my 95 cherokee will turn over but not start - JeepForum.com
post #1 of 14 Old 02-21-2013, 03:53 PM Thread Starter
farlerau
My 95 grand Cherokee would turn over but not start untill the battery died and now the battery will hold a charge but a very low charge. I initially replaced the spark plugs and ignition coil. I'm out of ideas and need help, thanks
farlerau is offline
post #2 of 14 Old 02-21-2013, 05:04 PM
MilanJeep
MilanJeep's Avatar
Alarm activated? (are the lights flashing)?
98 5.9 ZJ - 4.5" lift, 33x12.50 MT/R Kevlars
02 Z06 - Supercharged, E85, lots of rwhp, built and tuned by me
Milan
MilanJeep is offline
post #3 of 14 Old 02-21-2013, 05:38 PM Thread Starter
farlerau
No, and no dash lights are flashing or stay on
farlerau is offline
post #4 of 14 Old 02-21-2013, 07:17 PM
KoreaZJ
1994 ZJ
Make sure you have a good battery with a good charge, battery cables clean/tight on both ends.
Otherwise you'll be chasing ghosts.
KoreaZJ is offline
post #5 of 14 Old 02-21-2013, 07:26 PM Thread Starter
farlerau
Its good now, same problem though. Crank but no turn over
farlerau is offline
post #6 of 14 Old 02-21-2013, 07:48 PM
wolfy418
Have you checked to make sure fuel is getting to the engine? Or to be more specific, do you hear your fuel pump turn on when you put the key in the "on" position?
wolfy418 is offline
post #7 of 14 Old 02-21-2013, 07:56 PM Thread Starter
farlerau
Yes and yes, fuel pump is good and motor is getting gas
farlerau is offline
post #8 of 14 Old 02-21-2013, 08:01 PM
wolfy418
You could always try pulling out the spark plug w/wire, ground the threads to the block or whatever, and turn it over and make sure you have a spark. Fuel/Air/Spark.
wolfy418 is offline
post #9 of 14 Old 02-21-2013, 08:01 PM
TipMeBackOver
2003 WJ
sounds like the crankshaft position sensor is bad, does your jeep have a dizzy or coil pack? ,if you have the distributor then its more then likely the magnetic pickup in the dizzy, if you have the coil pack then it could be the cam position sensor, can you check for codes?
TipMeBackOver is offline
post #10 of 14 Old 02-21-2013, 08:22 PM Thread Starter
farlerau
Sparks good as well, and what's the difference between the dizzy and the coil? And where is that sensor at?
I have a coil pack by the way
farlerau is offline
post #11 of 14 Old 02-21-2013, 08:33 PM
TipMeBackOver
2003 WJ
you have spark,dizzy=distributor ,the crankshaft position sensor is located on the passenger side of the engine right where the engine bolts to the trans, have you checked the fuel injector relay?also i would rent a fuel injector test noid from auto zone, and check to see if u have a pulse at the injectors while cranking
post #12 of 14 Old 02-21-2013, 09:08 PM Thread Starter
farlerau
Oh okay. And my father said he checked the relay and it was good. And okay I'll take a look at that sensor tomorrow, what should I look for? I know its got to have a certain clearance gap?
farlerau is offline
post #13 of 14 Old 02-21-2013, 09:29 PM
KoreaZJ
1994 ZJ
Check for fault codes. Learn how... HERE
KoreaZJ is offline
post #14 of 14 Old 02-21-2013, 09:32 PM Thread Starter
farlerau
Thanks everyone for the help. I'll be back on tomorrow for the results
farlerau is offline
grand cherokee , wj , wont start
