motor questions? - JeepForum.com
post #1 of 3 Old 05-07-2009, 03:21 PM Thread Starter
jonnn313
motor questions?
found a guy with a 318 out of a 94 grand cherokee, my question is i need a block and heads, this guy is willing to sell them to me, but will they work with my computer in 97 and will they line up so i can get everything running
like will everything including motor mounts and EVERYTHING mechanical bolt up exactly the same?
in theory it sounds like it will work, but are the bolt patterns and engine clearance the SAME
5.9 dead
5.2 dead
looking for a 5.2!
jonnn313 is offline
post #2 of 3 Old 05-07-2009, 03:28 PM
nashmd454
nashmd454's Avatar
send an email to Nick at kolak@aol.com and he will surely explain all your needs and year issues.
96' JGC V-8 5.2L ltd.
way too much to list.
Thought for the day:
If GOD gave HIS only son for us...can't we at least give HIM an hour of our time a day.
nashmd454 is offline
post #3 of 3 Old 05-07-2009, 03:32 PM
newfieZJ
Everything will work fine . Just use your original intake and sensors . My engine in my 95 is from a 2001 dodge ram , no issues . Motor mounts are the same , everything bolts up the same . Be sure to use your original flex plate also . I think that's all you need to know
1995 Orvis build
1988 MJ build
1998 Slate 5.9 build
1998 Platinum 5.9 build
newfieZJ is offline
Motor Swap: '03 motor into an '01? CHI4WD ZJ Grand Cherokee Forum 2 06-15-2009 10:27 PM
Wired up blower motor power module - do I need to replace blower motor? sniperdude ZJ Grand Cherokee Forum 0 04-19-2009 02:33 PM
I am putting an 04 motor in my 00 grand cherokee but have questions??? itr1446 ZJ Grand Cherokee Forum 2 01-28-2009 05:33 AM
HELP! Blower Motor, Blower Motor Resistor Fix Already Attempted... No Luck! DJGWJ ZJ Grand Cherokee Forum 3 12-26-2008 12:51 PM
94 JGC, where is the blower motor relay, and where's the blower motor ground wire go? camosilver ZJ Grand Cherokee Forum 1 08-24-2006 10:15 PM
