My First Jeep - Page 3 - JeepForum.com
post #31 of 36 Old 04-01-2013, 03:03 PM
LouC
2007 WK
You have a 4.0, I would not go crazy on tire size ESP if you have 3.55:1 gears as most do. Bigger tires are going to make it feel SLOW. The biggest I'd go is 30" tires maybe with a budget boost. Bilstein HD shocks, Wagner brake rotors and pads Dynomax cat back exhaust. I like OE for any sensors, aftermarket can cause trouble.
Best thing to do is go thru it and fix whatever the previous owners neglected. At that age there will be things for sure. My take on it after 15 years of ZJ ownership and maintenance.
2007 WK Limited Hemi QDII
1998 ZJ Laredo 4.0 Selectrac
LouC is offline
post #32 of 36 Old 04-01-2013, 03:28 PM
MTBlue
3.55? I was under the impression that all ZJs came from the factory with 3.73s... My 94 did at least. As did my 9er... And all 3 of my friends... And that weird kid down the blocks... So I count like 6 ZJs with 3.73 gear ratio... Maybe its just a Montana thing?
Dirt Deprived
MTBlue is offline
post #33 of 36 Old 04-01-2013, 03:50 PM
LouC
2007 WK
All V-8s had 3.73:1s, and if you ordered the tow package on the 4.0 you also got it, but a stock 4.0 with no tow package was 3.55:1. I would have given the 4.0 4.10s seeing as how they need all the help they can get!
I've had different size tires on my ZJ over the years but it feels noticably faster with 225/75-15s which are only 28.5" or so.
In some years (like 93-95 or so) they came with 225/70-15s and those are a hair under 28" tall, but with those it probably gave the best acceleration times. Keep in mind the little 4.0 only has 225 ft lbs of torque vs the V-8 having 300 so bigger tires that weigh more and change the effective gearing do slow it down.
LouC is offline
post #34 of 36 Old 04-01-2013, 05:12 PM
MTBlue
Boy ya learn something new every day! That actually makes a ton of sense!
You are absolutely right about the 4.10s. They don't call the 4.0 the 4.slow for nothing... Especially compared to the 5.9. I just can't get over the difference in the two. It absolutely blew me away when I drove my 9er for the first time!
Dirt Deprived
MTBlue is offline
post #35 of 36 Old 04-01-2013, 06:48 PM
LouC
2007 WK
Well I drove a 4.0 for 11 years and 125,000 miles, then I took a test drive in an 07 WK Hemi, took it out on the Northern State Parkway out here in LI and hit the gas...well...that converted me to the Hemi religion...just like a '69 Charger off the line, power everywhere and not so bad on gas either. BUT, when the complexity of the WK really sank in, I decided to keep the old 98 ZJ 4.0 in case any of that wiz bang technology gives me fits. I do still like the simple 4.0, so I have both. The ZJ I use for most of my local driving and beach 4 wheeling, the WK for boat towing and road trips.
LouC is offline
post #36 of 36 Old 04-02-2013, 09:51 PM
MTBlue
Magnums and Hemi's are like a drug if you as me. My magnum HAULS and my moms friends Hemi smoked a brand new Mustang off the line. Blew me away!
Dirt Deprived
MTBlue is offline
