mounting HF airhorn set. - JeepForum.com
post #1 of 13 Old 06-03-2013, 12:49 PM Thread Starter
airwolf9090
I picked up this set and already taken care of the few things you gotta do to the set to make it ready, But i was wondering could i just plug the Compressor into the stock horn wires? i am mounting the horns to the breather box sides but the compressor i was just gonna mount under the left headlight where the stock wiring goes if i can use that wire for the pump rather than wiring in a new relay etc etc,
This is the set. http://www.harborfreight.com/12-volt...orn-40134.html
1996 Jeep ZJ Orvis
airwolf9090 is offline
post #2 of 13 Old 06-03-2013, 02:23 PM
eagsc7
1994 ZJ
nope...
IF I remember correctly, you will have a set of wires running from the Ign ON to the compressor, then you can use the OEM wiring for the solonoid in the line that actually opens and closes the valve on the hose.
Least , that's how it works USUALLY!
There ARE directions that come with the kit...
eagsc7 is offline
post #3 of 13 Old 06-03-2013, 02:29 PM Thread Starter
airwolf9090
No valve, Its a simple kit 12V+ and a ground on the pump, When power is supplied to the pump it blows the horns, No tank.
1996 Jeep ZJ Orvis
post #4 of 13 Old 06-03-2013, 03:37 PM
eagsc7
1994 ZJ
Either way, read the directions. If it's not in your box, then you can D/L it from your link above.
eagsc7 is offline
post #5 of 13 Old 06-03-2013, 03:40 PM Thread Starter
airwolf9090
Thats not what i am asking, I know how it says to hook it up. i wanna know if i can just use the ZJs horn wiring that is already there to power the bump.
1996 Jeep ZJ Orvis
post #6 of 13 Old 06-03-2013, 06:48 PM
Afdude88
I have a cheap set of air horns in mine and I have the stock wiring from one of the stock horns running to the compressor.(which is smaller than a soda can) It's been like this for over a year with no ill effects.
Dana 35c behind a 242, behind an AW-4, behind a 4.0L Inline Six sitting over a Dana 30, all turning stock 215/75/15 tires and moving a 93 Grand Cherokee to places your truck only dreams of.
1998 Grand Cherokee:
4.0L I6
42RE
242 tc
2.5 OME lift
Afdude88 is offline
post #7 of 13 Old 06-03-2013, 06:57 PM
Anticanman
RIP one good jeeper
Anticanman's Avatar
There should be a relay run from the stock horn wires to initialize the compressor. I had one on my bronco and its not worth installing. Please trust me on it.
Luck Favours The Prepared
Anticanman is offline
post #8 of 13 Old 06-03-2013, 06:58 PM
Afdude88
Haha I just looked at the pic of the one you got. Mine is pretty much the same thing. Compressor just looks a lil different is all. Mine works fine using the stock wiring.
4.0L I6
42RE
242 tc
2.5 OME lift
Afdude88 is offline
post #9 of 13 Old 06-03-2013, 06:59 PM
Afdude88
Now that he mentions it I would have to agree. Occasional instead of an air horn sound it makes a loud screech.
4.0L I6
42RE
242 tc
2.5 OME lift
Afdude88 is offline
post #10 of 13 Old 06-04-2013, 10:33 PM
Mickey_D
Most ZJ's (AFAIK all of them) have a horn relay in the Power Distribution Panel. So the stock horn wiring already has a relay. Adding another one in is rather redundant.
The only time an air horn would need a relay is if the compressor draws more than 15 amps.
And I agree with the above. I recently picked up a set of those air horns and they sound like 4 feral cats with their tails caught under the same rocking chair.
1997 ZJ 5.2 Orvis, Baby!
1953 Willys M100 trailer Tagalong
________________
[_][][][][][][][][_]
#4
Mickey_D is offline
post #11 of 13 Old 06-04-2013, 11:47 PM
xcaliber81
Im trying to imagine what this might sound like but its failing miserably lol.
xcaliber81 is offline
post #12 of 13 Old 06-05-2013, 02:51 AM
ErikTheRad
bwuHAHAHAHAHA!!!! You probably ain't gonna find that description on the box.
ErikTheRad is offline
post #13 of 13 Old 06-05-2013, 09:34 PM
Mickey_D
Ever seen I Love Lucy? Imagine Lucille Ball with her hair caught in a belt sander.
________________
#4
Mickey_D is offline
