My Jeep is a hole in my pocket. Please help! - Page 2 - JeepForum.com
post #16 of 50 Old 01-03-2014, 06:36 AM Thread Starter
Spify
Originally Posted by JS97ZJ View Post
Follow the steps in ZeeJay's write up in his sig.
If tapping or moving the plugs on the PCM cause it to stall your probably looking at a PCM.
If you can solder or know someone that can solder try this procedure
http://www.jeepforum.com/forum/f13/9...tures-1303589/
I've soldered up 4 PCMs to fix this stalling problem. Each was a success except for ZeeJay's.
Yesterday I ran the engine and tapped everywhere possible on the PCM as well as the PDC and the engine did not stall, I then pulled all plugs and used electronic cleaner on the 3 connectors into the PCM and cleaned the PDC out as well. My jeep still stalled about 10 minutes after driving down the road.
Spify is offline
post #17 of 50 Old 01-03-2014, 10:03 AM
JS97ZJ
If it is the PCM (solder joints) it could very well only act up while driving. Small vibrations can trigger it while rough handling does nothing. It's the nature of the beast.
Make sure you go though Z's list and pay attention to the connections and grounds.
Try wrapping the PCM with ty's like in Z's picture. If it makes any kind of difference it will be the PCM.
JS97ZJ is offline
post #18 of 50 Old 01-03-2014, 11:56 PM
mig1289
Have you replaced the cps or iac sensors?
2wd zj...
mig1289 is offline
post #19 of 50 Old 01-04-2014, 08:12 AM
johnniebravo
2008 WK
I experienced a similar problem years ago, my issue ended up being a wiring short.
Get a factory build sheet and figure out what options were on the build sheet and compare that to what is installed on the Jeep. If an option is not listed, a dealer or owner added it. Dealers don't always add options properly, which can end up being problem areas. Follow the wires for not listed options and see where they tie into the harness for power.
In my personal case, I had cruise control and it wasn't on my build sheet. The power pulled from wires that ultimately fed the crank sensor. Every time the short happened on cruise control wiring, engine lost timing and stalled. Happened a lot and nothing fixed it other than finding the short.
Hope this helps.
2008 CRD GC
johnniebravo is offline
post #20 of 50 Old 01-04-2014, 09:23 PM Thread Starter
Spify
Thanks for the info and tips, Guys I have this hunch it is the fuel pump; call me crazy but I think that is the problem. I will try the zip tie PCM method soon and see what happens there. My fuel pump causes a loud buzzing sound that can be heard from under the tank very well, when the engine stalls you can hear the sound and when the engine dies the buzzing of the fuel pump does not stop. I have noticed the Jeep struggles harder on cold days, This alone made me think it could of been a fuel issue but I wasn't sure.
I know that cold weather calls for a richer fuel mixture which made me believe that maybe the pump wasn't pushing out an optimal quantity of fuel to the engine. I know that evidence of a bad fuel pump could point to bucking and rough stalling. However I feel as if the Jeep kind of hiccups at Idle but when accelerating it would just cut off as if the ignition switch was switched to the off position, no electricity in the vehicle ceases even the heater continues operating which normally requires the engine to be running.
I have also noticed that the problem seems to be intensifying as time passes, Tonight the engine would stall at idle, it did this for about 15-20 minutes straight. I managed to Drive the thing to the gas station by gassing it, popping it in neutral coasting and when the engine dies crank it back up while in neutral and shift her back into drive. (she's an automatic, probably not the best idea but I've got this down to a science). Once I arrived at the Fuel station I put in about 6 gallons of low quality gas (probably should have put in super-unleaded now that I think about it) Put some fuel system cleaner in there and she made it the rest of the way home without a single stall *the strange thing is that, it has worked in the past without adding fuel or system cleaner) Any opinions?
By the way saw this on Ebay: http://www.ebay.com/itm/New-Electric...e68e1e&vxp=mtr It's cheap so if my fuel pump wasn't the verdict this wouldn't be a pocket burner.
So what is a good way to see if it is the fuel pump or not? thanks guys.
Spify is offline
post #21 of 50 Old 01-04-2014, 09:46 PM
ZeeJay1997
check the fuel pressure at the test port on the rail. you can use the tool loan at Advance Auto or if you're on Whiteman, do they have an auto hobby shop?
ZeeJay1997 is offline
post #22 of 50 Old 01-04-2014, 09:58 PM
thexbeast12
Any luck on your CV? If not I can tell you it's an easy fix. I'm still working on my jeep and I did 2 of mine this past summer( 1 was going bad figures I'd redo both). If a girl can do it so can you. Lol.
thexbeast12 is offline
post #23 of 50 Old 01-04-2014, 10:11 PM
xrunndonex
1994 ZJ
Originally Posted by Gearhead31 View Post
THIS!!
Rust will easily turn a 5 minute job into a 5 hour job
Torch
xrunndonex is offline
post #24 of 50 Old 01-05-2014, 08:08 AM
JS97ZJ
A buzzing pump is not a good sign. I'd get that pressure tested before any thing else.
If it turns out that the pump is shot, go with a Bosch fuel pump. They are the original brand to Jeep. The cheaper brands too often fail within 1 year.
You can replace just the pump but you also need to get the 2 internal filters that don't come with the pump. Most guys here go with buying the whole module but that cost $.
The filter that comes with it is not the correct one for the Jeep.
JS97ZJ is offline
post #25 of 50 Old 01-05-2014, 08:46 AM
motordoctor
I don't know if this has been mentioned but you might have water in your fuel system. The pump picks up from the bottom of the tank where the water would sit. When it's cold out (has to be freezing where you are) the water will freeze and no more fuel pressure. The fuel system cleaner probably has alcohol in it and helps with fuel line freezing. I had that problem once with a motorcycle. I was riding it and the water in the bottom of the tank froze which stopped the fuel flow, even though the tank was full. Got some fuel line additive (basically methanol), thawed the tank out and away I went
motordoctor is offline
post #26 of 50 Old 01-05-2014, 09:36 AM
ZeeJay1997
the water / ice idea is a good one. if Heet doesnt help, you still need to check pressure.
take a look here.
post #27 of 50 Old 01-05-2014, 06:37 PM
papitt
What are you thoughts on that KESHEN pump .. I've not heard of it before but every pump I tried has been junk.
papitt is offline
post #28 of 50 Old 01-18-2014, 03:16 PM Thread Starter
Spify
Hey, i gave in took it to a mechanic, he looked at it he suspects possibly faulty fuel pump or maybe a bad catalytic converter? any thoughts?
Spify is offline
post #29 of 50 Old 01-18-2014, 03:52 PM
scope513
I have/haf the stallung problems also...Its your pcm...what year is your zj? Also if it is a 97 like mine all you have to do is take out your coolant resivor and the pcm is the box mounted to the fire wall. Use zip ties but not the thick ones use the skinny ones. I connected three together so it fully wraps arond it. Do each plug. Before you do the plugs put some dielectric grease on them. Tighten as tight as possible with out snapping them. Install your resivor. Make sure you take off the negative battery cable first. During the time itll give the pcm a chance to restart. This should eliminate or make it not stall ad much.
"We could be or not be alone in the world, both are equally terrifying."
scope513 is offline
post #30 of 50 Old 01-18-2014, 04:59 PM Thread Starter
Spify
I will give this a shot, i want the problem to be gone already i cant stand being broke because of buying parts all the time
Spify is offline
help needed , jeep grand cherokee , stalling
