MORE electrical problems - JeepForum.com
post #1 of 6 Old 12-22-2002, 09:59 PM Thread Starter
JeepGuyRyan
Jeeps are great vehicles for all around use, but suck when it comes to electrical problems!
1994 Grand Cherokee Limited 5.2 V-8 103,000 miles
Problem: The Radio resets everytime the car is turned off so I loose the station presets and the time. Also the Vehicle Display thing below the radio resets as well resting the time and such, any suggestions?
-=Ryan=-
JeepGuyRyan is offline
post #2 of 6 Old 12-23-2002, 12:32 AM
moabster
moabster's Avatar
2011 WK
There are 4 power feeds that go to the radio. It sounds like the one that supplies constant power to keep the memory alive has blown a fuse. These are the four power feeds:
1. Switched to supply power when the ignition is in the ON position or the ACC position. (This appears to be OK if the radio works when the car is running)
2. A power feed that connects to the parking lights and dimmer circuit. (You can check this by turning on the park lights and see if the light in the radio comes on. This should work without turning on the jeep.)
3. A circuit that goes through Fuse #1 (by the battery) and then Fuse #8 (probably in the fuse panel that is accessable when the passenger front door is open.) Check to see if these fuses are OK. If the power locks work, this circuit is probably OK.
4. I can't find the fuse source for the 4th circuit in my wiring diagram but it is connected to the same source as the courtesy lamp switch. Again check the fuses by the passenger door.
I hope this helps you track down your problem.
Good Luck
2000 Jeep Grand Cherokee V8 Stock
93 YJ I6 hard top (really belongs to SPEED)
RE 4.5" Extreme Duty Lift, Advanced Adapters SYE, Tom Woods CV Drive Shaft, EA589 10" rims with 33" x 12.5" MT/Rs
Bullet Proof Front and Rear Bumpers and Tow bar
moabster is offline
post #3 of 6 Old 12-23-2002, 01:41 PM
MJR
MJR's Avatar
1988
Your battery is going dead and needs to be replaced. When the battery voltage drops below 8 volts when you crank the engine over this resets everything. Rarely do most people notice the slower cranking on the V-8s.
"Got Groceries"
88 Jeep Wagoneer
MJR is offline
post #4 of 6 Old 12-23-2002, 10:21 PM Thread Starter
JeepGuyRyan
Thanks for all the info guys, much appreciated.
It has a fairly new battery (about a year old) but it has been cranking slowly, thing is, I took it up to Autozone and they checked the battery and the alternator and said both were fine. But it suffers from the slow crank problem now as well (started doing it suddenly a few weeks ago) this radio memory problem has been occuring for the past 2 years my brother has owned this jeep. Thanks again for the info,
Ryan
-=Ryan=-
post #5 of 6 Old 12-24-2002, 04:40 AM
Slightly_Off
I assume its an aftermarket radio, There is a wire that supplys 12 volts constantly to the head unit. and another 12 volt line from the acc swich, it could be that when the radio was installed they did not hook up the constant 12 volt connection and just used the acc connection and that would cause the loss of memory for the radio.try to find a wireing diagram for your radio and take a votage meter and find the acc line and the constang 12 volt line, if you find both and both work like they should...well....there goes my theory.
1993 Mustang 5.0L LX special edition (for sale) white white white vert
1993 ZJ 4.0L
Slightly_Off is offline
post #6 of 6 Old 12-26-2002, 10:26 PM Thread Starter
JeepGuyRyan
No, it's the factory stock AM/FM/Cassette
-=Ryan=-
Electrical Problems on 99 WJ superarmen ZJ Grand Cherokee Forum 10 06-24-2009 07:08 AM
Electrical Problems (I think) bost1217 ZJ Grand Cherokee Forum 7 10-02-2006 08:35 AM
Electrical problems!!! BOBBYBARLOW ZJ Grand Cherokee Forum 0 06-26-2006 06:11 PM
more problems (electrical) tbone31 ZJ Grand Cherokee Forum 19 11-14-2004 11:19 PM
Electrical Problems need some help. iroc22 ZJ Grand Cherokee Forum 16 11-30-2003 08:21 PM
