Quantcast My 8.8 ZJ Rear End Build Thread - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > ZJ Grand Cherokee Forum > My 8.8 ZJ Rear End Build Thread
RUBICON EXPRESS Lift Kits and Accessories Available at BasSpartan Lockers FREE SHIPPING Excellent PricesFree Shipping on TIRES at KrawlOff-Road
Old 11-05-2008, 11:47 PM   #1
redhatman
I picked up an 8.8 rear end today from an Exploder... 3:73 gears which is what I have now, some rust (has a good amount of rust, stock with fords). Now I will be working on fitting it into the rear of my 1998 ZJ in place of the Dana 35.
The axle at the pull your own parts yard was $86, but every first wednesday is half price day on parts. So $43 for an 8.8 And being I got there with about an hour to work on it, I had the guys cut it out with the torch. $50, a huge ask tractor, and a gigantic engine crane to lift the exploders rear end later, I had an 8.8. Only downside I see is drum brakes, and I noticed tonight I have two small holes in the diff cover
PICS:
I had to make sure there was metal underneath that rust!
I will need everything for this install so any links/write-ups would be appreciated. I will need the brackets and all so... yeah. Thanks
-Pat
-Pat I'm 19, and getting my hands cut while learning
"Project Dirty Princess"
5.9 ZJ 7" IRO, 35s, 8.8, hp30, locked, blah blah
"Project Grow A Set"
Originally Posted by CMARJEEP View Post
Those tires look freakin awesome Redhat... took the ZJ up a notch in my book. Now you're at notch 2.
Looking for quality Jeep parts? www.ironrockoffroad.com
redhatman is offline   Reply With Quote
Old 11-06-2008, 12:05 AM   #2
JeepOrvis97
One of 2733 :)
JeepOrvis97's Avatar
-Pat
http://www.mallcrawlin.com/forum/showthread.php?t=2880&highlight=8.8
My Classifieds
JeepOrvis97 is offline   Reply With Quote
Old 11-06-2008, 12:07 AM   #3
BucYouUp68
www.mallcrawlin.com There are some good write up's over there. Good Luck, and a screaming deal for a 8.8
[I]No man stands as tall as when he bends to help a child.
I feel sorry for people who don't drink. When they wake up in the morning, that's as good as they're going to feel all day.[/I]
[QUOTE]Why is there a fish finder in your Jeep?[/QUOTE]
______0__0
/__l_l_,\____\,__
l_---l_l__l----( )jeep( )
._(o)_)__(o)_)--o-)_)
BucYouUp68 is offline   Reply With Quote
Old 11-06-2008, 12:34 AM   #4
FortCollinsZJ
Pat, that first link is the one I followed to prepare mine. No all I have left to get for it is the truss from claytons.
ARP wheel studs: 30$ (ish)
Spicer Dana yoke adapter: 35$ locally
Brackets and tabs: Mine are cut from a d35. I would recommend going with ballistic fab stuff though. its MAD beefy and very affordable.
Mine was 200$, but I have NEW discs on it, they are like a month old from the looks of it. It also has a LSD. You made away with a steal though.
Here is my rust bucket, turned beauty queen.
Nothing here
FortCollinsZJ is offline   Reply With Quote
Old 11-06-2008, 04:00 AM   #5
sandman
ooh! looking forward to the build. rustys has a rear axle bracket kit too, nothing as beefy as BTF though. what do you have for a welder?
1993 Jeep ZJ. 4.0
sandman is offline   Reply With Quote
Old 11-06-2008, 07:30 AM   #6
redhatman
I have a Clarke 130EN which is a 110 (not planning on using other than to tack) and then my buddy just bought a 220 Clarke a couple of days ago and he said I could use it. Both are Wire feed, otherwise if I feel like doing stick I know someone else that has a 220 Lincoln Stick.
Old 11-06-2008, 08:40 AM   #7
StrokedWJ
Are you gonna try to reuse your ZJ brakes on the 8.8?
The 8.8 diff covers are tinfoil POS. Go ahead and plan on upgrading to an aftermarket cover like a MORE or Rockcrusher.
2000 WJ 4.5L - Stroked, Locked, & Long-Armed
Click this -->Think you can beat me?
StrokedWJ is offline   Reply With Quote
Old 11-06-2008, 08:48 AM   #8
spidermonkey
Lookin good. If you have drums it is most likely only 28 spline shafts but still stout. For a diff cover I used the stock one with a $50 Rusty's diff guard. RS is the way to go if you can swing it.
98ZJ, 4.0,242, 8.8 Detriot, hp30, 4.56's
My build here: http://www.jeepforum.com/forum/f197/spidermonkeys-98-zj-build-716209/
North Shore Wheelers www.nsw4x4.com
spidermonkey is offline   Reply With Quote
Old 11-06-2008, 11:55 AM   #9
Sporer65
Location: Powder Springs, Georgia/University of Tennessee
All Explorer 8.8s have 31 splines.
Too bad on getting one with drum brakes, but I think that you should be able to switch over your brakes. But at least you got one with a limited slip.
Ben
1993 Jeep Grand Wagoneer ZJ V8: Rear Aussie, 3.5" Lift, 31" M/Ts
GA Trail Riders
Sporer65 is offline   Reply With Quote
Old 11-06-2008, 12:09 PM   #10
ArloGuthroJeep
Mr. Hyde!
ArloGuthroJeep's Avatar
The stock diff cover is SUPER thin so it is a good thing that it has a hole in it...that way you are forced to upgrade to a quality version
ArloGuthroJeep is offline   Reply With Quote
Old 11-06-2008, 01:16 PM   #11
Jones
Infowars.com
Jones's Avatar
Nice find redhatman. I got one about two months ago with aussie locker and 4.56 gears. Unfortunately mine came with drum brakes as well. I'm going to put 4.56 up front and do four new disc brakes.
What is it about Ron Paul?
Jones is offline   Reply With Quote
Old 11-06-2008, 01:48 PM   #12
redhatman
A couple of Questions.
1.) Will my ZJ Disc setup fit on the 8.8 with little modification? If yes, what is required?
2.) What is the big circle thing on the left side by where the input from the transfer case comes in? You can see it in the first pic.
3.) What do I need to do to my driveshaft? I have ~6" of lift now and my shaft sticks out of the t-case probably 2.5" from stock. Wouldnt the 8.8 have a bigger yoke, and therefore require a shorter driveshaft and I should be good?
4.) What about ABS and E-Brakes?
Old 11-06-2008, 02:20 PM   #13
TslAtticus
1994 ZJ
I'm doing the same thing....eventually. I have the 8.8 w/discs and 3.55's. Is this what one would need to do the swap? http://rustysoffroad.com/mm5/merchant.mvc?Screen=PROD&Store_Code=rustys&Product _Code=RC-RAM399&Category_Code=cus
I'm going to try and cut the old ones off the d35 but in case I booger them up i want to be sure.
TslAtticus is offline   Reply With Quote
Old 11-06-2008, 02:39 PM   #14
Jones
Infowars.com
Jones's Avatar
You can use that or your old mounts if you want to save money. The down side is having to cut the old ones off.
Old 11-06-2008, 02:40 PM   #15
aircruiser
Moparrrrrrrr
aircruiser's Avatar
nice man, guess iron rock cleaned out the 44s and 8.8s because when i went with nick, there were a shat load of 8.8s and two 44s. oh well, atleast your ***** little 35 will be gone abs is over-rated. so your rear-end has a limited slip now? wow that sounds really gay
-2001 Dodge Dakota Quad Cab 4x4 - 4.7 V8, the new hotness!
-1997 Jeep Grand Cherokee Limited - 4.0, 4" lift, 33s, bilstiens, IRO stuff, FOR SALE
-1999 Jeep Cherokee Sport 2 door - 4.0, 8" lift, 35" KM2s, IRO stuff, Long Armed, Armored, Rolled, Parted
aircruiser is offline   Reply With Quote
Glock Forum
