More A/C trouble - JeepForum.com
post #1 of 5 Old 04-06-2009, 09:12 AM Thread Starter
rflem550
More A/C trouble
2002 V8, dual-climate control.
I had my heater core replaced in December and while they had the dash out, I had them replace the evap core, blend door actuators, etc b/c my A/C was not working last summer. So they charged the system and it lasted only a couple of weeks. Took it back in February and they said my compressor was bad, so they replaced my compressor. At this point, I've got about $2,000 invested in all this work.
Now the A/C is not cooling. It feels cool when it's cool/cold outside, but when it gets in the upper 60's and into the 70s and close to 80, it does not feel cool at all.
Any ideas?
rflem550 is offline
post #2 of 5 Old 04-06-2009, 10:33 AM
ChvyKc
2006 XK Commander
I had this problem with my wife's Liberty. It ended up having a small hole on the back side of the condenser. The AC place that I took it to was able to put in some type of die and tell me exactly where the leak was. They wanted 600 bucks for a new condenser and labor but I did it myself for 225 (condenser and coolant).
-ChvyKc
'06 XK 3.7L (Stock for now)
'07 WK HEMI Limited (Wife's)
ChvyKc is offline
post #3 of 5 Old 04-06-2009, 02:47 PM
CaseyC
1994 ZJ
I bought a kit at O'Reilly's. Consisted of a can of "flourescent" dye, a small charging hose and a small flashlight about the size of a fountain pen. Load the can of dye into the system and charge it up to specs. Once it stops cooling, go over the system with the flashlight. Any leaks will show up bright yellow.......
CaseyC is offline
post #4 of 5 Old 04-06-2009, 07:22 PM Thread Starter
rflem550
I thought that's what I was paying the shop to do the first two times.
rflem550 is offline
post #5 of 5 Old 05-07-2009, 11:46 AM
kendalyn07183
Was it easy to replace? I was quotes $1,000 to replace the condensor on my 2002 WJ LTD.
kendalyn07183 is offline
RPM Trouble whasz ZJ Grand Cherokee Forum 11 07-04-2008 04:58 PM
need help! a big trouble ruddyr ZJ Grand Cherokee Forum 5 12-04-2007 02:27 PM
ABS trouble ajmorell ZJ Grand Cherokee Forum 11 12-09-2006 01:55 PM
trans trouble started as 249 trouble GCJeeper1993 ZJ Grand Cherokee Forum 1 08-30-2006 03:13 PM
