My first post and my fix for no speedo and overdrive not working - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > ZJ Grand Cherokee Forum > My first post and my fix for no speedo and overdrive not working
KrawlOff-Road.com Jeep Beach SaleFS: Wranger BRIGHT License Plate LED! Just $3! Great valueEliminate Hood Flutter!!!
Unread 02-15-2014, 09:55 PM   #1
Zjjames84
We'll I'm new on the forum but by no means new to searching and browsing the forum or new to jeeps.
I have a 95 zj 5.2 orvis and have no speedo and no overdrive after searching and trying things like a new vss and checking the connectors and cluster I pulled the whole assembly and found numbers on the gear of the vss and also found numbers on the black housing. I had 35 on the gear for number or splines and clocked the vss aka put the horse shoe adapter on in the notches to center the numbers 28-38. After I took it for a test drive and both the speedo and overdrive worked.
I am posting this due to finding tons of people with the same issues but most just give up or never actually post the cure. I hope this helps.
Zjjames84 is offline   Reply With Quote
Unread 02-16-2014, 01:40 PM   #2
dusterdude
Good info,thanks
dusterdude is offline   Reply With Quote
