My Front Recovery System(PICS) - Page 7 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > ZJ Grand Cherokee Forum > My Front Recovery System(PICS)
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineMemorial Day Sale at Under Cover Fabworks! 15% Discount oNOTCH CUSTOMS - Max Clearance Fender Flares
Closed Thread
Unread 04-22-2012, 10:13 AM   #91
suthrnsoldier
Originally Posted by badbird17x View Post
Straps have very little rubber band effect. Rope will act like a rubber band but are very dangerous unless you have great recovery points. I use straps simply for the safety. At least with a strap weakness is shown without people getting hurt.
I can see your point.... i meant they have some give as opposed to say a winch cable or a chain
1996 JEEP GRAND CHEROKEE 4.0 4WD DAILY DRIVER
3.5" lift ( spacers, coil springs, adj track bar, extended sway bar end links) ,33x11.50 super swampers, k&n intake, magnaflow exhaust and cat, true 2.5 in from cat back, Throttle body spacer, custom winch bumper
suthrnsoldier is offline
Unread 04-22-2012, 10:22 AM   #92
badbird17x
badbird17x's Avatar
1994 ZJ
Definately. Chains destroy things lol. Straps are a great mix of absorbing shock without the safety issues. If you have solid overbuilt recovery points ropes work awesome, but again are dangerous.
We use an 80,000 lb rated rope to pull rail cars when we load them. It will hold back my 38,000 lb tractor with no problem but pulls over a million lbs with the brakes on slightly. Point of this is ratings are very misleading. You can pull a zj in neutral down the road with a 2000 lb strap, but I'd it's stuck I wouldn't hook up with anything under 20,000, and that's pushing it.
94 jz, bruiser, la, cage,5.3 ls, 36 swampers 98 jz, the mutt, 3.5 iro, 33 swampers, avalanche conversion, 02 north face avalanche blacked out work truck, 06 rhino R1 engine, 4x4, Leeroy's custom paint, 04 escalade wifes truck 22s, 03 duramax 18s, completely blacked out, efilive by nick, wicked wicked truck, 39 chop chevy rod, aluminum 5.3 ls, 08 apex, 310hp mcx turbo, holz 162, completely black, CCM built.
badbird17x is offline
Unread 04-22-2012, 10:54 AM   #93
suthrnsoldier
haha... we just bring lots of straps... when one breaks, just put two on next time.... lol but then again im not pulling a freightliner out of a canyon or anything!
Unread 04-22-2012, 11:05 AM   #94
badbird17x
badbird17x's Avatar
1994 ZJ
I carry a 30,000 40ft. I can't break it and it has got me out of many bad spots, but it is only as strong as what it's hooked to.
Unread 04-22-2012, 11:36 AM   #95
suthrnsoldier
I feel ya there... i got a nice winch bumper off an old farm jeep and im catchin hell tryin to get it mounted on my ZJ... i got it on there and bolted and sandwiched to the frame and welded to the front crossmember thats attached to the frame but im not quite satisfied yet.... got my thinkin cap on for now...
Unread 04-22-2012, 11:46 AM   #96
badbird17x
badbird17x's Avatar
1994 ZJ
Welding 1/2 bolts down the side of the frame to bolt it on is working incredibly well. I had to pull it sideways with a tractor once, pretty sure the front diff was going to get ripped out. It's tested and strong.
Unread 04-22-2012, 11:58 AM   #97
suthrnsoldier
the sheet metal frame up front always scares me... wish they woulda just used a full boxed frame like every other solid vehicle......
Unread 04-22-2012, 12:17 PM   #98
badbird17x
badbird17x's Avatar
1994 ZJ
That's why I welded a good 10 inches on each. This way it has to rip 80 inches of flat iron, and I had it cranked up on the left side as there is some meat inside for the steering box mount. Frame is fully boxed, just made of pretty light stuff.
Unread 04-22-2012, 09:41 PM   #99
ratmonkey
Living dead mod
ratmonkey's Avatar
Straps have an incredible amount of potential energy they can build before breaking. When a strap breaks in the middle, it will just fall, unlike a winch or chain. But if the strip holds and the recovery point breaks, you just made a missile with the kinetic energy greater than a rifle shot.
No matter what you are using for recovery, use a line weight/damper.
ratmonkey is offline
Unread 04-22-2012, 09:49 PM   #100
badbird17x
badbird17x's Avatar
1994 ZJ
Whenever I've had something break with a strap it drops because they do not stretch for crap, I assume this is why they are used for securing cargo when hauling. Nylon ropes on the other hand I can feel stretching like a rubber band. Ropes are more successful in the jerk pull catagory, until something breaks, then they are deadly.
Unread 04-22-2012, 11:15 PM   #101
ratmonkey
Living dead mod
ratmonkey's Avatar
I've seen a strap whip a tow hook straight through a windshield. They do stretch quite a bit.
Unread 04-22-2012, 11:38 PM   #102
tirus89
Originally Posted by xbeakerx View Post
What do you think rollcages and frames are put together, I'll give you a hint its not bolts. If its going to ever rip out its going to have to take the entire front assembly also. There is no way it will do that.
http://www.genright.com/ProductInfo....ductid=GRC5500
http://www.jpmagazine.com/shop4parts...ges/index.html
There is more than one way to skin a cat
Im a student and employed and have a Haynes.
//93 ZJ//5.2L//NP249//K&N Fipk Gen II//2" BB w/BD AT Shocks//4.10's//31" Cooper Discovery STT's//Cstm Frnt Bmpr//Custom Rear Tube Bmpr//3" Magnaflow exhaust w/high flow cat//500RMS Pioneer Amp//600RMS 12" JL Audio Sub//
tirus89 is offline
Unread 04-23-2012, 08:01 AM   #103
speedbucket
No action pics yet....maybe he's still stuck in a mud hole at oakridge because nobody would hook up to him
http://www.jeepforum.com/forum/f22/speedbuckets-zj-build-1361322/
V8 zj,4.5" ...coming- boat sides, rear stretch, tringulated 8.8, streched front HP30, bead locked 35s.....
speedbucket is offline
Unread 04-23-2012, 03:22 PM   #104
RedZJ
Got Mud CNJ 4x4
RedZJ's Avatar
Id hook up to him.. I really wanna see how it does..
RedZJ is offline
Unread 04-23-2012, 04:11 PM   #105
Dyn0mitemat
You are correct if you're indeed talking about 'tow straps'. As they're made for towing, not recovery use.
If you get a REAL 'recovery' strap, then they'll stretch a good bit. I have one and it works very well.
Check it out:
edit:
Didn't read your post all the way lol, or didn't think about it. Rope=recovery strap, so nvm about what I said
98 ZJ: Built 44/88, long arm'd, locked, 35s, armour, blah blah blah
Build Thread: http://www.jeepforum.com/forum/f22/green-zj-aka-jolly-green-giant-1386118/
Dyn0mitemat is offline
Closed Thread
