my 5.2 zj will not run with tps plugged in - JeepForum.com
post #1 of 7 Old 05-22-2014, 05:43 PM Thread Starter
thezjkid
Truck shutters and stalls with tips plugged in, unplug it runs good. Replaced tips no change had access to new computer tried it no change only code that was present was p0123 any ideas ?
thezjkid is offline
post #2 of 7 Old 05-22-2014, 07:50 PM
newfieZJ
You may have a wiring issue . It's reading high voltage so I would think the wires may be shorting somewhere . Time to start checking/tracing/testing wires , especially around and close to heat sources
1995 Orvis build
1988 MJ build
1998 Slate 5.9 build
1998 Platinum 5.9 build
newfieZJ is offline
post #3 of 7 Old 05-22-2014, 08:02 PM
UltimatE
Resident Audio Guru
UltimatE's Avatar
Also, check your grounds on the PCM as well as around the TPS & Clock spring wiring. Make sure they are good and clean.
-Matt
White '94 YJ Sport
Green '94 XJ Sport - 57,000 Original miles
UltimatE is offline
post #4 of 7 Old 05-24-2014, 09:14 AM
UltimatE
Resident Audio Guru
UltimatE's Avatar
Ended up being a broken clock spring causing TPS issues through a shared ground. Anyone know where to locate a speed sensitive clock spring these days?
-Matt
White '94 YJ Sport
UltimatE is offline
post #5 of 7 Old 05-25-2014, 11:17 AM
ikidd
You mean on your steering wheel? How was that affecting your TPS?
1998 ZJ 5.9 - 4", NP242
1998 ZJ 4.0 - Stock
1977 CJ7 304 Auto
1994 ZJ 4.0 "Rammy" RIP
ikidd is offline
post #6 of 7 Old 05-25-2014, 02:40 PM
ozzy_2_me
1994 ZJ
I can get you a clockspring I just need to know what you need it for.
ozzy_2_me is offline
post #7 of 7 Old 06-17-2014, 10:26 AM Thread Starter
thezjkid
the clock spring uses the same reference signal as the tps. I disconnected the clock spring started right up and ran like a champ.
thezjkid is offline
