My 5.2 Build Thread - Page 6 - JeepForum.com
post #76 of 117 Old 10-21-2013, 01:57 PM Thread Starter
ZJNewbi3
Originally Posted by Scopez View Post
I need to find a good crimper so I can put lugs on all my ends. Any suggestions? Or were you able to just leave the wire exposed and screw it down tight?
I left them exposed and bolted them down tight then sprayed some seal stuff on it.
Just trying to keep her goin'!!
ZJNewbi3 is offline
post #77 of 117 Old 10-21-2013, 07:58 PM Thread Starter
ZJNewbi3
Here are some pictures of the new terminals. Sorry about the stupid flash glare...
ZJNewbi3 is offline
post #78 of 117 Old 10-22-2013, 12:36 AM
Myusername1674
I just did the same thing to my battery terminals, only $5 at O-Reillys. The factory terminals had shredded. haha those quick discos look nice though, I didn't get that.
95 FiveTwo ZJ, DD, Lifted, Locked on 35s,
(in progress)
Myusername1674 is offline
post #79 of 117 Old 10-22-2013, 07:46 AM Thread Starter
ZJNewbi3
I think mine were around $7 with tax. Now I can't wait til I can get an Optima Yellow Top!
ZJNewbi3 is offline
post #80 of 117 Old 10-22-2013, 09:06 AM
PolkaPower
I would skip the Optima since the price is still the same even though they are made in Mexico now. Sears makes some very nice AGM batteries though.
PolkaPower is offline
post #81 of 117 Old 10-22-2013, 03:50 PM Thread Starter
ZJNewbi3
I'll be waiting a very long time for this to happen anyway xD the Die Hard is only a little over one year old.
ZJNewbi3 is offline
post #82 of 117 Old 11-02-2013, 04:08 PM Thread Starter
ZJNewbi3
Replaced the tranny pan filter with a WIX and gasket with Fel-Pro (no RTV). Also gave the pan a nice cleaning. Hopefully this stops all leaking! So far so good! Cross your fingers for me!
ZJNewbi3 is offline
post #83 of 117 Old 11-02-2013, 06:42 PM
moparlover1992
Good luck I always hate trans pan leaks. On mine I dropped the pan multiple times before realizing the quick disconnect fittings that tap into the tranny that the tranny cooler lines hook to were leaking. Replaced those and so far so good. Just something to keep ur eye on
Sent from my Galaxy Note 3 using JeepForum
95 zj 5.2 np242 3.5'' IRO lift, IRO adjustable arms, KOR front trackbar, steering stabilizer and box brace, IRO rear adjustable trackbar, bilsteins, Hughes plenum plate, flow master 40, 31x10.5s on 15'' dc-2 rims
Mopar or no car!
moparlover1992 is offline
post #84 of 117 Old 11-03-2013, 06:51 AM
95GCL
Quick question: Did you have to do the trimming on the front bumper? Was there rubbing?
95GCL is offline
post #85 of 117 Old 11-03-2013, 07:19 AM Thread Starter
ZJNewbi3
Nope didn't have to. My tires aren't big enough to rub. They are 235/75/15 which is around 28" in diameter. They are still within stock spec. (225-245) Hopefully down the road I will get 30s on 15s/16s
ZJNewbi3 is offline
post #86 of 117 Old 11-03-2013, 09:01 AM
95GCL
Oh haha I had looked at another users pictures thinking they were yours. Do you have pictures of the stock sized tires with 2" bb? I have stock tires and want to bb (might buy 1.75" spacer ) but it would be some time before I can buy tires
95GCL is offline
post #87 of 117 Old 11-03-2013, 10:38 AM Thread Starter
ZJNewbi3
Yup go to page 6 and there will be one there! If u want a better one ill take some when I'm home
ZJNewbi3 is offline
post #88 of 117 Old 11-03-2013, 10:57 AM
95GCL
Found it! Haha lots of wheel gap!
95GCL is offline
post #89 of 117 Old 11-03-2013, 12:00 PM Thread Starter
ZJNewbi3
I totally agree! But those tires were a graduation gift from my parents so Id feel bad sellin em off.
ZJNewbi3 is offline
post #90 of 117 Old 11-03-2013, 01:57 PM Thread Starter
ZJNewbi3
Got home from work today and checked the pan. Found some slow drips I wiped around the pan edge and got some red. Decided to grab the torque wrench and check the torque. I didn't budge the dial AT ALL and all of those bolts needed at least one full turn to be 12.5ft-lbs. The temperature got to a little below forty last night, then back up to fifty today, let alone the tranny warming up to high temperatures driving at 50mph. I'm assuming this is normal, and hopefully that is the reason it was leaking.
ZJNewbi3 is offline
5.2l , build thread , limited , v8
