More Information On Stalling Problem - JeepForum.com
post #1 of 3 Old 03-11-2004, 07:34 PM Thread Starter
phjohnso
I replaced the coil tonight on the 95 gc and still it would not start. I manually turned the throttle by hand and my son turned it over and it started up then stalled out - I went out and replaced the tps and got the jeep started. I warmed it up and took it for a drive.
The jeep tried to stall out a few times, the idle dipped low and recovered a few times. If I left it parked and raced it a bit the jeep would try to stall out and sometimes did. Would this now point to the IAC as the next item that may need replacing???
phjohnso is offline
post #2 of 3 Old 03-11-2004, 08:02 PM
BeachinXJ
Resident McGeek
BeachinXJ's Avatar
Could be your MAP sensors. Could also be the Crankshaft position sensor.. the CPS. CHeck that as well...
- Chopped / Locked
- Daily Driver
2003 Dodge Ram 2500 CTD - 6-speed, 4" MBRP Turbo Back Exhaust
Rule #1 - No talking about the weather!
BeachinXJ is offline
post #3 of 3 Old 03-12-2004, 07:01 AM
greasefingers
greasefingers's Avatar
1994 ZJ
Check the delivery pressure of the fuel pump on the rail.
Cheers Steve
94 Black Laredo 4-Liter with QuadraTrac (42RE trans & NP249 TC) 200,000 + miles purchased new
88 Cherokee 2-door with 5speed manual 139K miles(deceased) purchased new
greasefingers is offline
05 4.7L another stalling problem kmartin96 WK Grand Cherokee & XK Commander Forum 6 09-14-2009 03:34 PM
Another Stalling Problem, '05 4.7 WK. Rish WK Grand Cherokee & XK Commander Forum 3 08-04-2009 09:02 AM
Stalling problem with 97 ZJ kontrast ZJ Grand Cherokee Forum 9 05-14-2009 04:45 PM
Problem with Vehicle Information Center Schlotz ZJ Grand Cherokee Forum 5 10-13-2008 09:08 PM
96 GC Vehicle Information Center Problem jetdude ZJ Grand Cherokee Forum 6 09-24-2006 12:30 AM
