi Slate Black
2004 KJ w/90,300 mi
jeepjeepster is offline
post #7 of 7 Old 09-22-2017, 11:08 AM
PolkaPower
As long as they are copper it's fine. My Acura factory plugs were NGK too. They are just made better.
PolkaPower is offline
