My Jeep is squealing. - JeepForum.com
post #1 of 20 Old 10-25-2005, 02:04 AM Thread Starter
Eds97ZJ
Hey guys,
I had no symptoms before this but I drove my Jeep 5 miles today parked it. It sat for about 2 hrs. I then started it up to drive home and heard squealing from under the hood. It did this at idle and driving all the way home. I think it was a little intermittent. I got close to home and started to lose power steering. I put it in the garage shut it off and checked the ps fluid it was at the cold mark. After driving 5 miles it shouldn't be at hot mark, right? Serp belt looked fine to.
So what do you guys think? Is it ps pump or do I just need to tighten the serp belt? BTW: I didn't see any puddles on the floor.
1997 Jeep Grand Cherokee LMTD Loaded 5.2 V8 Q-Trac 4X4
Eds97ZJ is offline
post #2 of 20 Old 10-25-2005, 03:38 AM
Texas ZJ1
Jeep Jedi Master
Texas ZJ1's Avatar
1994 ZJ
Check the serpentine belt tension pulley. IT is plastic and will start to squeal just before it eats itself and starts to melt.
Hunter
04 4.7 HO, limited
08 Z71 Suburban, front leveling kit with rear spacers. 285/65 18s Nitto TerraGrappler G2s
94 5.9 Laredo 6.5 RE lift with 35 Maxxis Bighorns
and 33 Bridgestone Duelers
Detroit and true trac
Red Jeep Club Member
REDNECK JCM
Texas Jeep Owner #6
USN Jeep Club #4
602.841.3355
For your performance needs:
480.998.366
Texas ZJ1 is offline
post #3 of 20 Old 10-25-2005, 08:59 AM
KingZeke
KingZeke's Avatar
I had this problem just two weeks ago. On the pully and pwr steering pump assembly I notice a broken bracket. It was an easy fix, I bought the part from the dealer, $35 or so. Easiest thing to do it take off your belt, check it and check all of your pullies when the belt is off. That is how I found my problem. I noticed I had pwr steering fluid all over but it seems that it was only because the pwr steering resevoir was shaking around so bad. Now that the bracket was replaced of course the belt was tighter, squeaking went away and pwr was restored.
1997 Jeep Grand Cherokee Laredo
2 Inch Budget Boost from Rubicon Express
31 Inch Tires, Shaved front facia
IMCO Exhaust
Almighty 2" BB Club Member # 38
KingZeke is offline
post #4 of 20 Old 10-25-2005, 01:54 PM Thread Starter
Eds97ZJ
Ok, I'll check the pulleys. Maybe it did have symptoms if you think it's the idler pulley. I've been having problems with volt gage not staying up above 12 and when it's cold out it just drops to 0 after driving a mile. Although I never lost elec power and lights never even dimmed. Do you think it might be related? Thanks
Eds97ZJ is offline
post #5 of 20 Old 10-25-2005, 04:06 PM
KingZeke
KingZeke's Avatar
Your volt gauge may have problems because your belt isn't properly turning your alternator. Just a thought. Mine was doing the same thing until I fixed that bracket.
IMCO Exhaust
KingZeke is offline
post #6 of 20 Old 10-26-2005, 12:05 AM Thread Starter
Eds97ZJ
Yep, that's what I thought to. I checked it out like you guys said. Removing belt and checking the pulleys. They all seem to be good except the tensioner pulley and the tension arm itself. It sounds like the bearings are going in the pulley (like you guys said). I was spinning it and it was making noise but was not loose at all.
The arm does not move freely either. I sprayed them both with PB and then with white grease also hit it with the airgun. The arm works a little better part way but as you get it to the left where it tightens the belt it has a dead spot where it won't go all the way tight and you have to move it over the rest of the way about a 1/4".
I got the belt tight and then took a test drive. I was pleased to see my gage staying at 14 with h-lights and fogs on. It also didn't drop to 9 and alert check gages. Like it would have before at the lower temps we are having here right now 40 deg F.
So I guess I want to replace both pulley and arm. How do I do this and what will the parts cost? Thanks
Eds97ZJ is offline
post #7 of 20 Old 10-26-2005, 12:07 AM
Woody
Retired back to Bowties
Woody's Avatar
1985
If it's working at the moment you are good. I would buy those parts, or just be ready to buy those parts if it acts up again.
Woody
1985 1 ton K-5, Detroit diesel, 36" tires (going bigger when money permits), 4-speed manual swap, Rockwell T-case, Hybrid lift, 12.5K winch.
Woody is offline
post #8 of 20 Old 10-26-2005, 04:38 AM
Texas ZJ1
Jeep Jedi Master
Texas ZJ1's Avatar
1994 ZJ
The new parts are around 65 bucks.
Hunter
04 4.7 HO, limited
REDNECK JCM
Texas Jeep Owner #6
USN Jeep Club #4
602.841.3355
480.998.366
post #9 of 20 Old 10-26-2005, 07:08 AM
greasefingers
greasefingers's Avatar
1994 ZJ
Do yourself a favor and crawl under the front of the jeep. Inspect the bottom of the power steering pump for signs of leaking.
Cheers Steve
94 Black Laredo 4-Liter with QuadraTrac (42RE trans & NP249 TC) 200,000 + miles purchased new
88 Cherokee 2-door with 5speed manual 139K miles(deceased) purchased new
greasefingers is offline
post #10 of 20 Old 10-26-2005, 12:46 PM Thread Starter
Eds97ZJ
Ok, I'll check under the P/S pump. Thanks
I can get a tension arm assm from Adv-Auto for $63 or a orig Jeep part for $111.00 ..ouch!! How do Dayco's compare to orig? Anybody got a Dayco? Just want to make sure if I go with cheaper I get good tension on the serp belt.
It looks like 3 bolts to replace T arm. Is that all there is to it? Or is there a certain way it goes in to get tension on it?
Eds97ZJ is offline
post #11 of 20 Old 10-26-2005, 12:52 PM
Woody
Woody's Avatar
1985
Try Rockauto.com. I've had great luck with their stuff.
Woody
Woody is offline
post #12 of 20 Old 10-26-2005, 12:53 PM
greasefingers
1994 ZJ
A Gates belt will run ya $ 27
An ACdelco tensioner assembly cost $ 56
IMO any aftermarket parts for this will be fine.
Cheers Steve
post #13 of 20 Old 10-26-2005, 12:54 PM
greasefingers
1994 ZJ
damm Woody beat me again, due to the 60 second rule
Cheers Steve
post #14 of 20 Old 10-26-2005, 12:59 PM
Woody
Woody's Avatar
1985
60 SEC!
Woody
Woody is offline
post #15 of 20 Old 10-26-2005, 02:00 PM Thread Starter
Eds97ZJ
That's good to hear about aftermarket for this part. I really didn't want to spend $111.00.. Yea, I looked at R-auto by the time they add the $6 ship I might as well get it at Adv Auto and not wait for it.
Any answers for this one?
Thanks
Eds97ZJ is offline
2006 Jeep REC Navigation Voice instructions come out as a loud squealing noise jake06cherokee WK Grand Cherokee & XK Commander Forum 18 07-25-2010 12:34 PM
Squealing! Haleyrz ZJ Grand Cherokee Forum 21 12-31-2008 06:07 PM
Squealing on start VoteWithABullet ZJ Grand Cherokee Forum 12 11-19-2008 10:21 PM
AC squealing like mad motu1983 ZJ Grand Cherokee Forum 6 09-21-2007 01:02 PM
squealing transmission rallyspitman ZJ Grand Cherokee Forum 2 02-24-2007 02:55 PM
