my jeep is idling low and shakes - JeepForum.com
post #1 of 12 Old 03-13-2010, 04:18 PM Thread Starter
theredjeeper
When im sitting in park, reverse, or drive sitting still my zj idles low and shakes alot, i have to hold the gas and brake at stop lights to stop shaking. Ive been told it might be the motor mounts( they were good) and also the Throttle body sensor. any ideas?
theredjeeper is offline
post #2 of 12 Old 03-13-2010, 04:25 PM
ZeeJay1997
I would clean throttle body and Idle air control. Do some searches on the forum, common 1st attempt to troubleshoot the problem and it's almost free.
ZeeJay1997 is offline
post #3 of 12 Old 03-13-2010, 04:28 PM Thread Starter
theredjeeper
ive cleaned my throttle body a few times and havent changed anything, ill try the IAC and see what happens. do u think it could be the throttle body sensor?
post #4 of 12 Old 03-13-2010, 04:37 PM
ZeeJay1997
I believe you mean the throttle position sensor. Yes, it could be, but i would clean the IAC good first.
You can electrically test the TPS:
The TPS (Fig. 59) can be tested with a digital voltmeter.
The center electrical terminal of the TPS is
the output terminal.
With the ignition key in the ON position, check the
TPS output voltage at the center terminal wire of the
connector. Check this at idle (throttle plate closed)
and at wide open throttle (WOT). At idle, TPS output
voltage should be greater than .350 millivolts but
less than 900 millivolts. At wide open throttle, TPS
output voltage must be less than 4.5 volts. The output
voltage should increase gradually as the throttle
plate is slowly opened from idle to WOT.
post #5 of 12 Old 03-13-2010, 04:42 PM Thread Starter
theredjeeper
alright ill try that tomorrow. my uncle is a mechanic. you said something figure 59, where is that diagram or where should i look?
post #6 of 12 Old 03-13-2010, 04:53 PM
ZeeJay1997
I copied and pasted from the FSM, forgot to take the figure reference out. It's just a pic of the TPS.
post #7 of 12 Old 03-13-2010, 04:58 PM Thread Starter
theredjeeper
ok thanks for the help, im going to check that stuff tomorrow and i hope it works
post #8 of 12 Old 03-15-2010, 07:36 PM
purplecty
2003 WJ
any luck??? because i have the same problem...
purplecty is offline
post #9 of 12 Old 03-15-2010, 07:47 PM
ZJ97EB
Mine was doing that last year and they replaced the distributer cap and it was all fixed
'97 ZJ 5.5" long arms 31's
'99 TJ 4 banger stock (my fuel efficient vehicle)
ZJ97EB is offline
post #10 of 12 Old 03-17-2010, 06:28 PM
purplecty
2003 WJ
did they only replace cap or rotor as well???
post #11 of 12 Old 03-18-2010, 01:08 AM
befumo
Should just do a complete tune up in general.
'89 YJ Wrangler - Sold
'95 ZJ Orvis Edition
'89 YJ Islander
befumo is offline
post #12 of 12 Old 03-18-2010, 04:15 AM
purplecty
2003 WJ
PO did about 1-2 yrs ago but maybe used cheap parts... i only replaced spark plugs cuz i noticed autolites and i replaced wit champion. i also did 02 sensors... maybe i should just get new wires cap and rotor and coil as well huh? what about the distributor pick up? how do u know if that is going bad? any symptoms im having as a result of it going bad?
rpms drop in reverse and jeep shakes? kevin_saun ZJ Grand Cherokee Forum 4 01-25-2017 08:14 PM
my jeep shakes when i hit bumps on the road sometimes really bad! jeepercreeper69 ZJ Grand Cherokee Forum 16 02-03-2010 07:57 PM
Jeep Shakes When Hit Bump!! HELP! borndahoop ZJ Grand Cherokee Forum 10 08-10-2009 05:51 PM
4.0 engine shakes the whole jeep! at idle PJNovinskee27 ZJ Grand Cherokee Forum 6 07-06-2008 09:43 AM
jeep shakes in when stopped finninjeep ZJ Grand Cherokee Forum 3 02-11-2007 08:42 PM
