My 98 Grand Cherokee Laredo jerks forward while in park - JeepForum.com
post #1 of 10 Old 03-25-2011, 02:11 PM Thread Starter
JeepRumors
The moment i park the jeep - whether the engine is running or not, my Jeep will make a jerking motion as if it wants to move forward at the same time making a single popping sound.
the jeep will do it a few times maybe more. Best way to describe the motion is to imagine sitting in your car and a person leans on your rear end of the car causing the car to jerk forward from the pressure of the person.
What could this be?
Just to let you know i factored in the chance it might be my gas sloshing around.
the jerk motion timing is unknown i usually sit and wait till it happens again.
it could be 2 3 small pops and tiny movement to a medium pop with an inch like jerk forward.
JeepRumors is offline
post #2 of 10 Old 03-25-2011, 03:30 PM
Mark05059
sounds like the parking "pin" isnt engaging fully.
1998 ZJ 5.2 Auto
1989 Wrangler Black Bone Stock 2.5l 5spd
/l , [____],
|---L--[]lllllll[]-
()_) ()_)==O=)_)
Mark05059 is offline
post #3 of 10 Old 03-25-2011, 07:47 PM
Wood2km
Have all of the recalls been completed on your jeep? There is a recall that makes it firmer when you shift to park, so that it goes all the way into park when you shift the lever.
Wood2km is offline
post #4 of 10 Old 03-28-2011, 07:35 AM Thread Starter
JeepRumors
i bought used ayear ago
I bought the jeep used a year ago and it does all kinds of funky things. I had to pull the fuse for the interior lights as well because they would turn on by themselves.
What or where should i look to find information about these recalls you mentioned?
post #5 of 10 Old 03-28-2011, 08:59 AM
Wood2km
You can put the vin in on chryslers website, or on carfax. You don't have to pay to see if there are recalls.
Wood2km is offline
post #6 of 10 Old 07-15-2014, 08:49 AM
retrotek
1998 FSJ Cherokee
I have the same exact problem with my 98 Grand Cherokee 5.9 limited. I just had the transmission rebuilt as well. It happens in park, with the Jeep running or right after turning the Jeep off (for up to 2 minutes). It feels like someone is pushing the back bumper, it's the strangest thing.
Did you find a solution?
Thanks
J
retrotek is offline
post #7 of 10 Old 07-15-2014, 11:37 AM
Candymancan
You guys talking about when you put it into park and let off the brakes it will roll forward like an inch and then stop ? You know pretty much every car does that... which is why its best to use the parking brake as well to keep pressure of the parking pin in the transmission... My 5.9 does this as well and makes the same pop underneath... Im not worried about it.. been doing it since I got it 4 years ago.. The 4.0 does it too it just doesn't pop
Candymancan is offline
post #8 of 10 Old 07-15-2014, 11:50 AM
retrotek
1998 FSJ Cherokee
It's not that the car rolls forward, it's lunges slightly like someone is jumping on the rear bumper while it's in park. It happens when while it's running, and also happens to me after I shut the engine off (up to 2 minutes after)! I literally just had the transmission rebuilt after 140K (pump went bad), but that didn't fix it.
It's almost like energy is being built up somewhere in the drive line, like a rubber band being twisted, and then suddenly released. Is there a center bearing in the drive shaft on these? Someone mentioned the possibility of brake calipers getting stuck, but I don't think that would be it. Ideas?
retrotek is offline
post #9 of 10 Old 07-15-2014, 03:16 PM
marduksenforcer
My jeep used to do this until last friday. I have the 4.0, and yes, it did pop as well. Had the stealer do the recall for the shifter and no more problems.
Didnt know there was an open recall(other than the hitch) until i emailed chysler for my build sheet.
-AJ
marduksenforcer is offline
post #10 of 10 Old 07-15-2014, 03:51 PM
jeepzj1998
Do you have a 249 transfer case? If so, VC probably going bad.
jeepzj1998 is offline
2007 Grand Cherokee Lurches forward when put in DRIVE Natemare13 WK Grand Cherokee & XK Commander Forum 8 06-22-2009 02:05 PM
99' Grand Cherokee Laredo $2,500 Boscy ZJ Grand Cherokee Forum 16 01-12-2009 02:05 PM
Grand Cherokee 3.1 TDI Laredo erasmuslj ZJ Grand Cherokee Forum 6 08-19-2008 02:39 PM
2000 Jeep Grand Cherokee Jerks?? nczj95 ZJ Grand Cherokee Forum 5 03-06-2008 05:45 PM
Grand Cherokee 'Park' lever selection ldldw1 ZJ Grand Cherokee Forum 17 11-02-2006 11:09 AM
