My 5.2 Build Thread - Page 7 - JeepForum.com
post #91 of 117 Old 11-03-2013, 02:20 PM
95GCL
Sucks about the leak!
I have the same situation.. I'd lift it but then new tires are 600 bucks and the current ones have under 10k from PO
95GCL is offline
post #92 of 117 Old 11-03-2013, 03:39 PM
Myusername1674
Thats weird it's leaking, did you torque it all criss cross? Are you sure it wasn't just resedue from when you changed it? That's always possible
Sent from my couch using JeepForum app
95 FiveTwo ZJ, DD, Lifted, Locked on 35s,
(in progress)
Myusername1674 is offline
post #93 of 117 Old 11-03-2013, 05:01 PM Thread Starter
ZJNewbi3
Treadwrights are fairly cheap and good tires. My problem is the rim. My rims r garbage and leak
Just trying to keep her goin'!!
ZJNewbi3 is offline
post #94 of 117 Old 11-03-2013, 05:05 PM Thread Starter
ZJNewbi3
Oh I hand threaded criss cross, then ratcheted criss cross, then final torqued criss cross! Today when I retorqued I criss crossed too. The pan was bone dry when I left work too. Kinda weird but hope the retorque takes care of it. If not I guess ill baby the fluid all winter then try again in spring. All out of love for the vehicle xD
ZJNewbi3 is offline
post #95 of 117 Old 11-03-2013, 05:29 PM
95GCL
Treadwrights huh? Retreaded bfgs? Where can I find those?
95GCL is offline
post #96 of 117 Old 11-03-2013, 06:04 PM
riot1987
I ordered mine at treadwrite.com
Build thread^^
riot1987 is offline
post #97 of 117 Old 11-03-2013, 06:09 PM
95GCL
Thanks! This will save a lot of money!
95GCL is offline
post #98 of 117 Old 11-03-2013, 08:41 PM Thread Starter
ZJNewbi3
Yeah I'm definitely buying them when I'm ready to upgrade to 30s. Lookin' at either the Guard Dogs or the Wardens
ZJNewbi3 is offline
post #99 of 117 Old 11-03-2013, 08:43 PM
riot1987
Theyre way cheap. I have read lots of good reviews on them as well. I got 5-315/70/R16's shipped to my door for $850. Havent had a chance to wheel em yet though...
Build thread^^
riot1987 is offline
post #100 of 117 Old 11-03-2013, 10:05 PM Thread Starter
ZJNewbi3
What lift height are you running?
ZJNewbi3 is offline
post #101 of 117 Old 11-04-2013, 05:59 AM
riot1987
Im sitting about 7" in the front and 6.5" in the rear
Build thread^^
riot1987 is offline
post #102 of 117 Old 11-04-2013, 08:52 AM Thread Starter
ZJNewbi3
That's awesome! When I make my jeep a trail only rig I think ill put 4.5" on it.
ZJNewbi3 is offline
post #103 of 117 Old 11-04-2013, 10:18 AM
95GCL
The only 30x9.5x15 I see are Pumas. Are they still good?
95GCL is offline
post #104 of 117 Old 11-04-2013, 10:46 AM Thread Starter
ZJNewbi3
The tread on those looks like the tread on the Badyears the PO threw on the jeep. I didn't like em and thy weren't to good in the snow. But then again with multiple tread depths and being leaky along with the rims, I would never truly know.
Drove to school today, and still saw a little pan leak. Tomorrow I'm going to try to re-torque again and see what happens. I'm regretting not using RTV now
Either that or it wasn't flat. Using a steel ruler across each hole all turned up level. If I turn it upside down on the flat drive, it would rock a little bit. From what I under stood "check for flatness across each bolt hole" meant what I did with the ruler. I took my dads + uncles advice that "the bolts take care of that" and put it up knowing it rocked when put on level ground.
ZJNewbi3 is offline
post #105 of 117 Old 11-04-2013, 11:17 AM
95GCL
Not what I wanted to hear D: since I'm only putting 30s on with a 1.75" spacer, not 2". So 31s would be like 40 more and rub
95GCL is offline
5.2l , build thread , limited , v8
