My project - Page 4 - JeepForum.com
post #46 of 295 Old 06-04-2006, 08:20 PM Thread Starter
anticrombie
anticrombie's Avatar
Originally Posted by ArloGuthroJeep
Heat...heat it out!
I'm afraid to do that because it's so close to the engine block.
Charlie
anticrombie is offline
post #47 of 295 Old 06-04-2006, 08:21 PM
Virmagicus
Virmagicus's Avatar
Spray some PB blaster real good and repeat . Will work
Jeff
Virmagicus is offline
post #48 of 295 Old 06-04-2006, 08:25 PM
Skyline
Skyline's Avatar
Originally Posted by anticrombie
Oh ok...Well anyways, I can not get that steering stabalizer out to save my life. I've taken off the bolt, and hit it with a flipping 8 pound sledge, and it still won't come out. Any ideas? I've also tried using a pickle fork and hammer and that even won't work.
This is the tool you want:
If you ever see one of these things for sale, BUY IT!
This trick little press will pop your steering stabilizer out without breaking a sweat. Just turn the nut with an 19mm wrench. For the stabilzer I do need to flip the bottom half over to get good contact. It was designed to pull tie rod ends off, and cost me $87 15 years ago. At the time, I though that was a lot, but it has proven to be indespensible. The great thing about it is, that unlike a pickle fork, it will not harm the tie rod end or rubber boot at all. It will also easily seperate a drag link from a pitman arm or a tie rod from a drag link.
The bad news is that I've never seen one for sale since, (perhaps another member knows a source!) The BMW high performance specialty shop I bought it from is long since gone. It's a German made tool, made by a company called Stahlwille, and it's marked part no. 12616.
Should all else fail, or you can't find one of these, I recommend that you torch the drag link to red hot at the spot the stabilizer is attached before wailing on it with the BFH. A good whack on the side can also help.
'96 Green ZJ Laredo V8; 4.5" SA lift, RE 4.5 Springs JKS CA's, MX-6 Shocks, OME SS, Kevins TB Conversion, JKS rear TB, JKS Discos, Kevins Sliders, 16x8 Pro Comp Wheels, Dunlop Mud Rovers (33's)
Skyline is offline
post #49 of 295 Old 06-04-2006, 08:29 PM
ArloGuthroJeep
Mr. Hyde!
ArloGuthroJeep's Avatar
I heated this up which is right next to my power steering pump/hoses. Just keep the flame aimed and it'll be fine:
Burning afterwords:
'14 WK2 Limited w/5.7L, ORAI, & Tow Package
ArloGuthroJeep is offline
post #50 of 295 Old 06-05-2006, 12:49 PM Thread Starter
anticrombie
YESS! I got it off! Now I have to find a stinkin 9/16 bit with a 3/8 shank...Ugh!
Charlie
post #51 of 295 Old 06-05-2006, 01:18 PM
ArloGuthroJeep
Mr. Hyde!
When you start getting into that big of bits then get pricey fast
post #52 of 295 Old 06-05-2006, 01:19 PM
ArloGuthroJeep
Mr. Hyde!
I think a 5/8th bit was around $30
post #53 of 295 Old 06-05-2006, 01:30 PM
Varkyl
No where near stock
Varkyl's Avatar
It all depends on where you get it at. I got a 3/4" at Lowe's for about $17.
Nathan
One slightly modified '96 ZJ
new sig coming soon
Varkyl is offline
post #54 of 295 Old 06-05-2006, 01:31 PM
ArloGuthroJeep
Mr. Hyde!
And the quality of the bit...
I got mine at a local hardware store that has EVERYTHING, but is priced accordingly
post #55 of 295 Old 06-05-2006, 09:19 PM Thread Starter
anticrombie
Well I never did find one. I did a combination of reaming out the whole with a 1/2 inch bit and a dremel tool. Finally got it in there.
The front is complete except for some trimming and bending of the pinch seam so I can turn. Although I do have one issue...When turning, where my tierod and drag link connect hits my QD on the passenger side. Is mine just bent or something?
Charlie
post #56 of 295 Old 06-06-2006, 08:08 PM Thread Starter
anticrombie
ARG!!!! Got it all bolted up and tight, and took it for a test drive. I noticed a lot of rear end sway in it, so I got home and checked out the rear. Had my brother push on the side of the jeep to rock it back and forth, and noticed all the play was coming from the axle side of the track bar. I then realized that I was stupid and forgot to put the metal sleeve back in the bushing after I pushed it out by accident. ARG! and since I had to cut the orignal track bar bolt and nut off with a cut off wheel, I have to use a socket on the back side of the nut to tighten it up. Thus meaning I have to take off the UCA on that side to get to the bolt.....I'M SO FRUSTRATED WITH MYSELF! And now I can't get anyone to help me work on it till after 6 tomorrow, meaning I can't get it alligned till thursday...meaning I can't drive till thursday afternoon. All because I was STUPID!!
Charlie
post #57 of 295 Old 06-06-2006, 10:24 PM
SuRf 092
Have patience dude. You'll be mall crawlin in 2-HI in no time.
2004 WJ 470 H.O.
http://www.mallcrawlin.com/forum/showthread.php?p=84888
SuRf 092 is offline
post #58 of 295 Old 06-06-2006, 11:05 PM
EMTimZJ
GSMW!
EMTimZJ's Avatar
1994 ZJ
Char, its alright crap happens! Good to see you wrenching, learning, lifting, and now I want to see you wheel. I better see you at GSE or GSSE
-Tim
KD8EBC
'94 ZJ 5.2 LTD
JCR Rock Sliders
EMTimZJ is offline
post #59 of 295 Old 06-07-2006, 09:47 AM Thread Starter
anticrombie
Are you going to GSSE at Tellico?
Charlie
post #60 of 295 Old 06-08-2006, 07:18 PM Thread Starter
anticrombie
Now I have to replace the tie rod because it's seized....
Charlie
zj project mudder_317 ZJ Grand Cherokee Forum 30 03-25-2008 06:23 PM
New project nashmd454 ZJ Grand Cherokee Forum 13 01-12-2008 12:42 PM
Looking at a project '98 ZJ rayar3 ZJ Grand Cherokee Forum 2 11-30-2007 09:14 PM
next project? Derek33 ZJ Grand Cherokee Forum 4 10-24-2007 03:21 PM
just trying to sum up my project Derek33 ZJ Grand Cherokee Forum 1 05-16-2007 08:39 AM
