Mpg/hp Noticably Improved>read Post - JeepForum.com
post #1 of 33 Old 09-15-2009, 11:27 PM Thread Starter
ronsaun
2003 WJ
03 grand cherokee, 4.7L(not HO) 94000 miles. just added an american parts corporation universal fit cold air intake(tossed included filter) cost $59.95, k&n 4" conical air filter $45.00 and a flowmaster 50 seriers muffler $79.95. i cut out the filter box on the intake side with a roto zip to allow for the filter and intake tube to set in it and cut out the grille side to allow more fresh air into the box. replaced the lid. this whole install took 1 hour and looks good. replaced stock muffler with the flowmaster it fit perfect with a 12" extension pipe. this took 1 hour also. the flowmaster has more cfm capability than the factory cfm at the exhaust manifold(520 cfm) the muffler has far more per flowmaster tech support. resulting in a "low" restriction exhaust. found out as well that the factory mandrell bent pipes and the cat convertor restrictions are very negligible anyway. ended up with a great hp increase(throws you back in the seat and "smokes" the tires for 100 feet) and noticably more fuel economy. following is my "test". traverse city mi. to toledo oh. 600 miles round trip flat highway. 180 miles at 60mph averaged 21.8 mpg. 420 miles at 75mph averaged 18.8 mpg. the odometer and speedometer was verified throughout the trip by my garmin 76c gps. factory mpg is 19mpg at 55mph. i feel it is a tremendous inexpensive improvement and easy to do!!!!!!!!!!!!! next i am purchasing a superchip to install the fuel economy program, calibrate for my new taller and slightly wider 70000 mile tires(harder rubber,less resistance,less revs) i have yet to purchase (235 85 16). hope to get a couple more mpg, then i am done with fuel economy unless anyone has an additional idea? by the way, i used 87 octane from speedway and bp.
ronsaun is offline
post #2 of 33 Old 09-16-2009, 12:00 AM
the88thpianoman
2003 WJ
Don't bother with the throttle body spacer. 100% waste of money on the 99+ intake manifold.
2003 WJ in Jeep Green Metallic, 4.0/242/4.10's. 4" Teraflex springs w/ RE monotube shocks and IRO short arms, cheap intake w/ amsoil filter, 2.5" hi flow cat and back exhaust, lots of lights and other misc crap.
Check out my build thread here:
the88thpianoman is offline
post #3 of 33 Old 09-16-2009, 05:15 AM
Turbonut
Often wondered how fuel mileage could increase when a computer keeps the F/A ratio the same before and after installation of parts. You could have a clogged air filter and the fuel mileage wouldn'd drop, but naturally performance would.
Turbonut is offline
post #4 of 33 Old 09-16-2009, 07:40 AM
rm2001wj
rm2001wj's Avatar
Even more amazing than the mpg claim is the claim that it
"smokes" the tires for 100 feet.
My supercharged WJ can't smoke tires for even 5 ft, but I do have Quadra-Drive. Even if I had a 2WD, I still couldn't do that.
rm2001wj is offline
post #5 of 33 Old 09-16-2009, 07:49 AM
srad711
2003 WJ
Originally Posted by rm2001wj View Post
Even more amazing than the mpg claim is the claim that it My supercharged WJ can't smoke tires for even 5 ft, but I do have Quadra-Drive. Even if I had a 2WD, I still couldn't do that.
A one legger 2wd 4.7 will easily smoke'm for 100ft. I've done it.
srad711 is offline
post #6 of 33 Old 09-16-2009, 07:58 AM
99avant
My 4.7 with a 242HD cannot smoke the tires from a stop.. I can get four or five spins on dry pavement.
Brakestands on the other hand...
And if you want better mpg, buy a honda.
|94 XJ|4.0|NP231|AW4|8.25 Trac Lock|Lotsa miles - SOLD
|99 WJ|4.7|242HD|Vari-lok|Upcountry+BB|DT8000|Dead as of 10/29/2009
If it aint broke, fix it till it is.
99avant is offline
post #7 of 33 Old 09-16-2009, 08:03 AM
the88thpianoman
2003 WJ
Probably depends largely on what type of surface you're spinning the tires on.
You pull those rear sway bar links off yet?
post #8 of 33 Old 09-16-2009, 08:07 AM
HighLonesome
Belief In All Things Jeep
HighLonesome's Avatar
In 2wd and at sea level, my modded '94 (5.9, heads, cam, headers) will chirp them for about 10 ft. That's with rear Truetrac and 31" BFG ATs. Then she locks up with the asphalt. Poor D35
Huge difference here at 5400 ft elevation.
HighLonesome is offline
post #9 of 33 Old 09-16-2009, 09:25 AM
rm2001wj
rm2001wj's Avatar
I'll bet you get over 25 mpg on the highway too.
rm2001wj is offline
post #10 of 33 Old 09-16-2009, 09:44 AM
SteelBlue_WJ
SteelBlue_WJ's Avatar
27, he put the K&N sticker in the window! Instant 2 extra MPG!
Bobby
2001 Steel Blue WJ Laredo SA 4x4, 3.5" lift, Apperance Package with factory Laredo Steel Blue cladding/leather
Conferr Roof Basket with custom Randy Ellis Design light cage, WAAG grille guard and Hella lots of 500 lights
2004 Wrangler Sport, 2.5" and 31's, nothing special
"For all sad words of tongue and pen, the saddest are these, 'It might have been.' "
John Greenleaf Whittier
SteelBlue_WJ is offline
post #11 of 33 Old 09-16-2009, 10:22 AM
lvum4x4
I recently made some respiratory changes to my rig and have to admit that it was a very notable difference. Unfortunately, I change a lot of components all at one time so I have no real way to compare each modification on its own. Typically, if you are going to let more in, you will not see much improvement if you dont let more out. Let us know what kind of milage you are getting after a couple of tanks of gas. I believe you definately have the potential for better mileage but at the same time you will have more throttle response and may be prone to lay into the pedal more now?
Here are the changes I made:
  • BBK PowerPlus Ported throttle body (spec'd to be 70mm but it measured at almost 75mm?)
  • K&N FIPK
  • Superchips re-program
  • Kolak MagnaFlow Catback system with a Flowmaster 50 and 3" piping
  • 4 brand new Mopar O2 sensors for the new exhaust system.
I could not believe the increase in throttle response but since I have a new motor I am still breaking it in and couldnt really step on it but there is a very noticable performance gain so as long as I can stay out of the pedal I should see some improved mileage. I will try to post up my findings after I can burn through a full tank and do a real mileage check.
lvum4x4 is offline
post #12 of 33 Old 09-16-2009, 10:23 AM
WiCkeDuDe
WiCkeDuDe's Avatar
I smoked my tires for 100 feet easily the other day. I wanted to try out the quadradrive diffs I installed and see how they grabbed. I held it wide open and eventually the other side kicked in. Oh did I mention it was raining
I Have WJ Stuff for Sale
WiCkeDuDe is offline
post #13 of 33 Old 09-16-2009, 10:45 AM
UrbanOffRoad124
x2 on the throttle body spacer. Waste of money, they make better paper weights than performance mods.
Fact of the matter is, you bought a V8 Jeep. MPG should not be your concern. I've done the same tests after changing my intake , exhaust, tire pressure, etc. It's all a placebo effect, you drive calmer when your trying to get better MPG. Here's how you save MPG, tape a block of wood under your skinny pedal!! Everything else is so negligable. You can improve MPG a little with a nice new air filter and better flowing exhaust, but not the type of difference your gonna notice at the pump. It's still $50-$60 to fill up every time and going an extra 10 miles doen't change the money coming out of your wallet.
But nice to have some new parts, and welcome to the forum.
P.S. -> Your profile shows your own a 2003 XJ Cherokee. Change that, you own a 2003 WJ Grand Cherokee.
'02 WJ | 4.7HO | Limited | QDII | 3.5" Lift (BB+OME Springs) | JKS TB | JKS Quick Disco's | JKS BPE's | RC Nitro 9000's | Rusty's SS | K&N FIPK | 40 Series Delta | Cat-Delete |
Coming soon: 31" KM2's | 15x8 Cragar V-5's
#236 |
#232
"those who do, can't explain; those who don't, can't understand"
UrbanOffRoad124 is offline
post #14 of 33 Old 09-16-2009, 11:39 AM Thread Starter
ronsaun
2003 WJ
my 100 ft of tire smoking is with brakestanding on dry asphalt. needed to clarify that.
ronsaun is offline
post #15 of 33 Old 09-16-2009, 12:52 PM
HighLonesome
I'll pass.
ZJ Forum FAQ's *READ THIS BEFORE YOU POST* Jones ZJ Grand Cherokee Forum 7 01-17-2015 07:53 PM
Read This Before You Post Jones WK Grand Cherokee & XK Commander Forum 0 08-24-2009 01:19 PM
Gas Mileage Improved!! jeepunlimited ZJ Grand Cherokee Forum 6 01-21-2007 08:35 PM
improved steering 241comp ZJ Grand Cherokee Forum 6 07-12-2006 10:33 AM
PLEASE read and offer insight, which one to buy..(last post, promise!) Jetjock16 ZJ Grand Cherokee Forum 11 09-30-2005 01:52 PM
