#1 | |
more power
well, after driving around on a 190 horses im ready for more. torque is actually what i would prefer gaining considering an increase in torque wont hurt gas mileage as much and it's easier on an engine than horsepower. anyway, im thinking about getting a new exuast pipe, and a chip of some sort, possibly a new intake too, so the extra power doesnt heat my engine to death. just wondering what you guys would recommend for some power boosts. guess it would be helpfull to mention that i have a 95 gcl with the standard I6.
Last edited by oreoandstuff; 05-09-2009 at 03:03 AM.. Reason: not specific enough information |
#2 |
5.9 Addict
Biggest cost effective power boost on a 4.0 will come from stroking it. Things like exhaust, intake, etc will give some, but not a lot. Others will have input on chips.
#3 |
swap it with a 5.2, i love my 5.2
#4 | |
zj tractor
i think he wants to keep his I-6.
more power, stick with the basics.. put more air in, and let more out. and add more fuel
hard working private first class in the United States Marine Corps. Quote:
build thread:http://www.jeepforum.com/forum/f197/5-9-andys-1-ton-zj-build-american-standard-1056365/ |
#5 |
Living dead mod
stroker, cam, 99+ intake manifold, exhaust.bored tb, that's about it.
'97 zj 5.2, some stuff, some other suff, and some things that even work sometimes. |
#6 |
well now i feel like a total idiot but whats a stroker?
#7 |
if you dont know what it is then it will be over your head. Not tring to be offensive. But its when you put a crank in there that allows your pistons to travel longer distances. It allows the stroke to be greated. Being a stroker. You usually add bigger pistons along with this combo.
1996 5.2 orvis: 6" lift, 33x12.50's, 8.8 rear, t-case skid, gas tank skid, 242 LOOKING FOR 96-98 ZJ CARPET, TAN OR BLACK IN COLOR, ALSO LOOKING FOR HOOD HINGES. 93-95 MIGHT BE COMPATIBLE |
#8 |
http://www.jeep4.0performance.4mg.com/stroker.html
http://www.performancedistributors.com/jeep.htm http://www.avengersuperchargers.com/ this should help you out.
96' JGC V-8 5.2L ltd. way too much to list. Thought for the day: If GOD gave HIS only son for us...can't we at least give HIM an hour of our time a day. [URL]http://photobucket.com/albums/v639/nashmd454[/URL] [url]http://groups.jeepforum.com/The_Dark_Side[/url] |
#9 |
Transfer Case Guru
Best bang for your bucks would be a cam with supporting mods, hands down. You can get a mild cam from Comp Cams for under $150. A port and polish on your head, WJ intake manifold, bored throttle body, header, high flow cat, and a new muffler should net you 50+ HP.
Want to swap an NP242 or NP231 into your ZJ? Here's how: http://www.jeepforum.com/forum/f13/np249-np231-np242-swap-information-updated-685644/ |
#10 |
I've done the basic bolt on mods on my 04 4.0. 2.5 Cat and Back exhaust, FIPK, and 63mm TB. Overwhelming increase...no...noticeable....yes. Also, although they may be pricey, installing gears will get you the bottom end power you are looking for, at a sacrifice of mileage (unless you are lifted as gears would put you back near stock final gear ratio.
LET'S GO PSU 04 WJ Laredo I6 5.5" IRO CP 32" BFG M/Ts on JK 17's -Devin |
#11 |
the spark plug/distrubuter combo seems to be a good idea. how much of an increase am i looking at if i did that? anyone know? also how complicated to would it be to actually install a stroker kit? and what is my mileage looking like after thats said and done?
#12 |
Jeep Jedi Master
Gears,
swap from those 3.55s to 4.10s or 4.56s and just move out. Hunter
94 5.9 Laredo 6.5 RE lift with 35 Maxxis Bighorns and 33 Bridgestone Duelers Detroit and true trac Red Jeep Club Member REDNECK JCM Texas Jeep Owner #6 USN Jeep Club #4 http://www.kevinsoffroad.com/ 602.841.3355 For your performance needs: kolak@kolakperformance.com 480.998.3661 |
#13 |
Jeep Jedi Master
I think you missed Andy's post. To get more hp, you need more air, more fuel and a way to expel it. Just one simple part like a distributor or new plugs will not work. If you haven't changed your plugs and wires, distributor in the life of your Grand, you will feel a better response but not the 10 to 20 HP you're looking for.
Hunter
#14 |
ok. so plugs arent a good idea. what kind of camshaft should i be looking for?
#15 | ||
Brian 95 ZJ, 5.2 V8,160,000 miles Colorado Jeep Club member Pi Quote:
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
