Is my 46re on its way out? - JeepForum.com
post #1 of 8 Old 02-15-2011, 07:10 PM Thread Starter
jeep360limited
My Jeep has round 175k on the clock and the check engine light has come on for the third time in the past year for what seems like transmission related problems. It always seems to come on when the trans wont shift into overdrive. Even if i let it warm up in the morning(letting it idle in neutral to heat it up) it still wont **** into OD. I have heard that these transmissions are the weak link in the drivetrain and i want to know if it sounds like mine needs a rebuild or something along those lines.
Thanks
Charlie
2003 Ford Ranger Edge
1986 Jeep CJ7
1998 Jeep Grand Cherokee 5.9 Limited-----SOLD
jeep360limited is offline
post #2 of 8 Old 02-15-2011, 07:26 PM
newfieZJ
I doubt it's the trans after reading the FSM about no 3-4 shift .
Coolant sensor
Overdrive Circut fuse
Speed sensor
O/D wire shorted/cut
and thats just a few causes .
Wait for , or PM Ratmonkey , he'll give you a more percise diagnoses
1995 Orvis build
1988 MJ build
1998 Slate 5.9 build
1998 Platinum 5.9 build
newfieZJ is offline
post #3 of 8 Old 02-15-2011, 07:40 PM Thread Starter
jeep360limited
That's what the CEL code was for last time, a hard 3-4 shift. The coolant sensor warning goes off every once in a while, usually only during the warmer months. Are any of those problems expensive and/or hard to fix?
Charlie
1986 Jeep CJ7
post #4 of 8 Old 02-15-2011, 07:57 PM
ZombieJeep93
Whats the dtc? any other symptoms? do you still have 1-2-3 upshifts?
93 Grand Wagoneer (de-wooded) 5.2 Mag, 2"BB, Magnaflo Cat, Gibson ex, K&N CAI, Mopar pcm, 32" BFG AT, Accel truck ignition
ZombieJeep93 is offline
post #5 of 8 Old 02-15-2011, 11:36 PM
jnicewan
Need to read codes, do you have T/C lock up too. Whats the fluid look/smell like???
jnicewan is offline
post #6 of 8 Old 02-16-2011, 12:37 PM
MaintMech
Old and in the way
MaintMech's Avatar
Coolant Sensor
If it's the low level sensor that shows up as bad on your VIC there's a great thread on here about troubleshooting it. phild328 started it. Probably a bad solder joint on the VIC display.
Good Luck!!
MaintMech is offline
post #7 of 8 Old 02-17-2011, 02:24 AM
ZJ5point2GCL
Good Luck!!
i dont think the VIC has a sensor for trans fluid level, its almost impossible to measure electronically.
newfies on the right track though.
whats the DTC? when the CEL is on?
98 Deep Slate Niner- 6''s on 35's ---11 F150 Platinum Pearl White- Modded Tiny V6 with Two Turbos. ---93 Black 5.2 limited- Slowly dying in my Parents Driveway
ZJ5point2GCL is offline
post #8 of 8 Old 05-14-2013, 11:33 AM
Goliath27
Not to open an old thread again but don't want to start a new one. Has this ever been fixed?
I'm having the same issues now. 96ZJ, 4.0 - 1-2-3 are fine but it wont shift out of 3. I think if I get to a high enough speed it started to shift or maybe slip, hard to tell.
I changed the TPS thinking that was the problem and nothing changed, so now I'm here.
Trans fluid is good, and I just had it serviced not too long ago at the dealership.
edit: I also recalled having a couple of codes -
P0720 (M) Low Output Spd Sensor RPM Above
15 mph
Output shaft speed is less than 60 rpm with vehicle speed
above 15 mph (4-speed auto. trans. only).
P0740 (M) Torq Con Clu, No RPM Drop at
Lockup
Relationship between engine and vehicle speeds
indicated failure of torque convertor clutch lock-up system
(TCC/PTU solenoid)
but received conflicting answers about them. When I cleaned the IAC it stopped giving me the problems and then it just went to crap.
Goliath27 is offline
46re Tutorial baxy ZJ Grand Cherokee Forum 128 12-06-2015 03:13 PM
46re bowtie_65 ZJ Grand Cherokee Forum 3 05-25-2010 06:57 AM
46re rebuild akohlbaker ZJ Grand Cherokee Forum 3 11-02-2009 10:06 AM
46re in a 5.2 shdybrady19 ZJ Grand Cherokee Forum 4 10-09-2009 05:39 AM
46re? Travis873o ZJ Grand Cherokee Forum 4 08-03-2009 01:12 PM
