My blower motor won't work - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > ZJ Grand Cherokee Forum > My blower motor won't work
Zone Offroad Body and Suspension Lift Kits, Brackets, DiscJeep Wrangler Framless, Bowless, Trektops 92-95 YJ, 97-06 Baseline 4x4 Lifetime Warranty 4340 Chromoly Axle Shaft Ki
Unread 11-24-2009, 08:44 PM   #1
ksturgio
I've been having an issue with my blower motor in my 97 Zj. The blower motor would work on and off since i bought it. Just randomly work if i left it on. I replaced the resistor with a dealer part no dice. I removed the blower motor and directly connected it to a battery and it would run. I re installed it and it still won't work. I took apart the knobs and cleaned up the connectors and it still won't work. I've checked the relays the grounds for the dash and now i'm looking for any more suggestions before i break down and take it to the shop.
ksturgio is offline   Reply With Quote Quick reply to this message
Unread 11-29-2009, 02:51 AM   #2
MudMenace
1987 FSJ Wagoneer
I had the same problem while on a 14 hour road trip from nc to Michigan, worked on it in the parking lot for 3 hours. Replaced resistor, fuses, relays, jumped power to the the motor and it worked fine. Turned out to be a loose connection. There's a white harness above the interior light above the passenger kick panel pushed it tight and worked like a charm. I must have knocked it loose when I replaced the bulb in the light.
-Ethan Stanley (Mud Menace) 87 Grand Wagoneer - 6 inch Hell Creek, 33x10.50r15 BFG KM2, 10k HID with H4 headlamp housing.
MudMenace is offline   Reply With Quote Quick reply to this message
Unread 11-29-2009, 11:40 AM   #3
jeepgc99lmtd
1955 CJ3A
On the wjs there is a connection that melts. Thats what happened to me. Im not familiar with the ZJs so idk if it could be the same problem.
1999 WJ, 4" BDS Suspension Lift, Cragar 342 Series Wheels, Westin Front Brush Guard, 265/75/r16 Cooper STT's FOR SALE!!
1955 Willy's M38A1 Project
jeepgc99lmtd is offline   Reply With Quote Quick reply to this message
Unread 11-29-2009, 08:38 PM   #4
skunked_once
It does happen to ZJ's and it happened to my 97 also. Here is the link with a picture of the connector.
http://www.jeepforum.com/forum/f13/6...sistor-872458/
Hope this works for ya!
skunked_once is offline   Reply With Quote Quick reply to this message
Unread 11-29-2009, 09:47 PM   #5
ksturgio
Thanks jeepgc99lmtd and skunked once you guys are awesome i've been trying to fix this problem for almost a year. Once i looked at the connector i could tell it was fried. I owe you guys big time. If your ever in vegas I'd be glad to take you out to dinner or drinks or whatever thanks a ton. I still have question as to what caused it to short out. If i just make fresh connectors for the wires what is to keep it from shorting out again.
Unread 11-29-2009, 10:35 PM   #6
jeepgc99lmtd
1955 CJ3A
no problem dude. glad to help. It took me about a year to figure out mine to so I know the feeling. I decided I better hurry up and fix it since its starting to get cold again. now i apparently have blend door problems giving me a massive headache
on my wj I had to replace both the wiring and the resistor replaced because the resistor wasn't doing its job like it should have been so it was frying the connector and if I just put a new connector in I would have had them same problem all over again. the resistor had to be replaced with a newer one which did its job correctly. once again not familiar with the zjs but it sounds like the same problem so if I were you I would just replace everything. it would be better and save you money in the long run.
It pisses me off that chrysler wont do anything about this since it could potentially catch on fire. I hate dealing with them
