Mom's WJ Rotor Removal - JeepForum.com
post #1 of 20 Old 03-13-2007, 01:04 PM Thread Starter
Bloodbath
Bloodbath's Avatar
So I am changing my mothers WJ's front rotors. I have the caliper off and have been beating on it a little. Then I noticed it isn't attached like my ZJ's rotor. Do I need to remove the cotter pin and that huge nut in the center to get the rotor off? I am going to go have a few beers and wait for an answer
-Bill
1998 Red Grand Cherokee Laredo
6" Lift - 32 x 11.5 BFG MT's - K&N FIPK - MSD Ignition with Magnecore wires - JKS Control Arms, Trackbars and QD's - Addco Front Swaybar - Intake Swap - U-turn Steering Conversion
Bloodbath is offline
post #2 of 20 Old 03-13-2007, 01:12 PM
nierace
nierace's Avatar
2003 WJ
No!
Soak it with wd40/pb blaster and get a mallet smack it till it comes off.
Nickerdoodle
03 WJ 4.7 242HD Kolak/IRO 5" Clayton LA's
35" BFGoodrich KM2
North East Offroad Club
nierace is offline
post #3 of 20 Old 03-13-2007, 01:14 PM
rrubio
rrubio's Avatar
Having a few beers always helps.So your on the right path.The only thing to do is what Nick mentioned is to beat it till it comes off.I had to just about bust my driver side off when I changed out my rotors.
rrubio is offline
post #4 of 20 Old 03-13-2007, 01:18 PM
nierace
nierace's Avatar
2003 WJ
You beat it till it came off ?
Nickerdoodle
35" BFGoodrich KM2
nierace is offline
post #5 of 20 Old 03-13-2007, 01:20 PM
rrubio
rrubio's Avatar
There you go another gay comment
rrubio is offline
post #6 of 20 Old 03-13-2007, 01:22 PM
ArloGuthroJeep
Mr. Hyde!
ArloGuthroJeep's Avatar
The cotter pin & big nut you're referring to holds the axle shaft to the hub/wheel bearing assembly. No need to remove it.
'14 WK2 Limited w/5.7L, ORAI, & Tow Package
ArloGuthroJeep is offline
post #7 of 20 Old 03-13-2007, 01:24 PM
Ds4x4
Ds4x4's Avatar
you really gunna have to go to GSW Nierace so you two can shake hands.. or what ever you want to do..
1996 ZJ Orvis Edition,V8 5.2L
Tow & Skid Package, FM 40,44a - 3.73, NP249
265/75/16 Destination M/T's, JKS Discos, UC; Dual Intake;Red Top;
OME Stab.; Rustys 2" BB + shocks, xtreme hi-lift, Kennesaw Rear MultiCarrier
Proud To Be A FF/EMT/Police/Military Club Member #15
Ds4x4 is offline
post #8 of 20 Old 03-13-2007, 01:26 PM
ArloGuthroJeep
Mr. Hyde!
Think you'll have to get the OK from Ramon's wife...err, or maybe she is into that kinda thing?
post #9 of 20 Old 03-13-2007, 01:43 PM
Ds4x4
Ds4x4's Avatar
In today's world anythings possible... you guys better figure out who's the pitcher and who's the catcher...
Back on topic before someone gets banned.... How bout' them Yankee's??
Ds4x4 is offline
post #10 of 20 Old 03-13-2007, 02:00 PM
nierace
nierace's Avatar
2003 WJ
I don't know what you perverts were talking about, but me and Ramon were talking about the rotor.
Nickerdoodle
35" BFGoodrich KM2
nierace is offline
post #11 of 20 Old 03-13-2007, 03:26 PM
rrubio
rrubio's Avatar
These people Nick.Always thinking bad..Back to the subject before I get banned for life
Just keep tapping or hitting it really hard like I had to do.It will bust loose eventually..
rrubio is offline
post #12 of 20 Old 03-13-2007, 03:38 PM
zaq123
zaq123's Avatar
1941 JK Wrangler
smack it hard
zaq123 is offline
post #13 of 20 Old 03-13-2007, 04:28 PM
walter_da_jpr
4.0 Piston Skirt Victim
walter_da_jpr's Avatar
It may take a long while to smack it. I always get to the point of about giving up, then after a few more minutes of pounding and spraying they always pop off.
Time for the BFH.
WALTER
walter_da_jpr is offline
post #14 of 20 Old 03-13-2007, 06:05 PM
Chloetar
Hope this isn't a dumb question for you, but did you alsop remove the caliper retaining braket? Might remind me of the time I worked on a Subaru, the piston twisted in, didn't realize that right away, thought I needed a bigger clamp!
Anyhow, if you did remove the braket...beat away!
'00 GC Laredo 4.7 / FM Delta Flow 40 Series / K&N Drop in /Rancho 5000's and Steering Stabilizer / Uniden 68LTW CB w/4' FS II
Chloetar is offline
post #15 of 20 Old 03-14-2007, 10:23 PM Thread Starter
Bloodbath
Bloodbath's Avatar
Yeah, I removed everything. After chugging a few more beers things became clear that I just needed a bigger rubber mallet. 2 big whacks on each one and they flew off. I couldn't believe the amount of rust falling from between the two surfaces of the rotors Thanks everyone for the help.
-Bill
Rear Rotor Removal help CarFanatic ZJ Grand Cherokee Forum 25 05-07-2013 05:17 PM
Front/Rear Brake Rotor Removal AngryDog ZJ Grand Cherokee Forum 9 10-29-2009 08:39 AM
Rear rotor removal on a 99 Grand Cherokee dirtyjeepdc ZJ Grand Cherokee Forum 5 05-08-2009 12:08 PM
Rear rotor removal mmgrand ZJ Grand Cherokee Forum 8 10-24-2006 04:41 PM
Cap and Rotor Removal for 95 Grand Cherokee... G4teamG ZJ Grand Cherokee Forum 12 06-27-2005 05:24 PM
