moaning in low speed turns - JeepForum.com
post #1 of 48 Old 01-19-2009, 07:02 AM Thread Starter
alexsious
sometimes like in my neighborhood or a parking lot, my jeep sounds like its moaning. at really slow speeds while turning it sounds like heavy rubber being twisted. it sounds like its coming from the rear because the rear shudders when coming out of the turn. its kind of freaking me out.
alexsious is offline
post #2 of 48 Old 01-19-2009, 09:49 AM Thread Starter
alexsious
anyone have an idea why it might sound like a haunted ship in some scary movie??
post #3 of 48 Old 01-19-2009, 09:57 AM
xJoshxx
2012 WK
What type of 4x4 are u? select-trac Quadradrive?
xJoshxx is offline
post #4 of 48 Old 01-19-2009, 10:04 AM Thread Starter
alexsious
selec-trac
post #5 of 48 Old 01-19-2009, 10:15 AM
xJoshxx
2012 WK
check ur differntials the pumpkin lookin thing on the axle see if it has enough fluid in it. (take the plug out fluid should be level with the hole)
also could have a bad wheel bearing.
xJoshxx is offline
post #6 of 48 Old 01-19-2009, 10:43 AM
ajmorell
ajmorell's Avatar
Sounds like a power steering issue to me. Have you checked to make sure the reservoir is topped off?
ajmorell is offline
post #7 of 48 Old 01-19-2009, 12:11 PM Thread Starter
alexsious
i will check that stuff when i get home tonight. i think the ps fluid is low but i don't think that is everything. it shudders really bad when i make a slow turn and sounds like a creaking old ship about to snap in half from hurricane winds!
post #8 of 48 Old 01-19-2009, 01:02 PM
tfgnt16
2009 WK
make sure your transfer case isn't stuck in 4wd part time. in part time the wheels are spinning at the same speed. i've tried it before and it sounds exactly as you said. check the transfer case linkage.
2001 WJ Laredo 4.0L - Sold!
2009 WK Limited 5.7L HEMI
tfgnt16 is offline
post #9 of 48 Old 01-19-2009, 01:06 PM Thread Starter
alexsious
i do need to check that because i can never feel it change when i shift from 4FT to 2WD.
post #10 of 48 Old 01-19-2009, 02:17 PM
tfgnt16
2009 WK
you should hear and feel the tcase lever slighty "snap" into position when you shift back into 2WD. there should also be an audible difference in the sound of your jeep. it gets a bit quieter when it's properly shifted back into 2WD.
i used to have the same problem as you until i had my tranny rebuilt, thankfully under warranty. the dealer must has reset the linkage on the tcase when they set it back in place.
tfgnt16 is offline
post #11 of 48 Old 01-20-2009, 08:05 AM
irishmarco
Sounds like what my '01 is doing with Quadradrive, I guess I should change all the fluids and see if that helps?
'04 WJ Laredo 4.0L selectrac, 99k, 2.5" Rusty's coils
'89 YJ Wrangler S 2.5L (60K), 2" Rusty's AAL, 31" BFG
'90 Miata (30 mpg DD) 220K, '01 engine (27K)
sold : '95 XJ country, 4.5" RE, 31" BFG, F&R lockers
sold : '01 WJ 4.7L Limited, really wanted to lift! (wife)
irishmarco is offline
post #12 of 48 Old 01-20-2009, 08:15 AM Thread Starter
alexsious
ALL the fluids were changed a few weeks ago. but i think it could be getting stuck 4PT because i am running it in 4FT with no sounds. i shifted from neutral to full time a little fast and got a nice back jarring. then i drove down the road and switched to part time and got another nice clunk, then shifted 2WD and got nothing. so its probably that. how will i be able to check the linkage? and how will i be able to adjust it. right now its freakin cold so i can't check at the moment.
post #13 of 48 Old 02-10-2009, 07:46 AM Thread Starter
alexsious
i checked all the wheel bearings, they are still good. i tried checking if it was stuck in 4PT by throwing it in 2WD and rotating one lifted front wheel with the other on the ground till the transfer case clicked and i could freely rotate the front wheel. i drove it after that to check that it stayed in 2WD but the sound was still there. so its not the transfer case. i guess next is check the fluid levels in the diffs and PS fluid. its so clear i can't tell where the fluid is on the stick. could the diff have seized? it has had water in it and the fluids were changed, but maybe enough water was left to rust it together. also my diffs look wet on the bottom of the covers but its not leaking. it just looks like wet paper. could this be a problem? how much would a shop charge for differential work?
post #14 of 48 Old 02-10-2009, 08:14 AM
KeeptheJeep
Remove your front drive shaft and take the jeep for a drive. If it goes away, then you have a bad u-joint or front diff most likely.
KeeptheJeep is offline
post #15 of 48 Old 02-10-2009, 08:51 AM Thread Starter
alexsious
oh boy... how hard is it to do that? i don't have my haynes manual with me right now.
Hopping/Binding at slow speed tight turns PaLftr ZJ Grand Cherokee Forum 19 02-11-2010 05:32 AM
low speed turning issues, click in and out of sharp turns MidwestJ ZJ Grand Cherokee Forum 5 06-05-2009 12:01 AM
Low "roaring / moaning" sound on full-lock turns adgjqetuo ZJ Grand Cherokee Forum 16 01-13-2009 08:10 PM
Rear Diff Moaning?? Friction Mod? upcountry ZJ Grand Cherokee Forum 10 06-27-2007 11:46 AM
Moaning/Scraping Noise in Drivetrain cjdietzman ZJ Grand Cherokee Forum 1 02-04-2005 10:56 AM
