My easy/cheap rear spring post extensions - JeepForum.com
post #1 of 22 Old 04-26-2009, 03:14 PM Thread Starter
ShantasticZJ
I wasn't thrilled with the way the 2" spacer was flush with the rear post.
So here is my solution.: picked up some exhaust pipe adapters (Inexpensive, and available at any parts store.)
You can see that they fit perfectly. They will be attached with JB weld and a few self tapping screws.
They are a little longer then I wanted, but they should be fine. I will probably want extended bump stops, or hockey pucks on the spring perch because of the length.
I will report back after it's all installed.
EDIT:
It worked out great.
-Shann
Originally Posted by gaTJgal View Post
LOOK!!! I escaped the kitchen!!!!
HERS: 98 5.2 ZJ Loredo. 249 to 242 Swap. Skyjacker Hydro shocks, Painted Canyons, Bedliner on the rocker panels. Front tow hooks. 2" Budget Boost. 31" SXT a/t.
. De-striped, roof rack, 31" BFG's. Lifted with 3" rusty's coils, s-10 bastard pack, Rancho shocks up front, and F-150 shocks in back.
Theirs: 85 XJ 2dr 5 speed, v6, junkyard build trail rig/project
1986 F-150 The Purple Beast! 300 I6, tow package, granny stick, 3" body lift and 35" wild country's
ShantasticZJ is offline
post #2 of 22 Old 04-26-2009, 03:49 PM
ZJcrawler45
good thinkin! i was also worried about that when i did mine.
Captain Nate
ZJcrawler45 is offline
post #3 of 22 Old 04-28-2009, 08:04 PM
Hilltop
kind of sad that i have three sons who haven't a clue when it comes to cars. its my daughter that's mechanically inclined. tell Ryan, nice hair cut!
Your Jeep is always the first to know you just got paid!
Hilltop is offline
post #4 of 22 Old 04-28-2009, 08:22 PM
daufuskieraised
Thats a great 'write up'. Really simple mod but really helpful. The way you painted your rockers makes your Jeep look like it sits so much higher. Looks awesome.
1996 ZJ Laredo
1.75"BB, Monroe Shocks
Cheap Radioshack CB radio
Magnet antenna
daufuskieraised is offline
post #5 of 22 Old 04-28-2009, 08:26 PM Thread Starter
ShantasticZJ
thanks. After those went in I realized they should have been painted first.
-Shann
post #6 of 22 Old 04-30-2009, 07:31 PM
Joshhamburger
what size are the extension pieces you used? diameter
Joshhamburger is offline
post #7 of 22 Old 04-30-2009, 07:34 PM
runnerboy2010
looks like they say 1-3/4" ID and 1-3/4" OD.
92 YJ
runnerboy2010 is offline
post #8 of 22 Old 04-30-2009, 08:03 PM
shdybrady19
I had a coil spring pop out on my the other day bc of my spring spacer. So this is getting done tomorrow
1996 5.2 orvis: 6" lift, 33x12.50's, 8.8 rear, t-case skid, gas tank skid, 242
Originally Posted by nick62087 View Post
If you can weld and aren't afraid to take a chance, I'd say try it - someone's gotta do it.
LOOKING FOR 96-98 ZJ CARPET, TAN OR BLACK IN COLOR, ALSO LOOKING FOR HOOD HINGES. 93-95 MIGHT BE COMPATIBLE
shdybrady19 is offline
post #9 of 22 Old 04-30-2009, 08:05 PM
sandman
great idea but the BB is on wrong. it goes.
body
spacer
isolater
spring
1993 Jeep ZJ. 4.0
sandman is offline
post #10 of 22 Old 04-30-2009, 08:19 PM
shdybrady19
i had no idea either. I have it set up like she does. damnit
post #11 of 22 Old 04-30-2009, 08:51 PM Thread Starter
ShantasticZJ
body
spacer
isolater
spring
I've seen it done either way. Does it really matter?
-Shann
post #12 of 22 Old 04-30-2009, 08:51 PM Thread Starter
ShantasticZJ
Yes. That is what they say.
-Shann
post #13 of 22 Old 05-01-2009, 12:48 AM
sandman
well ive had a spacer buckle running it the way you have it, it was in the front though. so in my case, yes it does matter.
1993 Jeep ZJ. 4.0
sandman is offline
post #14 of 22 Old 05-01-2009, 11:13 AM
ZJ_Papa
also if you think about it the isolater is there to help keep the spring in place
"Any man can be a father it takes a real man to be a dad!!"
1997 Jeep Grand Cherokee 4.0L Stocker: My DD
2002 Toyota Camry: R.I.P It was a great car
ZJ_Papa is offline
post #15 of 22 Old 05-01-2009, 11:27 AM
tirus89
Well, more stuff to do to my jeep now. Might as well get new isolators too!
tirus89 is offline
Cheap easy ZJ antenna mod; power to fixed HighLonesome ZJ Grand Cherokee Forum 10 10-25-2010 09:07 AM
KOR Rear Post Spring Extensions? RrCoX22 ZJ Grand Cherokee Forum 7 04-18-2009 08:48 PM
WJ budget boost- do you need bump stop extensions and spring retainers? winkosmosis ZJ Grand Cherokee Forum 17 01-16-2009 09:22 PM
It wasnt cheap, easy, pretty, or done right, and it kind of smells micifus ZJ Grand Cherokee Forum 11 07-27-2007 05:41 AM
KOR Spring Retainer Extensions? FivePointTwo ZJ Grand Cherokee Forum 15 04-20-2006 05:25 PM
