motor mounts - JeepForum.com
post #1 of 20 Old 03-05-2013, 12:44 PM Thread Starter
jeep93GCL
motor mounts
Hey has anybody change their motor mounts on their jeeps is hard and how many mounts is it. When I drive the vibrations goes away when I stop at a red light or stop if vibrates but once I drive away it goes away I was thinking it was the motor mounts has anybody had this problem before....
jeep93GCL is offline
post #2 of 20 Old 03-05-2013, 01:02 PM
xcaliber81
I do exact same thing however by tuning it up and putting feel cleaner in the tank I am narrowing it down to old dirty injectors and worn mounts.
xcaliber81 is online now
post #3 of 20 Old 03-05-2013, 01:20 PM
a20ftsloth
1993 XJ Cherokee
Correct me if I'm wrong but I think it might be two. I'd probably just google it if I were you. Just crawl under there and see if they're dry rotted. But honestly if it goes away at high rpms then it's not the mounts. If I were you I would get in the car, drive down the block, and stop but keep it in drive. Try putting it in neutral and if the vibrations go away then it's your tranny. The best solution is to go home, pull the parking brake, put the car in neutral with the car still on, and check the transmission fluid. If I'm right then you're going to want to add some fluid and that should help it. Basically your tranny is still grabbing the engine a bit at stop and that's what causing the vibrations. So ill say it again; parking brake, turn engine on, put in neutral, and fill tranny till full.
a20ftsloth is offline
post #4 of 20 Old 03-05-2013, 01:27 PM
Scopez
1994 ZJ
What motor? To test worn motor mounts, put the jeep in drive, hold the brake and give it a little gas. Do the same in reverse. If your motor moves any, more than likely bad mounts.
I suggest IronMan4x4fab mounts. I ordered some, but I haven't received them yet. I just heard very good things about them.
94 ZJ Laredo. 5.2 Crate engine. 6in JKS SA Lift. 33in Destination MTs. ARB Front Bumper.
Scopez is offline
post #5 of 20 Old 03-05-2013, 01:30 PM
xcaliber81
My tranny is full and it does it mine is slowly diminishing over time I'm thinking my issue is old dirty injectors or worn mounts more gearing towards the trans mount.
post #6 of 20 Old 03-05-2013, 01:53 PM
CanaanTSA5
The I6 4.0 has 2 mounts. The mounts them selves are easy to replace. The only snag is that you need to lift up your motor to do it.
I am currently dealing with the same kind of vibration issue. When I come to a stop, the front end will shake. Sometimes violently, sometimes just lightly. In my case, I narrowed it down to more than one thing wrong. My transmission wouldn't downshift properly (Gears 2 and 1). The converter lockup valve in the transmission valvebody was sticking.
I put in some Automatic Transmission Treatment fluid and that solved the vibration issue about 75%. I'm assuming that it also needs motor and transmission mounts as well. It's 14 years old and gets the hell beat out of it. Not really what the stock mounts were intended for.
Other than that, you could try cleaning your IAC. That's what's next on my list before I spend the money for mounts.
1998 ZJ 4.0 Stock 225/75R15 General Grabber AT2
191,000mi
CanaanTSA5 is offline
post #7 of 20 Old 03-05-2013, 01:54 PM
biggoofy
If you want to upgrade while you swap check out ironman4x4fab.com. They have motor and trans mounts for all Zj models.
Zack
13 JKU Stock
93 ZJ F/R Long Arms, 4.56 gears
96 ZJ HP44 / 9" (RIP)
biggoofy is offline
post #8 of 20 Old 03-05-2013, 05:29 PM
coralman
USER OF PARTS CATALOGS
coralman's Avatar
I think he was looking for a how to, I wouldn't mind knowing myself.
Originally Posted by HighLonesome
coralman is offline
post #9 of 20 Old 03-05-2013, 06:10 PM
KoreaZJ
1994 ZJ
Replace all three, L/R engine and rear tranny.
Not a ZJ, but similar to this...
KoreaZJ is offline
post #10 of 20 Old 03-05-2013, 08:07 PM
coralman
coralman's Avatar
I was just wondering about the board under the oil pan thing, if it was the accepted method Thanks Korea.
coralman is offline
post #11 of 20 Old 03-05-2013, 10:07 PM
Afdude88
The board idea should be ok. The idea is to distribute the motor weight across the board versus a the smaller area of a jack's head. I have done this before on other vehicles without problems.
1993 Grand Cherokee Limited 4.0L AW-4
1998 Grand Cherokee:
4.0L I6
42RE
242 tc
2.5 OME lift
Afdude88 is offline
post #12 of 20 Old 03-06-2013, 12:49 AM
AVR2
I used the block of wood under the oil pan on my 4.0L. No problem. It's the recommended procedure in Haynes, can't remember what the FSM says.
The driver's side mount is the one where access can be an issue. I've seen people change it as-is, but I took a few minutes to pull the airbox, and voila - plenty of room.
AVR2 is offline
post #13 of 20 Old 03-06-2013, 04:25 AM
coralman
coralman's Avatar
.....and the gear shaft? Some say remove or pry on, nothing in the fsm about that. I was just thinking I would tackle the mounts while doing all the rework on the sus./strg systems.
coralman is offline
post #14 of 20 Old 03-06-2013, 04:37 AM
AVR2
You mean the steering shaft? There's just enough room between it and the frame to get a socket onto the bolts underneath it. That wasn't a problem at all.
AVR2 is offline
post #15 of 20 Old 03-06-2013, 04:44 AM
coralman
coralman's Avatar
Cool, thanks for the replies !
coralman is offline
