More ZJ Problems...Surprise? NO! - JeepForum.com
post #1 of 14 Old 06-03-2013, 06:00 PM Thread Starter
zRoxxah
So I've been having some funky oil gauge activity. It drops to 20 in idle and goes back to 40 when giving it some skinny pedal. I posted a thread about this and someone says its normal...even though I've never noticed this while driving her. I figured it has something to do with the small oil leak..maybe.
Anyways I just spent some time under her (love it down there) and I noticed the leaks were coming from the tranny pan and the North end of the transmission where there's some sort of 1mm thick metal plate(what's this for?)..its missing 1 bolt. Although the drippings on the ground were oily and golden brown..not runny and red ( ) like tranny fluid. Also I did my pan gasket a month ago and stopped most of the leaking and I checked if the seal was compromised and its fine..still gotta do valve cover & oil filter adapter.
I'm stumped as what to do next besides replace the o-rings on the filter adapter and drop my tranny pan and do that gasket.
Suggestions please!?
It's 102 degrees outside so I'm gonna go have a cigarette, a brew and admire my baby I hope this thread helps someone else...btw has there ever been a non-leaking ZJ?
Matte Black '96 ZJ 4.0
IRO 3.5" Benchmark Lift, Bilstein 5100's, 31x10.5x15 Westlake SL369 A/T's, Moog Super Trail Boss SS, KOR Rad Support, Chopped-up Front Bumper
zRoxxah is offline
post #2 of 14 Old 06-03-2013, 06:26 PM
dylantheheeler
Well if its not trans fluid it's not going to have anything to do with the transmission pan gasket. If you're talking about what I think you're referring to, that is the inspection plate, used to inspect the flexplate on the transmission. Usually it is the rear main seal, but can be as simple as the valve cover gasket leaking on the back side of the engine, or an oil pan gasket leak.
Sent from AutoGuide.com Free App
yo vivo. yo voy. yo soy. Jeep.
I live. I ride. I am. Jeep.
dylantheheeler is offline
post #3 of 14 Old 06-03-2013, 06:33 PM Thread Starter
zRoxxah
Yes that's exactly what it is...just looked it up. Well I guess I should do my valve cover gasket and see what happens since my pan gasket isn't leaking. It could be the rear main seal since I believe that was the thing I forgot to put back on when I had my pan back up. I just said **** it...it's a hemisphere shaped bracket thing right?
zRoxxah is offline
post #4 of 14 Old 06-03-2013, 06:52 PM
dylantheheeler
Not a bracket, rather a 2 piece seal. Looks like this:
If that seal is removed completely, I would think you would have a larger leak.
In regards to your question about the oil pressure fluctuating, I'm 99% sure it is normal for a high mileage engine. If it bothers you, you could try running 1/3 of a can of seafoam in the oil a few hundred miles before an oil change. The oil pump pickup screen could be partially gummed up.
post #5 of 14 Old 06-03-2013, 07:15 PM
tucsonzj
since you got the leak figured out i'll leave that be, i didn't know anyways. and the oil pressure change is normal. As in that's how it should be. I know when mine gets low on oil my pressure stays pinned higher lol. Just a way I know my zj. Essentially it equals out to be around 10psi for 1000rpms. Now mine never gets quite down to 10 even at idle and that's fine.
And no there has never been a non-leaking ZJ. I'm convinced they came off the factory line like this lol.
His:00 TJ "Fiona" stuff/stuff/stuff
95 ZJ 3.5" w/242 swap-Sold
Hers: 15 JK Sahara-3" Teraflex
tucsonzj is offline
post #6 of 14 Old 06-03-2013, 07:53 PM
ZeeJay1997
oil leaking from the filter adapter looks like a rear seal leak when you're under there.
ZeeJay1997 is offline
post #7 of 14 Old 06-03-2013, 09:02 PM Thread Starter
zRoxxah
this^
I'll do my valve cover and filter adapter ASAP and see if that solves anything. As for the rear main seal, I used high temp RTV all around for the gasket so there was no piece completing the upper hemisphere...is that about to be a major PITA?
zRoxxah is offline
post #8 of 14 Old 06-03-2013, 09:04 PM
StPaul59
Im betting on the valve cover leaking. When you change that, put rtv on the bolts and clean the top of the cover real well where the bolt tightens up. Thats where my leak is right now.
StPaul59 is offline
post #9 of 14 Old 06-03-2013, 09:07 PM
dylantheheeler
I would grab a rear main seal and be prepared to pull that oil pan off again to replace it. Do a search here for replacement instructions. While you're in there it'll give you a chance to take a look at that oil pump pickup screen.
post #10 of 14 Old 06-03-2013, 09:27 PM
AveryZJ
This is of no help but my ZJ hasn't leaked once.
AveryZJ is offline
post #11 of 14 Old 06-03-2013, 09:51 PM
Oldfrog
2007 WK
It's out of oil.
2007 5.7 Hemi, Ltd. QD II -
1997 ZJ, 4,0 select trac, Up country, track lok.
Oldfrog is offline
post #12 of 14 Old 06-03-2013, 09:54 PM
StPaul59
Put some amsoil in it. Then we'll see!
StPaul59 is offline
post #13 of 14 Old 06-03-2013, 10:00 PM Thread Starter
zRoxxah
I'll def do the valve cover now that I got a deep socket kit. Ugh pulling my oil pan was such an ordeal atleast I checked the screen while I was at it. It was all good.
Thanks for the help guys
I call bull****!!!
zRoxxah is offline
post #14 of 14 Old 06-04-2013, 12:15 AM
eagsc7
1994 ZJ
Yeah... that was me that posted it's normal...4 Jeeps with 4.0 engines, and it's done that to all of them...
Of course, they all had the "normal" ZJ leaks that they're famous for. I'm in process of doing the seals to TRY and fix the leaks.
I KNOW that both of our current ones have the Oil Filter adapter leak. I'll also be dropping the lower pan if I see a leak when I take it to get a new tranny *when it comes in*
eagsc7 is offline
