My Antenna is Garbage, how much is this gonna set me back? - JeepForum.com
post #1 of 3 Old 09-11-2004, 06:55 AM Thread Starter
madmanfrommars
madmanfrommars's Avatar
Okay I replaced the stock radio with a Pioneer radio about two years ago (great radio by the way).
My problem is, that recently, my radio reception has gone from bad to worse. I know the source of some of these stations is very close to me, but my reception is still garbage.
I think the antenna may need to be replaced? What do you think, and how much will this cost me?
As far as I know, I'm the only person to own a flame red liberty with the light bar, and until someone disproves that to me, I'm going to enjoy it.
madmanfrommars is offline
post #2 of 3 Old 09-11-2004, 08:18 AM
Meerkat
Your antenna is basically nothing more than a wire with a sheilded coax connecting to the radio. Unless you have done something to damage the coax (such as cut it) it's unlikely to "go bad". The two places to inspect are where the coax connects to the base of the antenna, and where it plugs into the back of the head unit.
At the base of the antenna is a screw (or nut) and a couple washers with the coax having a couple of eyelet terminals. If you take that all apart and go over it with emery cloth then re-assemble it, you may see an improvement in signal strength to the radio. Going over the connector at the back of the radio with emery cloth wouldn't hurt either.
I haven't bought a complete antenna in a number of years, but I wouldn't expect a new one to run more than $50.00 USD.
HTH
Warren
Black 1996 5.2L ZJ Limited
Meerkat is offline
post #3 of 3 Old 09-11-2004, 10:46 AM
GrandRubicon155
mine went bad last year and i called my junk yard and they had some. went up and pulled it out of a 93' and it was $15. i have a motorized one and we just swapped it out, if you have a stationary one i would think that would be a bit easier.
sean
99' TJ Sport, 31inch MTR's, Lift Comming Soon
GrandRubicon155 is offline
i think my I6 is gonna die.... 2tone93zj ZJ Grand Cherokee Forum 19 11-01-2009 10:12 AM
Who's gonna buy that bad boy? WyoZJ ZJ Grand Cherokee Forum 19 01-31-2009 02:09 PM
gonna get a GC jeepxj91 ZJ Grand Cherokee Forum 4 08-26-2008 07:45 PM
06 commander heat/ac smells like garbage.. placencia12 WK Grand Cherokee & XK Commander Forum 1 04-05-2008 05:28 PM
it was gonna be toke ZJ Grand Cherokee Forum 14 01-08-2007 02:36 PM
