My CB Install Thread: Midland, Firestik
| Truck-Lite's New LED Headlamp Series | Ruffstuff Axle Simple Swap Kit! | Spartan Lockers FREE SHIPPING Excellent Prices |
#1 | |
I put on my antenna today, I still have to install the cable and the CB headunit yet into the jeep. I like how it looks so far though.
I bought a 5 ft. firestik brand antenna. I bought a door jam mount for it and it is very sturdy. The mount was only recommended for 4 ft. but I don't think that other foot will matter. Hopefully I will get the rest of it in this weekend. More pics to come! ![]() ![]()
1997 ZJ Laredo-183k 4.0 2" BB 31" BFGooodrich AT 15 in. Cragar Soft 8's Rola Roof Rack Rough Country Shocks 01 WJ-79k, 4.0 Stocker |
#2 |
Local *******
where did u get that bracket
Zack
I REFUSE TO TIP TOE THROUGH LIFE TO ARRIVE SAFELY AT DEATH!!! 96 ZJ Ironman4x4fab front long arms, Clayton subframe and Belly skid, 6" coils, 35" Goodyear Wrangler MTR with Kevlar, IRO OTK, Front / Rear bumpers, Cage, Rear armor, Skid row gas tank skid, Lots of trimming, Boat sides Ford 9"/ HP44 with ECGS 4.88's in the works RIP Troy aka BigBlueZJ94 FroBot Fab FTW My Build Need spare drive shafts or axle shafts? Need a ZJ washer bottle for your WJ? PM ME $30 + shipping to the lower 48 |
#3 |
WalcottCB.com has great stuff. I got most of mine from there.
#4 |
The thing I don't like a CB sticking out there is that if you offroad in any woods, chances are you are going to get close a tree. Trees like to grab stuff. Won't be pretty.
#5 |
that bracket would not last on my jeep. looks like it would be vonerable to branches. probably wouldnt be so bad if you didnt mount it backwards.
#6 |
Local *******
i think if it was turned the other way it would be less likely to get ripped off in the woods also a spring would help alot
Zack
#7 |
Yeah I may have to move it to the otherside, it's a swivel one so if I want it on the right side I have to mount it that way.
#8 |
I agree. 10 char
#9 |
Ok finally got the thing installed, I will get pics up later.
I am having a problem though. I have the antenna grounded to the frame and the cb grounded to the frame. I have Sirius Satellite radio antenna that is above my hatch and it is causing interference with my CB signal. If I move the satellite antenna will this help or am I just going to have to turn off my sirius when I want to listen or use the cb? Any suggestions or things to try?
#10 |
I would start with grounding the CB to the battery, it sure helped to get rid of a lot of interference for me.
#11 |
that's where i had it originally, it got better when it went to the frame. It's the sat. antenna. Don't know what to do though.
#12 |
Survivor
Here is some pics of my antenna mounts.
The two lower ones I made myself some 2 and a half years ago, and they have lasted well with heavy wind load antennas. They are made with Home depot plate molded to the inside of the door with a hammer. The one unused my my Diamond K 400 spare mount and it is lip mounted with two set allen screws. I find that the fact that the antennas are mounted in the tailgate towards the back, they have been less likely to get damaged, and I also like the fact that they are out of the way when the tailgate is lifted for loading. I did add a grounding strap between the tailgate and the body at the hinge. |
#13 | |
Wicked Pissah
2004 WJ Laredo-selectrac 242-I6- Amsoil drop in filter-Saguaro 4x4 Front 3/4" shackles, Rear hitch & Warn 3/4" shackle-Mopar Front skid,Gastank skid -IRO TC skid- RRO super sliders- 6.5'' IRO critical path lift -IRO extended rear arms-Bilstein 5125 shocks -IRO F&R 6.5'' Bump stops-Carolina drive shaft-16x7 black soft 8's - 34'' Super swampers-Yukon 4.11 gears -Ultimate RCV shafts - LockRight Locked ECGS bolt in rear D60 -35 spline Chomloy shafts -BTF HD diff cover -IRO Adj A-arm-OX Locked super D30 -OX HD diff cover -OX drive away lock-Rock Krawler d30 truss-Stillen rotors & Matrix pads-JKS Adj Track Bar-JKS Quicker discos -OME SD-40 Steering Stabilizer-Relocated washer bottle-Removed rear sway bar-Cobra CB-TomTom one XL navi-alpine deck Built 44hd for sale Still to come: Flowmaster 50suv Western Mass 4X4 Club October 2011 GCOTM Winner |
#14 |
I think we have trail damage in the same spots on both of our jeeps. First, the tire catching the fender and now this. Except mine is on the other side.
This tree got me.![]() |
#15 |
So anyone have any suggestions or experience with a CB and a SAT antenna?
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
