mufflers and Cat - JeepForum.com
post #1 of 10 Old 05-11-2014, 11:47 PM Thread Starter
davidtownsend
2006 WK
So I have a universal cat on it now but am wanting to change it due to my plenum was bad. I had to rig my cat and muffler with clamps to get it past expectation in MD. Now that the metal is all bent i'm going to get either a 3" or 2.5" tail pipe from iron rock. I also have a knock off magnaflow muffler and want to get a real one since the clamps bent the tubing. I'm hoping in the near future I am going to get headers to finish my exhaust. My question to you is what cat and muffler should I get? I want to keep it all magnaflow unless something out performs them in performance. There are a lot of models for both of these items. Another question is what size tail pipe should I get? I drive mainly on highways and interstates with minimal wheeling. I have a 5.2 with a Durango hat, ported kegger, and CAI. Thanks for the help everyone!
1994 Jeep Grand Cherokee 5.2L Limited
2006 Jeep Grand Cherokee Overland 5.7L Hemi
davidtownsend is offline
post #2 of 10 Old 05-12-2014, 06:15 AM
AlphaLorde
Even with simple bolt ons 3" piping is a little big for a 5.2, its even a little big for a 5.9.
I'd run 2.5" from the y pipe back. If you can afford it have the exhaust shop take out the crushed pipe by the oil filter and pass. upper CA. Its been proven time and time again that is good for about 10 ponies and make it a smoother running rig.
Here is a list of good cats for our jeeps
http://www.cherokeeforum.com/f10/my-...verters-96369/
1998 ZJ Laredo 5.2L 139k 231 w/SYE artec trussed 8.8 4.25"F/5"R lift
AlphaLorde is offline
post #3 of 10 Old 05-12-2014, 08:52 AM Thread Starter
davidtownsend
2006 WK
Thanks man. I did replace my entire y pipe. So I don't know if it is still a problem.
post #4 of 10 Old 05-13-2014, 04:39 PM Thread Starter
davidtownsend
2006 WK
What's the difference between the 300 and 400 hole cats?
post #5 of 10 Old 05-13-2014, 04:48 PM
firsttimeZJ13
My guess would be more flow with 400 holes. Anyone know why they crushed the pipes anyways??
1995 ZJ, 5.2L, NP249, stock suspension, e-fan, CAI, engine needs work!! Plan on lift and tires when money finds its way here...
firsttimeZJ13 is offline
post #6 of 10 Old 05-13-2014, 11:04 PM Thread Starter
davidtownsend
2006 WK
What side of the stock muffler is offset? And both inlets/outlets are 2.5 right?
post #7 of 10 Old 05-14-2014, 01:07 AM
Kolak
Vendor
Kolak's Avatar
They crushed the pipe because of assembly line installation ease.
The number of holes is not the only parameter that determines flow. You have to also consider the area of the substrate as well as the frontal area of the converter case, the shape of the case, and the transition from the pipe nipples to the body.
Magnaflow does an excellent job at maximizing converter flow. If you'd like any exhaust information, PM me here on the forum or email me at kolak@aol.com
Jeepforum members get 10% off my Kolak Exhaust by the way.
Kolak Performance and Offroad
Member: Specialty Equipment Market Association
Telephone: 480 998-3661
or
Kolak is offline
post #8 of 10 Old 05-14-2014, 02:22 AM
firsttimeZJ13
Well that makes all the sense in the world. I do need to replace my y pipe some day.
David, my offset was towards the middle of the jeep if I remember. I cut it off the weekend I brought it home due to an entire corner missing from it.
post #9 of 10 Old 05-15-2014, 06:16 PM Thread Starter
davidtownsend
2006 WK
Can anyone post a pic of the stock muffler?
post #10 of 10 Old 05-27-2014, 12:56 AM Thread Starter
davidtownsend
2006 WK
This might be a long shot but has anyone ran a 200 cell metallic cat? If so how does it run?
