My '02 GC Died This Morning - Help. - JeepForum.com
post #1 of 16 Old 01-23-2006, 08:57 AM Thread Starter
KellyN
Hello.
Usually it fires right up, but this morning it was "Shug shug shug shug shug shug shug vroooom!".
I thought to myself, well, it is winter here in freezing San Diego. Maybe it was just a bit cold.
I drove about 2 miles and it just stopped. Good thing I was at a stoplight. It started right back up again, no problems.
Pulling into the Starbucks parking lot it died again. Now I'm a pretty strong guy and it was pretty tough to steer, good thing my wife wasn't driving or someone would be dead.
I noticed that my clock was reset back to 12:00. All the gauges read normal. Last week the check engine light came on, but I think it was because my gas cap was loose. Anyways, it was off this morning as well.
Any clue what this might be? Battery perhaps?
Thanks,
Kelly
2002 Jeep GC Limited
V8 HO
35k miles
KellyN is offline
post #2 of 16 Old 01-23-2006, 09:02 AM
BlaineWasHere
BecauseRacecar
BlaineWasHere's Avatar
I don't think it had anything to do with the cold becuase I assure you it is at leasat twice as cold were I am! Around here if it is above 32 right now I think about waring shorts!!! NO JOKE!
ANYWAY I would take your Jeep to the dealer (Only becuase it should still be under warrenty) and have them check the alternator and the batt.
2013 FR-S
BlaineWasHere is offline
post #3 of 16 Old 01-23-2006, 09:04 AM
Phil Gerard
Former Mod
Phil Gerard's Avatar
Tell the dealer that your check engine light came on also so that they read the codes.
Phil
'95 ZJ Ltd. White 4.0L
TW DC DS; ARB Bull Bar, F&R Air Lockers; Superior Axles; Warn Winch; 4.56 gears; ACOS, Addco F&R Sw Bar, JKS Discos, Rr Track Bar & Nerfs, 249>242 Swap, Stillen rotors+Kolak pads, 3 pc. Armor, RE 4.5 Kit + 2.5"BB, Adj. UCAs&LCAs, OME SS, Bilstein 5150s, 15x8 AR Diamond Backs, 33 Truxus MTs, K&N FIPK, RE 62mm TB, Perf. Distr. 4.0L Kit, Exhaust: 2.5" Kolak exhaust FM 70: Optima Yellow, Mean Grn Alt., PIAA 520s, 540s, Kevins Rack, & TB Conversion
Phil Gerard is offline
post #4 of 16 Old 01-23-2006, 09:05 AM
ArloGuthroJeep
Mr. Hyde!
ArloGuthroJeep's Avatar
But don't do the dealer unless it is under warranty still...Autozone/checker/etc... will check it for free. My bet is your battery or alternator as well
*An 02 isn't normally under warranty still unless you buy the extended warranty...is 3 years or 36k miles, which ever comes first...is past the 3 year mark...
'14 WK2 Limited w/5.7L, ORAI, & Tow Package
ArloGuthroJeep is offline
post #5 of 16 Old 01-23-2006, 09:11 AM
EMTimZJ
GSMW!
EMTimZJ's Avatar
1994 ZJ
When the battery is low, the electrical system (which controls the fuel system etc.) does not function normally.
-Tim
KD8EBC
'94 ZJ 5.2 LTD
JCR Rock Sliders
EMTimZJ is offline
post #6 of 16 Old 01-23-2006, 09:11 AM Thread Starter
KellyN
It passed the warrenty in June. And I just passed 35k miles last month.
This car is really p-ing me off because right as the warrenty expired the problems began:
1) The driver side heated seat burnt out. It literally turned 500 degrees then didn't work anymore.
2) The dual zone climate controls only work on the driver side. The passenger side just blows cold air.
3) Now the current problem (all in the last 2 weeks)
I'll take it down to the autoparts store and check the codes.
Any other ideas?
Kelly
KellyN is offline
post #7 of 16 Old 01-23-2006, 09:16 AM
wrigleylaredo
2008 KJ Liberty
Wow all that in a few weeks? Sorry to hear that. Where in San Diego are you, I grew up there.
Was a 2002 Grand Cherokee Laredo, I-6 ,Steel blue, 4x4, stock for now. Now it's a 2008 Liberty Jeep Metallic Green, Command Trac, sunroof, and that new car smell.
wrigleylaredo is offline
post #8 of 16 Old 01-23-2006, 09:18 AM
anticrombie
anticrombie's Avatar
1. ouch
2. blend door. do a search around here and you'll see it's a very common problem.
3. I'd suspect a dead or almost dead battery or a bad alternator. Go to an autozone, checkers, etc. and have them read the codes from the CEL. I'm gonna guess it's the code saying the battery was disconnected within the last 50 starts.
Charlie
anticrombie is offline
post #9 of 16 Old 01-23-2006, 09:25 AM Thread Starter
KellyN
Thanks for your help.
Seriously, when that seat got hot it was like my nuts were in a frying pan. I was using my elbows to prop myself up until I found a spot to pull over.
Oh.. I'm in the Bay Park Area..
KellyN is offline
post #10 of 16 Old 01-23-2006, 10:13 AM
Woody
Retired back to Bowties
Woody's Avatar
1985
The seat heating element is probably worn out. You can get a repair kit for $25 or so at the dealer. You can do a search as fixes have been posted for that as well.
Check your battery connections. If you are able to crank the engine after it dies, it makes me believe the battery has enough juice to get the job done. If the alternator was gone, the battery would also be dead when you went to crank it again. If you connections are loose, you would all of a sudden experience a stall and your clocks and stuff would reset.
Hopefully you get this sucker figured out.
Woody
1985 1 ton K-5, Detroit diesel, 36" tires (going bigger when money permits), 4-speed manual swap, Rockwell T-case, Hybrid lift, 12.5K winch.
Woody is offline
post #11 of 16 Old 01-23-2006, 10:27 AM
MtnbikerWJ
MtnbikerWJ's Avatar
Loose or corroded battery connections will cause those symptoms
04' WJ Laredo 4.0L 4x4
245/75-16 GY MTR's
Rusty's 2" BB
ARB Bull Bar with Piaa 520 drivings, no winch yet though
Kenwood Headunit, Kenwood Sirius Reciever, RF Punch p2002 Amp, RF Punch 10" Sub enclosure
Hypertech power programmer
K&N 77 series FIPK
Flowmaster 50 SUV
Magnaflow Cat
next gears and lsd's and OME coils
Colorado Jeep Club Member #14
White Jeep Club Member #114
MtnbikerWJ is offline
post #12 of 16 Old 01-23-2006, 01:12 PM
coolest_Stan
check the ground to your starter. I had similar problems, and when I fixed my grounds evyerthing worked perfectly. ALthough your jeep is realtively new so that may not be the problem.
93' Grand Cherokee Limited 4.0 L 190 hp 4x4
235x75 BFG Goodrich A/Ts
K&N Drop In Filter
New Coolant Resevoir Cap
Current Projects:
coolest_Stan is offline
post #13 of 16 Old 01-23-2006, 04:38 PM Thread Starter
KellyN
Update:
Ok, I got the car home... popped the hood and there was a buncha corrision around the battery terminals. I used some baking soda and water to clean them off (worked like a charm) and it started right up.
I lett'r run for about 10 minutes, hopped in and gave'r a few revs and when I pull my foot off the gas it stalls. I also ran the a/c and the lights at the same time to see if it was draining the battery at all, and the needle moved a little, but not significantly.
Any thoughts ?
KellyN is offline
post #14 of 16 Old 01-23-2006, 05:04 PM
ArloGuthroJeep
Mr. Hyde!
Drive 'er to Autozone/Checker/etc... and have the battery/alternator tested.
post #15 of 16 Old 01-23-2006, 07:35 PM Thread Starter
KellyN
Thanks
Took it to Autozone..
Alternater is good.. I replaced the battery and cleaned the connections. Seems ok now.. hopefully. The lease is up on this guy/gal in a few months and she's going back to the dealer for sure.
Doesn't make sense to pay to get the seats and the heater fixed under these circumstances.
What really pissed me off was when I took the car to the dealer they mentioned that my warrenty expired in June and I told them that they either fix it now and make me happy and I'll consider buying another Jeep or fix it when I return it and I'll never buy another Jeep..
They decided that they didn't need me, after 2 jeeps in 5 years. Pity.
KellyN is offline
Morning Sickness? kturano ZJ Grand Cherokee Forum 18 04-23-2011 10:37 PM
So I had an interesting morning... ragincanadian4 ZJ Grand Cherokee Forum 10 02-02-2009 08:49 PM
Got rear ended this morning sabre364 WK Grand Cherokee & XK Commander Forum 4 12-21-2008 06:45 AM
This morning... dmowb ZJ Grand Cherokee Forum 4 03-09-2007 04:33 PM
Jumping in and out of OD 14 deg out this morning? 02Lightning ZJ Grand Cherokee Forum 1 01-31-2007 10:14 AM
