Muffler problem -- somewhat urgent - JeepForum.com
post #1 of 13 Old 11-22-2012, 06:55 PM Thread Starter
woodst0ck
1994 ZJ
Hey guys,
My muffler broke off right behind the cat as I was driving today. It's hanging about 7 inches below the cat after i took my jerry-rigged support. my main concern is that the weight of the muffler seems to be resting on the rear track bar, and that it will cause long term damage. Is this a valid concern? my neighbor has a saws all and I can cut the pipe close to the muffler, but I don't know if I need to. the battery has about 20 or minutes before it's ready.
thanks everyone
woodst0ck is offline
post #2 of 13 Old 11-22-2012, 07:06 PM
squazz
gonna rattle and get on your nerves before it causes any damage, But fix it exhaust replacement is a cheap enough fix
squazz is offline
post #3 of 13 Old 11-22-2012, 07:09 PM Thread Starter
woodst0ck
1994 ZJ
I fully plan on fixing it next week. So there wont be any damage caused by the weight and cutting is unnecessary?
post #4 of 13 Old 11-22-2012, 07:12 PM
squazz
personally Id just remove it its easy enough prob dont even need to cut just remove it from the hanger by the tail pipe (2-13mm bolts if you wanna remove the hanger too) then Jack the body up and fish over the rear axle
squazz is offline
post #5 of 13 Old 11-22-2012, 07:16 PM Thread Starter
woodst0ck
1994 ZJ
I think that's where i've been running into to trouble. the tail pipe seems like it's corroded onto the hanger and it's stuck. I also don't really have any way to get the jeep lifted up to get more room to work
post #6 of 13 Old 11-22-2012, 07:33 PM
nicklopic
The whole hanger comes off but you can remove it from that rubber bit with a pick i believe its called
Its a PITA though
98' ZJ 4.0
4.5" short arm, 33" Courser MXTs, custom stubby bumper, skids, someother stuff
nicklopic is offline
post #7 of 13 Old 11-22-2012, 07:51 PM Thread Starter
woodst0ck
1994 ZJ
I ended up cutting it. the muffler was blown out and nearly rusted through. Now I have to decide between a straight pipe and a muffler. And man, that rumble is kinda nice
post #8 of 13 Old 11-22-2012, 08:16 PM
nicklopic
Glass pack is a compromise
Or a nice flowmaster
98' ZJ 4.0
post #9 of 13 Old 11-22-2012, 08:19 PM Thread Starter
woodst0ck
1994 ZJ
Have any of you run a magnaflow? i like their rumble but i can't find a price.
post #10 of 13 Old 11-22-2012, 08:24 PM
nicklopic
You're gonna need to find a dealer probably
A good muffler is exspensive just so you know, also a thrush welded is good too
98' ZJ 4.0
post #11 of 13 Old 11-22-2012, 08:47 PM Thread Starter
woodst0ck
1994 ZJ
a thrush weld?
post #12 of 13 Old 11-22-2012, 09:48 PM
nicklopic
Click to View Search Results for Google (Search Results) Google (Search Results)
98' ZJ 4.0
post #13 of 13 Old 11-22-2012, 09:49 PM
nicklopic
Its pretty much a cheap flowmaster
98' ZJ 4.0
