mods from junkyard - JeepForum.com
post #1 of 12 Old 04-26-2007, 06:14 PM Thread Starter
BustedZJ
mods from junkyard
thinking about doing some stuff, and some new parts and some used.
trans cooler - new - what size to get? 7.5"x15" good for normal stuff and some towing??
electric fan - used, found one on a zj.... did they come available from the dealer on some years?? if not what year taurus should i look for
intake manifold - used - 99+ swap - is it worth it, and how much trouble?
also gonna prob get a new exhaust from the cat back, because i got a new cat on the recall from DC. should i go a 1/4" bigger or 1/2"??
1996 ZJ 4.0L - traded
1972 CJ5 304 - sold
1999 WJ 4.0L - current dd
BustedZJ is offline
post #2 of 12 Old 04-26-2007, 06:17 PM
ajmorell
ajmorell's Avatar
I plan on swapping the intake manifold over the summer, its slightly labor intensive, but it's supposed to provide some good gains.
ajmorell is offline
post #3 of 12 Old 04-26-2007, 07:25 PM
FPKites
ZJjazzyJim
FPKites's Avatar
If you found an electric fan, it was probably a 98 5-niner.
Cooler that size should be fine. Pretty sure that's what mine is.
Jim Karlin
"Duh! Big RED Jeep!!!"
or
96 ZJ Laredo
5" lift, Claytons, KOR radiator support, rear bumper, steering brace, etc, etc, etc.
04 WJ Overland
Clean.... :D
FPKites is offline
post #4 of 12 Old 04-27-2007, 06:52 AM
anticrombie
anticrombie's Avatar
I wouldn't buy a used cooler. They aren't that expensive, just buy a new one.
Charlie
anticrombie is offline
post #5 of 12 Old 04-27-2007, 07:42 AM
FPKites
ZJjazzyJim
FPKites's Avatar
You're probably right Charlie - I noticed he put New next to that in his list, so figured it'd be safe.
Jim Karlin
or
96 ZJ Laredo
04 WJ Overland
Clean.... :D
FPKites is offline
post #6 of 12 Old 04-27-2007, 07:47 AM
cj7guy
Anyone else have comments on this?
I'm thinking of throwing on an exhaust manifold and a 99+ intake at the same time on the 96 ZJ.
07 JKU - 6spd - LSD rear
cj7guy is offline
post #7 of 12 Old 04-27-2007, 08:04 AM
ajmorell
ajmorell's Avatar
That would be a good plan, I have an aftermarket header, but if I had to do it again I would have done both at the same time. It is really straighforward, just takes some time to do (~4-5 hrs, maybe less if you've done it before)
ajmorell is offline
post #8 of 12 Old 04-27-2007, 12:01 PM
Texas ZJ1
Jeep Jedi Master
Texas ZJ1's Avatar
1994 ZJ
Grab the skids off a junker. cheap and after a fresh coat of paint....brand new!
Hunter
04 4.7 HO, limited
04 4.7 HO, Overland
08 Z71 Suburban, front leveling kit with rear spacers. 285/65 18s Nitto TerraGrappler G2s
94 5.9 Laredo 6.5 RE lift with 35 Maxxis Bighorns
and 33 Bridgestone Duelers
Detroit and true trac
Red Jeep Club Member
REDNECK JCM
Texas Jeep Owner #6
USN Jeep Club #4
602.841.3355
For your performance needs:
480.998.366
Texas ZJ1 is offline
post #9 of 12 Old 04-27-2007, 04:37 PM
jfowlzj95
Hunter
Got all 3 for $35.
95 zj with some big n heavy crap!
jfowlzj95 is offline
post #10 of 12 Old 04-27-2007, 05:11 PM
legend6009
legend6009's Avatar
i have personally did my intake manifold...and it was pretty much straight forward....mine took awhile because i also had my buddy weld my exhaust manifold and that was the b*tch part of it. if you do the intake swap grab the injectors too, and youll have to get the wires for them, i suppose you could just use yours if you dont want to switch the harness. i just decided to switch them over to the new style. another thing is the vacuum lines you'll have to run them different, so make sure you get the lines also. and get a throttle body gasket cause im sure you will need break it like how i did.
so you will need:
tb gasket
vacuum lines
the intake
injectors off that intake
the wire harness off the injector(if you decide to change them over)
and thats about it any question i could probably answer for you
oh and yes it does seem to add noticeable power gain.
-Andy-
06-tj-2.4 4 cyl, 6 speed. red, 2.25 bb on 31s, rear aussie locker, hella 500 series on bumper, mile marker pe8000, rock krawler rear bumper w/ hitch, optilux lights mounted on stainless steel windshield light brackets, in cab winch switch
red jeep club member 479
my myspace^
legend6009 is offline
post #11 of 12 Old 04-28-2007, 11:52 AM Thread Starter
BustedZJ
thanks guys, i had not read anything about the harness, but i will have to keep that in mind.
1972 CJ5 304 - sold
BustedZJ is offline
post #12 of 12 Old 04-29-2007, 08:53 AM
legend6009
legend6009's Avatar
well i guess its not really a harness more or less the wire connectors, they are 2 wires then the connector and you will have cut your injector wires off and splice the new one in, its not very hard. being that i dont know how to solder i just used the butt splicing.
-Andy-
my myspace^
Junkyard treasure Thelt ZJ Grand Cherokee Forum 3 10-29-2009 06:47 PM
have DW - going to junkyard spikeystrip ZJ Grand Cherokee Forum 8 07-21-2009 01:33 PM
junkyard 44a Qs? sandman ZJ Grand Cherokee Forum 5 11-23-2008 02:31 AM
ZJ Junkyard/Pull-A-Part Mods And Upgrades daufuskieraised ZJ Grand Cherokee Forum 2 10-13-2008 09:25 AM
Found ZJ in junkyard... Dtowncats ZJ Grand Cherokee Forum 22 04-05-2007 11:37 AM
