Moog DS1235 track bar questions - JeepForum.com
 2Likes
post #1 of 25 Old 06-25-2011, 01:40 PM Thread Starter
Calypsokev
I have a stock 97 ZJ with no lift. I just installed a Moog DS1235 track bar because I thought this was a direct stock replacement. I'm replacing the track bar and steering stabilizer due to death wobble, and this track bar has helped cure it, but I have had a couple issues with it.
After installing, my steering wheel is off center by an 1/8 turn and my axle moved 3/8" towards the driver's side. Since this track bar is NOT adjustable, I cannot get the axle centered.
Questions:
1. Since my alignment feels find (no drifting left or right), should I just adjust the steering wheel and be done?
2. With the axle being slightly off, will this mess up future alignments?
3. Should I get another track bar? The Moog seems to not be the correct length. I'm tempted to just buy stock, since most of the adjustable track bars are only if your jeep is lifted.
Thanks in advance for any help,
Kevin
Calypsokev is offline
post #2 of 25 Old 06-25-2011, 05:26 PM Thread Starter
Calypsokev
I think I know what might be going on.
A couple years ago I installed the yellow Bilstein struts for a stock (0" lift) ZJ. Although these are stock shock replacements, they lifted my jeep up a little. I never measured where the axle was after installing the shocks.
From what I have read in the forums, when you lift a jeep without an adjustable track bar, it moves the axle towards the drivers side. My jeep is 3/16" towards the drivers side.
I haven't read about anyone having trouble with the Moob DS1235 track bar, so I'm going to assume it's my jeep being slightly lifted by the shocks. Unfortunately, it's not enough to warrant an adjustable track bar.
Unless anyone believes there is a danger or reason not to drive with the axle 3/16" off center, I'm going to just adjust my steering wheel to center and be done.
Thanks to anyone who feels they could chime in with useful information.
Thanks,
Kevin
post #3 of 25 Old 06-25-2011, 08:44 PM
TallyZJ
What is the exact method you are using to measure the axle for center? Are you using the edges of the tires for reference? If so, that won't be exact. You would need to find exact center of the jeep frame/chassis and then find exact center of your axle and measure the difference.
1996 Jeep Grand Cherokee Laredo 4x4 - 4.0L
TallyZJ is offline
post #4 of 25 Old 06-25-2011, 09:16 PM
blackjack12982
1994 ZJ
Thanks,
Kevin
Did you really mean to say that after you installed your shocks your vehicle was lifted?
Shocks don't lift a vehicle at all...
blackjack12982 is offline
post #5 of 25 Old 06-25-2011, 09:37 PM Thread Starter
Calypsokev
There is a hole on the frame just behind the track bar bracket, and a hole in the exact place on the frame on the passenger side. I was measuring from there to the wheel rim. I found a 3/16" difference.
I also marked the center of the frame and hung a string and marked the center of the axle and hung a string. I then looked from the center marked at of front of the jeep to see if the strings lined up. They appeared to be off a little more then the 3/16" measurement.
When I lowered the axle end of the track bar and aligned the axle, I could not reinstall the track bar since it's not adjustable. I thought the Moog DS1235 was supposed to be a direct stock replacement.
What tipped me off something might not be right is the steering wheel was off center after the install.
Nevertheless, the Moog track bar is now installed, the axle is slightly off, and the death wobble is gone(except on one bump coming out of Boston where it appears for just a second, then goes away. Much better then before.). I wouldn't mind getting a different track bar that allows me to align the axle, but the JKS is for 1"-6" lift, Kevin's Offroad would hit the differential with no lift, and every other one seems to require lift. The Moog track bar I bought is still returnable.
Is it possible my track bar is faulty? Is there another direct stock replacement besides the moog that you recommend? Am I doing something wrong?
Thanks for responding,
Kevin
post #6 of 25 Old 06-25-2011, 09:41 PM Thread Starter
Calypsokev
Good to know. When I went from the stock shocks to the Bilstein, it seemed as if the vehicle sat higher. I must have been mistaken. I never measured before or after.
So if my ZJ is not lifted at all, when I install what should be a stock replacement non-adjustable track bar, the axle should automatically be centered?
When I put the Moog DS1235 track bar in, the steering wheel moved off-center, and the axle appears to be off by about 3/16". Try another track bar?
post #7 of 25 Old 06-26-2011, 06:42 AM
sebian
If it is off by 3/16", I would guess that is because the bushings in the old trackbar were worn down, causing the difference. I had the same problem when I swapped mine, old trackbar pretty much dropped right out, and I had to do a little finagling to get the new one installed since it had new bushings. Get an alignment and you should be good.
Timmyh13 likes this.
1995 ZJ 5.2L V8 318. 230,000 miles and still rollin.
List of parts not replaced yet:
sebian is offline
post #8 of 25 Old 06-26-2011, 08:42 AM
JrMechanic
Don't bother with an alignment, just adjust the sleeve on your drag link 1/2 turn to align the steering wheel. Might take a few tries to get it exactly right however.
Although I don't like Moog ball joints, the track bar they make for our Jeeps is the best stock replacement you can buy. I first purchased a house brand track bar for $50 with a lifetime warranty... Within 9 months the bushing was worn out, so rather than having it go bad again I spent the $12 for a poly bushing. 3 months later the joint end developed play, so I returned it for the Moog. I did have the same problem you encountered, but 3/16" is miniscule, your window for error when measuring is larger than that.
Want to swap an NP242 or NP231 into your ZJ? Here's how:
JrMechanic is offline
post #9 of 25 Old 06-26-2011, 09:00 AM
AlphaLorde
If the front axle is shifted to the passenger side. I would lift it a little, like some 2.25" spacers, that should bring it back to square.
When you are lifting the front it shifts toward the driver and when the rear is lifted it goes to the passenger side.
1998 ZJ Laredo 5.2L 139k 231 w/SYE artec trussed 8.8 4.25"F/5"R lift
AlphaLorde is offline
post #10 of 25 Old 06-26-2011, 09:56 AM Thread Starter
Calypsokev
Your experience sounds like the most likely scenerio. Thanks for sharing. My old trackbar appears to be original. With 150k miles, the bushings are most likely worn down.
I checked the alignment. My tow-in seems to be at 1/8" and drives as well as it did before, so I'll take JrMechanic's advice and just adjust the sleeve on the drag link.
Thanks!
Kevin
post #11 of 25 Old 06-26-2011, 10:09 AM Thread Starter
Calypsokev
Since my alxe is shifted towards the driver's side, I guess lifting the back would bring the axle back to the center.
If I put 2.25" spacers in the back, then I would need spacers for the shocks too. I see where this would lead! This would be the beginning of my lift addiction. I would then want to get all new springs all around and lift to 3.5-4 inches with 35" wheels = new control arms, adjustable track bar, new front bumper with a winch! Ut-oh, my winter vehicle would take on a whole new life, all because my axle was off 3/16"!
post #12 of 25 Old 06-26-2011, 10:16 AM
newfieZJ
I haven't read about anyone having trouble with the Moog DS1235 track bar,
http://www.jeepforum.com/forum/f197/...to-wth-821786/
There's a little discussion on the topic
newfieZJ is offline
post #13 of 25 Old 06-26-2011, 11:53 AM
AlphaLorde
Since your already shifted to the driver side, the lift idea will not work. Once lifted, it will shift the axle more to driver side. Ignore my idea from before.
post #14 of 25 Old 06-26-2011, 06:19 PM Thread Starter
Calypsokev
Thanks for the link newfieZJ. I read your thread. The Moog part I got was from the "Problem Solver" line. It has the Moog name ingraved on the part. It's a solid looking piece. Sorry to read about your nightmare with RockAuto. I bought several items from them when I lived in California without a problem.
Kevin
post #15 of 25 Old 08-19-2015, 10:53 AM
tek610
Same problem here
I know I'm reviving an old thread, but there isn't much out there on this subject.
I replaced the track bar on my stock-height 2000 Classic with a Moog Problem Solver D1235, and it was too long. Once I got it installed, my axle was shifted to the passenger side and my steering wheel was off center. I straightened it up and drove it for a day, but I heard a rub under there somewhere, and so I swapped it with a slightly less beefy stock replacement from O'Reilly's. Comparing the two side-by-side, the Moog was visibly longer. Weird. The stock replacement had the same part number- it fits, and my alignment is restored. I'm about to have new tires mounted, and I want her tracking straight.
Note- the bushing on the old bar was not super-worn. Certainly not worn enough to explain the difference in length. My passenger wheel was noticeably beyond the plane of the fender flare.
Has anyone else experienced this? No lift- the Moog might be fine with a 1 or 1.5" lift, but not stock height. As it is non-adjustable, what use is it?
Also, 1 Moog DS1235 Problem Solver Track Bar for sale. Little use, pre-greased.
tek610 is offline
alignment , axle , death wobble , moog , trackbar
moog track bar bushings 93ZJDave ZJ Grand Cherokee Forum 8 04-22-2010 01:22 PM
moog ss jamnjeep ZJ Grand Cherokee Forum 5 07-08-2009 09:36 PM
MOOG TRE & KOR Jamb Nuts-HELP!!!!! FlipFlop425 ZJ Grand Cherokee Forum 0 11-16-2008 10:39 AM
Do I really need MOOG TREs? JeepOrvis97 ZJ Grand Cherokee Forum 25 10-01-2008 12:45 PM
Moog tie rod ends gorman ZJ Grand Cherokee Forum 11 02-27-2008 02:16 PM
