Motor loses power when turning left - JeepForum.com
post #1 of 29 Old 11-23-2013, 04:37 AM Thread Starter
Sn0wD
the motor feels like it loses a lot of power almost like cutting out when I take a hard left from a stop and giving it gas... Anyone have any idea what might be going on? Also it has a full tank of gas but does it more often when it's lower on gas close to E
Sn0wD is offline
post #2 of 29 Old 11-23-2013, 04:57 AM
MTBlue
Only thing that comes to my mind is that your fuel pump is going out...
Dirt Deprived
MTBlue is offline
post #3 of 29 Old 11-23-2013, 06:59 AM
johns1mj
Possible wire short caused by body roll?
johns1mj is offline
post #4 of 29 Old 11-23-2013, 07:22 AM
ZeeJay1997
i'll give another vote for fuel pump
ZeeJay1997 is offline
post #5 of 29 Old 11-23-2013, 09:41 AM
PolkaPower
Same thing mine did when the pump was going out.
PolkaPower is offline
post #6 of 29 Old 11-23-2013, 10:15 AM Thread Starter
Sn0wD
Give or take how much longer does it have in y'all's experiences?
Sn0wD is offline
post #7 of 29 Old 11-23-2013, 10:19 AM
ZeeJay1997
don't venture out too far from the house
post #8 of 29 Old 11-23-2013, 10:38 AM
PolkaPower
I drove around for a few months like that. I used to smack the fuel tank with a rubber mallet before I started it up. Eventually it just got to the point where I had to play with the gas pedal while driving straight to keep it going. I replaced it after that. Took a couple hours. It's bad to the motor to run it like that because it's being starved of fuel. This was on my first ZJ. I would never let it get that way on this one.
post #9 of 29 Old 11-23-2013, 11:27 AM
bigbill888
I once had a 95 ZJ and the radio would always die when I turned the steering wheel to the left. Maybe a similar issue? I struggled with it for some time and never found the problem before the Jeep was totalled...
96 ZJ Laredo, 4.0, 242, 230K
95 ZJ Limited, 4.0, 242, 140K
98 XJ Sport, 4.0, 231, 140K
All work well
bigbill888 is offline
post #10 of 29 Old 11-23-2013, 11:37 AM
PolkaPower
Yep the fuel pump in the radio was going south. Every time you turned it would slosh the fuel away from the pump and cause the radio to stall. Especially when the radio was low on gas.
Seriously though the fuel pump is more on the drivers side of the tank. It would make sense that a weak pump would stall when turning left while low since the gas would be slung to the other side.
post #11 of 29 Old 11-23-2013, 12:40 PM
bigbill888
Don't go changing out the fuel pump until you have tested it and have certainty that it is bad. It is expensive, a PITA, and changing it out is somewhat dangerous. "Sounds like a fuel pump" isn't enough.
All work well
post #12 of 29 Old 11-23-2013, 12:42 PM
PolkaPower
It's not dangerous if you are not dumb. It takes about an hour but it is not cheap. If it's your first time it will take longer. Just make sure you are very low on fuel. Switch the relays around to see if that may be the issue.
post #13 of 29 Old 11-23-2013, 12:47 PM
ZeeJay1997
49 psi plus or minus 5 at all throttle ranges.
post #14 of 29 Old 11-23-2013, 12:50 PM Thread Starter
Sn0wD
I'm all about narrowing down my options... How would I go by testing it?
Sn0wD is offline
post #15 of 29 Old 11-23-2013, 01:04 PM
ZeeJay1997
find a parts store that has loaner tools. there's a port on the fuel rail. screw it on, crank it up, jab the throttle, watch the gauge.
