Quantcast My Drop Bumper I made... - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > ZJ Grand Cherokee Forum > My Drop Bumper I made...
Old 02-24-2009, 11:14 PM   #1
redhatman
Got pulled over for bumper height the other night. 25" to the bottom of the bumper here. I was at like 29". Now at 23"
Made this over the course of two days, and decided to add a hitch and d-rings back on it.
Here ya go. Mounts into the hitch and then two more supports with grade 8 bolts into the back end of the hitch. Pics.
-Pat I'm 19, and getting my hands cut while learning
"Project Dirty Princess"
5.9 ZJ 7" IRO, 35s, 8.8, hp30, locked, blah blah
"Project Grow A Set"
Originally Posted by CMARJEEP View Post
Those tires look freakin awesome Redhat... took the ZJ up a notch in my book. Now you're at notch 2.
Looking for quality Jeep parts? www.ironrockoffroad.com
redhatman is offline   Reply With Quote
Old 02-24-2009, 11:18 PM   #2
thudson331
cant really tell but is that whole setup held on by one boolt to the frame on either side?
Good tattoos aren't cheap, Cheap tattoos aren't good!
thudson331 is offline   Reply With Quote
Old 02-24-2009, 11:18 PM   #3
-cAcHe-
It looks...different... i take it its just for looks..those mounts wont hold up.
www.desert-hooligans.webs.com
Originally Posted by CarolinaWK View Post
I like happy endings :2thumbsup:
RIP Troy Edwards (bigbluezj94)
-cAcHe- is offline   Reply With Quote
Old 02-24-2009, 11:20 PM   #4
-cAcHe-
ohhh its held up with your original hitch...ahhhh now i see..you can take it off whenever you want.nice
Old 02-24-2009, 11:21 PM   #5
daufuskieraised
It slides into the tow hitch reciever. I think it will hold just fine. Good job Redhatman
1996 ZJ Laredo
1.75"BB, Monroe Shocks
Cheap Radioshack CB radio
Magnet antenna
daufuskieraised is offline   Reply With Quote
Old 02-24-2009, 11:21 PM   #6
Jones
Infowars.com
Jones's Avatar
That's a retarded law. Seems like they make these laws just cause they're bored or something.
What is it about Ron Paul?
Jones is online now   Reply With Quote
Old 02-24-2009, 11:25 PM   #7
daufuskieraised
I call it stupid too. Although when I think about it, lower cars need a lower bumper to hit instead of being beheaded. But for the record, I still call it stupid.
1996 ZJ Laredo
Magnet antenna
Old 02-24-2009, 11:29 PM   #8
bbehnke
looks great but defiantly beef up how it mounts to the jeep. those 2 bolts just aint going to hold up to the forces your going to see when you pull your self out or even towing something.
all in all kudos to u for building that. it takes alot of skill to make something useful from scratch.
edit never mind i didnt see that it slid into the hitch.
2001 WJ I6 selec-trac
64,000 miles
accessories: manik brush gaurd, KC daylighters, 2" BB w/ rusty's shocks, Dueler A/T REVO 245/75/R16, mudflaps, tow package, 1.5" wheel spacers, kevins exhaust, and an AIR HORN!
RED JEEP CLUB #424
bbehnke is offline   Reply With Quote
Old 02-24-2009, 11:37 PM   #9
EMTimZJ
GSMW!
EMTimZJ's Avatar
1994 ZJ
Pat, nice thinking on mounting it to the hitch. I don't mean to be too critical but the 1x0.5" flat bar you used for the "supports" won't do anything but maybe stop some rattles.
What are you using to weld this? (ie process and set up)
I'm a little concerned about your weld for the 2" box tube that fits into the hitch receiver, it looks like it is just butt welded to the angle iron...
What did you use to cut that 1/2 flat stock?
Anyway, I don't mean to come down on you, but I would consider redoing that receiver connection.
Keep working and learning as you go.
*EDIT*
Something like this for the hitch mount.
-Tim GS-MW 2009 INFO
KD8EBC
'94 ZJ 5.2 LTD
Project TORTOISE Build-up thread
JCR Rock Sliders Ford Taurus E-fan Install Dana 20 Twin Stick
EMTimZJ is offline   Reply With Quote
Old 02-24-2009, 11:41 PM   #10
bigbluezj94
1994 ZJ
thats the craziest nonsense i ever heard. bumper laws are GAY. i would move before i bolted that to my jeep haha. atleast you should get hassled any more. i wouldnt leave that on if i were goin wheelin though.
94 Grand Cherokee Laredo ZJ, lifted, 37s, yada yada yada
BigBlue build 33s, 6in lift and short arms
http://www.jeepforum.com/forum/f197/bigbluezj94-build-thread-679496/
BigBlue build 3/4 ton axles, LAs, 37s
http://www.jeepforum.com/forum/f197/3-4-ton-zj-build-818891/
99 Grand Cherokee Laredo WJ, 4.7 liter, 247 Quadra Trac II, fully loaded
bigbluezj94 is offline   Reply With Quote
Old 02-24-2009, 11:46 PM   #11
crazydude2500
what did you make it out of looks like an angle then a channel on the bottom what size is the tube ? 2 1/2 sq 1/4 wall ?
pat
green lifted 4.5 w/32's custom front bumper 5.2L
97 xj stock blue tow hooks F&R 4.0L
2004 dodge neon SRT-4
crazydude2500 is offline   Reply With Quote
Old 02-24-2009, 11:50 PM   #12
crazydude2500
ifi had to guess i would say you used 1 1/2 1/2 flat 4x3 1/2 angle and a 3 inch channel
pat
Old 02-24-2009, 11:51 PM   #13
redhatman
I am glad you posted again after that because I was going to call you RETARTED.
EMtimZJ, I completely agree with your idea, however I am on prohibation for some tickets and have already had a couple cops on my case so I cant afford to go without a drop bumper for long at all.
It was welded with an industrial welder at school. HUGE welder, with a separate spool. Hardwire MIG.
I am Very confident in the welds.
The side supports were basically a "gusset" for side pulls on the d-rings or hitch, and to help distribute impact if a rear-ending does occur. Just because there was not room for triangular gussets on the actual hitch itself.
Old 02-24-2009, 11:53 PM   #14
redhatman
Main Piece is 3x3 .25" wall. D-rings are 1/2" found at northern tool. Side supports are 1 x .5" solid steel. Reciever tubes are 1/4" wall with 2" reciever setups. Gussets are 1/2" Solid.
Old 02-24-2009, 11:55 PM   #15
mudwhoreTJ
so why do the ricers not have laws about being to low?
mudwhoreTJ is offline   Reply With Quote
Glock Forum
