My front tow point/ winch subframe build *pics* - JeepForum.com
post #1 of 24 Old 01-22-2010, 01:47 PM Thread Starter
pulsepb
I figured I'd show off my latest creation. As you can see for now I have shackles mounted through it for front tow points. Later this year I am going to build a front winch bumper and this will be my base. The bumper will slide over the outside of the two vertical bars and be held in place with two 7/8" bolts per side with a 1/2 inch bolt in the center of that tube
as far as contruction the base plates are 1/4 inch, the vertical plates are 1/2 inch and the tube tying them together is .120 wall DOM. The hardware is grade 8 with 1/2" and 7/16' diagonally from each other.
original concept
changed to due to constructability issues
what i actually went with
material cost was about $20 and the grade 8 hardware was about $20
pulsepb is offline
post #2 of 24 Old 01-22-2010, 02:54 PM
CJ7-Tim
Real Jeeps have dents
CJ7-Tim's Avatar
Creative design. Nice machine work and welding.
Consider adding some gussets from the .120 wall DOM to the clevis plates.
CJ7-Tim is offline
post #3 of 24 Old 01-22-2010, 03:07 PM
WhiteOut
WhiteOut's Avatar
When you build the bumper and mount it you should really change the mounting. 3 bolts per side is no where near enough. The ARB had 4 through the frame rail, 2 through the front and 2 on the bottom per side, them 3 bots per side holding the bumper to the mounts. All 3/4" grade 8 hardware IIRC.
WhiteOut is offline
post #4 of 24 Old 01-22-2010, 06:18 PM Thread Starter
pulsepb
Thanks
funny you should mention that, my roommate and I discussed the merits of running the DOM bar at all.
do you have a picture? I dont quite follow the placement of the bolts as you described?
pulsepb is offline
post #5 of 24 Old 01-22-2010, 07:39 PM
kwsamms
That is a really cool design...may have to try something like that for my ZJ! Got any drawings? Haha
" All these people say they're Fabricators, they can do this or that - well, I can cook hamburgers, but i'm no Chef "
kwsamms is offline
post #6 of 24 Old 01-22-2010, 11:42 PM
ratmonkey
R.I.P.
ratmonkey's Avatar
You only mounted to the bottom of the rail? If so that's not nearly good enough for a winch bumper. You need to "box" the rail with your mounts.
The 7/8 bolt hole is too big for the plate you used. You'd be much better off using 4-5 1/2" bolts per side to mount the bumper to your frame plates. It'll spread the stress concentration over a wider area. You'll have more peaks, but they'll be smaller.
Its all about spreading force over the widest area possible.
ratmonkey is offline
post #7 of 24 Old 01-24-2010, 06:55 PM Thread Starter
pulsepb
If you refering to my 7/8 shackle pin holes. Id have to disagree. Ill calculate the bearing stress later but im confident it will come out to be more than sufficient.
as far as my mounting to the frame Im confident it is sufficent as well. The 1/2 bolts are torque to a spec of 106 lb-ft and the 7/16' bolts to 69 lb-ft. this creates a sufficient pre-load where the friction of the plate on the frame is so great that the bolts will never see any shear effects as long as it it under the calculated load.
granted i used a rudimentary equation, I made up for this with conservative numbers. As you can see the preload applied creates a very large friction force. Also notice that that is per side.
As i mentioned Ill calculate the bearing stress on my 7/8 holes later.
various resources I used to make my major assumpions
Coefficient of Friction Reference Table - Engineer's Handbook
Coefficients Of Friction
Standard Metric Bolt Shank Dimensions
kwsamms:
I dont have any drawing but i could take some pics to give you ideas. Ive never looked at the frame of a zj so im not sure what you could do. maybe check out kevins zj shackle mount
http://www.kevinsoffroad.com/zj/rad%...t/f9baed38.jpg
Radiator Support for ZJ Jeep Grand Cherokees by KevinsOffroad.com Hard-KOR Products
pulsepb is offline
post #8 of 24 Old 01-24-2010, 07:04 PM
tarfin
Nice work!
tarfin is offline
post #9 of 24 Old 01-24-2010, 08:15 PM
nick62087
Looks good. Id agree that the bar between is beneficial - Id think itd work to strengthen the whole setup by essentially acting as a crossmember. Plus, if your pulling from just one of those shackles, i think it'd help to distribute the load.
Do you have it bolted through the holes for the factory tow hooks? Or where exactly did you bolt it to the unibody? - its hard to picture without looking underneath.
I know everybody here is critical of the strength of recovery point mounting. You definitely make a good point with the friction, that the bolts would be squeezing so hard that it shouldn't matter. I believe that the thin sheetmetal of the unibody is the main concern, as opposed to the shear strength of the bolts. Either way, i still think it'd be damn near impossible to rip that thing off.
Post more pics if you do any more fab work.
nick62087 is offline
post #10 of 24 Old 01-24-2010, 10:37 PM
ratmonkey
R.I.P.
ratmonkey's Avatar
I doubt you'll rip the mount from the frame rail. I'd bet good money you'll deform the crap out of it with a good tug or two with the single mounting plane like that though.
Your jeep, good luck.
post #11 of 24 Old 01-25-2010, 10:50 AM
xjokee
The only way to find out is to lock the wheels on asphalt and tug away...preferable uphill. I bet that bad boy will hold without deformation......if the calcs are indeed correct +\- 10%.
Mike
~ When in doubt........Throttle out! ~
xjokee is offline
post #12 of 24 Old 01-25-2010, 07:11 PM Thread Starter
pulsepb
I think the cross-member is of great help.
its mounted through the factory holes although i drilled out the square holes to give me additional mounting points.
I plan on fabbing up some stuff in the near future. Ill definitely be posting it up.
I understand the concern of the lower sheet metal, but its all about proper loading. How much money you looking to bet? I used these on Saturday got a few tugs in the snow after i slid into a ditch.
I think that large point that is being missed here is the plate has 21 sq inches of contact with the frame. This distributes the load very well. I calcd out the stress on the 1/16" steel making up the bottom.
At the bottom is the shear stress exhibited on the steel in psi. Ill let you look up the yield strength of mild steel. If you dont reach the yield point there wont be any deformation. I calculated it with a force of 10,000 lbs on one side so i think its sufficient.
pulsepb is offline
post #13 of 24 Old 01-25-2010, 10:27 PM
ZJ5point2GCL
looks good, too bad its not on a ZeeJay so i could copy them
Nice Work
ZJ5point2GCL is offline
post #14 of 24 Old 01-26-2010, 12:47 AM Thread Starter
pulsepb
Originally Posted by tarfin View Post
Nice work!
Nice Work
thanks!
10 char
pulsepb is offline
post #15 of 24 Old 01-26-2010, 01:45 AM
ratmonkey
R.I.P.
ratmonkey's Avatar
10k pulling force is pretty conservative for a pull on a good stuck.
You want it to fail at a higher rating than your pulling strap. Calculate your forces at 30k and add in another 20% for safety.
my wj front winch bumper build wonderbrd937 WJ Grand Cherokee Forum 78 03-15-2012 06:42 PM
ZJ front winch bumper build RRAM ZJ Grand Cherokee Forum 25 03-05-2010 09:59 PM
Towing w '04 - rear subframe?? bigteninch ZJ Grand Cherokee Forum 4 05-18-2008 10:42 AM
Front bumper/winch mount pics needed. sand zj ZJ Grand Cherokee Forum 3 07-25-2007 08:27 PM
I got a front tow point now... nierace ZJ Grand Cherokee Forum 40 05-24-2007 05:26 AM
