My Front Recovery System(PICS) - Page 9 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > ZJ Grand Cherokee Forum > My Front Recovery System(PICS)
Poison Spyder DeFenders™ - "Tubeless" Jeep FendeBaseline 4x4 Lifetime Warranty 4340 Chromoly Axle Shaft KiJcrOffroad new Crusader TJ/YJ/CJ Bumpers available!!
Closed Thread
Unread 04-24-2012, 08:20 AM   #121
gabrod72
Glad it worked out well and you had some fun.
OFF TOPIC: On the first part of the video, it looks like you've got an open diff in the rear end. The last hill climb looked slippery and you made it up pretty easy though (and nice fast forwarding on the editing that looks pretty sweet.) You should consider getting a locker for the rear and some meatier tires... you'll be amazed at how much further your ZJ could go under it's own power. Check this one out... I really thought I could clear that rock to get a better line - good thing I didn't bust my radiator. That climb is way more challenging than it looks on video and my friend had some traction issues with his locked YJ on 33 BFG KM2s. He made it up though but my rig made it look too easy.
http://youtu.be/ykUfvyaxFbY
gabrod72 is offline
Unread 04-24-2012, 09:19 AM   #122
xbeakerx
Thanks. Gonzo did great all weekend. Nothing broke off like most people said it would. I was getting compliments all weekend on the front recovery design. The person that winched me both times, after looking at my setup said he would winch me out anytime. He was very impressed with the setup. The guide Sunday liked it. You can see him in the video hooking it to it while I was no the rock stuck. Here is your proof that it works and it works great.
Yeah this was my first trail run with the ZJ. It rained all weekend just about so everything was wet. The first part of the video doesn't really show it but that was a VERY steep trail. It was probably a 10-15 degree angle trail going up.
OT: I do want to get lockers and M/T but this is still a DD for me. Those things will come in time. My wife even wants to beef it up after this weekend.
1998 ZJ Laredo(Gonzo) - Built Not Bought - 3.5" lift with IRO Long Arms, Cherry Bomb Exhaust, 31x10.50R15, CAI, Custom Front Recovery System & YJ Tube Bumper
1986 Toyota MR2 - Polyurethane Suspension Bushings,Suspension Techniques Lowering Springs,S/C Swap and more!
xbeakerx is offline
Unread 04-24-2012, 10:14 AM   #123
PolkaPower
Every time I am out with the wrangler guys they have trouble on steeper obstacles. I was out with my buddy in his 4 door JK and he even had trouble/slipping climbing some stuff that my track locked 249 walked right up. I think longer wheel base and larger motor building torque quick helps out.
98 5.9 2"BB, Custom V-Tec mod, high performance muffler elves, alloy performance lug nuts, super high flow custom radiator cap, Ultralight unobtanium flywheel, stage 6 ultralight hydro tuned wiper blades(front), kevlar stickers
[QUOTE=JohnnyZJ;13325401]if its to tall for her to get into why don't you just install some running boards?[/QUOTE]
[QUOTE=HAMAR;13330720]I just gave her ironing board, she's not getting another board.[/QUOTE]
"What is best in life?
"To crush your enemies, see them driven before you, and to hear the lamentations of the women."
PolkaPower is offline
Unread 04-24-2012, 11:15 AM   #124
speedbucket
Agreed polka. I had the same scenario open/LSD idling up an incline the locked locked guys on 35s spun on. I think it has more to do with the near even f/r weight distribution of the zj.
On to the recovery. A downhill winch high centered on a boulder recovery could be achieved with an ATV. And YOUDONT have to be rocker deep in mud to achieve those crazy 20klb plus loads.two weeks ago we We had a yj on its door in a ditch/drainage that wouldn't budge with 2 different winches (one doubled). We ended up putting a hilift on it and tipping the Jack several times with both winches going and that's dead pull. No snatching.
Props for going out of the mold but recovery points isn't a good one to start with.
I was a doubter and I still am
it does hurt your approach whether it showed in that trip or not
that pic I put as an example on the what did you do to your zj thread - that rock put a dent in my sheet metal bumper and as I said yours would not work there.
Keep wheeling!(just don't kill anyone)
http://www.jeepforum.com/forum/f22/speedbuckets-zj-build-1361322/
V8 zj,4.5" ...coming- boat sides, rear stretch, tringulated 8.8, streched front HP30, bead locked 35s.....
speedbucket is offline
Unread 04-24-2012, 11:21 AM   #125
speedbucket
This is the pic I was talking about and the second pic is where the yj (not in pic) got sanwhiched in on his door
Unread 04-24-2012, 12:05 PM   #126
xbeakerx
There were a couple of times I was either in the same situation you were in the first pictures and I never had a problem. One being the rock I was on in the video and another was on a steep downhill, which is in the video as a picture. The front end never touched any ground in that whole trip.
Thanks for the props by the way. I know I'm not going to convert everyone but I believe I made something better than what I can buy for more than half the price and this past weekend I proved that.
xbeakerx is offline
Unread 04-24-2012, 01:05 PM   #127
gabrod72
Longer wheelbase I'd say 100%, but it also cripples us vs. the YJ in other situations. On the motor though, the YJ had a 4 cylinder so I think the weight difference (stock YJ at 2900 lbs) makes things relatively even being I have the 4.0 with 4.10s on 35s. Whenever he had some hopping issues, it was usually due to the steep climb angles. It's very difficult to balance and bounce a JY with a 4 banger and standard tranny over the obstacles he got over, and that alone is a testament to his driving skills.
gabrod72 is offline
Unread 04-27-2012, 05:54 AM   #128
xbeakerx
I guess the peanut gallery has finally shut up since I proved my design works on the trail.
Thank you to the ones that stood behind me on this endeavor.
xbeakerx is offline
Unread 04-27-2012, 06:28 AM   #129
speedbucket
i was rather nice above (i thought) but that thing should still not be trusted. on those 2 pulls they could have just hooked up to your foglights and would have held just fine.
you have proved its strong enough to pull a rolling load. but it is completely untested beyond that in my opinion
and look back at your "peanut gallery"......not exactly a bunch of newbs
Unread 04-27-2012, 07:08 AM   #130
Freestyle713
1994 ZJ
x2
[B]94 Grand Cherokee 5.2[/B] [SIZE="1"]33in. Federal Couragia M/T's on Procomp Steelies, np231 swap, IRO Hack n Tap SYE, Carolina Driveshaft, 4.5 in. lift, RE front upper/rear lower ca's, RC front lowers, Ironman rear uppers, IRO 4.5 coils in rear, 3.5 and 2" bb (no isolators) in front, Bilstein 5100's, Clayton/JKS adj. track bars, KOR rad support and SS, Magnaflow/Flowmaster exhaust, clear corners, custom light bar w/ Hella 500's[/SIZE]
[CENTER][COLOR="Yellow"][URL="http://www.jeepforum.com/forum/groups/zombie-outbreak-response-vehicles/"][COLOR="Yellow"]Zombie Outbreak Response Team[/COLOR][/URL][/COLOR][/CENTER]
[QUOTE=elcorvino;14544406]Yea... It's kind of like the fat chick who lives around the corner. You aren't trying to get caught with her, but you know she'd be a good time.[/QUOTE]
[QUOTE=ScottD16;14460352]I had a dream my entire family was attacked by a giant polar bear. The crazy part was he attacked us with a giant spoon. Best dream ever.[/QUOTE]
Freestyle713 is online now
Unread 04-27-2012, 07:12 AM   #131
badbird17x
badbird17x's Avatar
1994 ZJ
Keep dreaming. I was trying to help but since you did two pulls that I could have done with my Honda atv any day of the week, oh and you just won't go in the mud because you don't want to rip it off. Put simply you did a horse sheet job at engineering, then came on here trying to sell horse sheet to ranchers, since the ranchers didn't buy you touched a tiny bit against your tongue and are acting like it the best tasting stuff on the planet, and now calling us stupid for not buying your horse sheet.
94 jz, bruiser, la, cage,5.3 ls, 36 swampers 98 jz, the mutt, 3.5 iro, 33 swampers, avalanche conversion, 02 north face avalanche blacked out work truck, 06 rhino R1 engine, 4x4, Leeroy's custom paint, 04 escalade wifes truck 22s, 03 duramax 18s, completely blacked out, efilive by nick, wicked wicked truck, 39 chop chevy rod, aluminum 5.3 ls, 08 apex, 310hp mcx turbo, holz 162, completely black, CCM built.
badbird17x is offline
Unread 04-27-2012, 08:24 AM   #132
xbeakerx
You all make me laugh. Everyone that came and looked at it this past weekend ate their words when they saw it plus said they would hook up to me any day of the week in any situation. I'm talking about at least 5-6 people that saw it that weekend.
Speedbucket, You live in Virginia. I will gladly come to your house show you my setup and then drag your peice of **** all across your yard without bending one thing on my Jeep. Just to shut you the **** up.
Its like talking to a wall with you people. I know i will never convince you of my setup until it gets ripped off when someone pulls me out of mud going 60mph and i know that is what you idiots want me to do. I did get in Mud this past weekend but it wasn't needed to winch me. I was not going to waste anyone time trying to get winched out for the sake of you idiots pleasure.
xbeakerx is offline
Unread 04-27-2012, 08:38 AM   #133
sevenscrew
I think it'll do fine in any straight pull, but tbh I don't think a side pull would be ideal with that thing, nor any stock tow hooks either. I think you should run a Steel tube from the side to the other side for extra strength, plus you can use it then to push over small trees
4" Rough Country Series 2 lift kit with steel radials 33x12.5x15 on d windows
iro rear adjustable track bar, carolina driveline u joint front driveshaft
replaced transmission at 162k with a junkyard one that had 102k.
sevenscrew is offline
Unread 04-27-2012, 09:26 AM   #134
speedbucket
Speedbucket, You live in Virginia. I will gladly come to your house show you my setup and then drag your peice of **** all across your yard without bending one thing on my Jeep. Just to shut you the **** up.Its like talking to a wall with you people. I know i will never convince you of my setup until it gets ripped off when someone pulls me out of mud going 60mph and i know that is what you idiots want me to do. I did get in Mud this past weekend but it wasn't needed to winch me. I was not going to waste anyone time trying to get winched out for the sake of you idiots pleasure.
that is very doubtful, and the I6 can barely get out of its own way stock
there numerous posts on adding a piece of box in across the top of that thing to make it legit spend 12$ on steel and have your "master welder" tie it into the dropped brackets and you will get the cyber pats on the back i think you were originally looking for.
leave your pride at door on the internets
good luck!
Unread 04-27-2012, 10:04 AM   #135
xbeakerx
good luck!
I'm not the one hiding behind a computer monitor.
Please do not insult my friends or you will be asking for a true visit from me.
xbeakerx is offline
Closed Thread
