Mixed tires sizes - whats broke up front? - Page 4 - JeepForum.com
post #46 of 53 Old 09-15-2013, 01:33 PM
stageninja
That Rigger Guy
stageninja's Avatar
Did you literally swap the ring & pinion from another axle? If so did you do all the set up required for setting up new gears?
Mine '97 White, ZJ Ltd, 5.2, Up-Country Suspension, Kolak ignition, Kolak/Magnaflow Exhaust
Her's '98 Chargold ZJ Ltd. 4.0 2wd
Our 1st '97 White, ZJ Ltd, 5.2, The parts Jeep for 5 years...R.I.P. Sent to Pic-A-Part 5/17/2013
stageninja is offline
post #47 of 53 Old 09-15-2013, 02:02 PM Thread Starter
Rmvr53
if you mean mesh checks, run out, etc with the DI then yes - thats why it took me 10+ days between posts. I tried to just swap out the complete diff but the bearings were stuck (could not adjust the carrier bearing shim pack)...almost broke my spreader and got no movement out of a 20 ton press...it wasn't going anywhere. So, I had to resort to the "nasties" of swaping out the ring gear. Drove it yesterday afternoon for the first time. Front end feels a bit sloppy but I'm going to drive it first to see what specifically it is
Rmvr53 is offline
post #48 of 53 Old 09-15-2013, 02:27 PM
stageninja
That Rigger Guy
stageninja's Avatar
That's what I was asking. If you'd been able to swap the complete diff you would still have had to "set up" the gears for your case. I get grief on here because I have been changing bearings only & using the factory shims, then checking pattern & running with it. If I were swapping gears it would be a whole other program indeed.
post #49 of 53 Old 09-15-2013, 05:16 PM
lionshooter
In 93, I bought a new ZJ with Command Trac 231 TC. NTW (now NTB) put different sized tires on the front and rear at 60K. Tore up that TC is very short order. Now I have another 93 ZJ with Selec Trac 242 and it has a donut spare.
If tire size is such an issue, why would Jeep do that?
lionshooter is offline
post #50 of 53 Old 09-15-2013, 05:20 PM
dusterdude
I think there was a recall to replace the donut with a full size spare
dusterdude is offline
post #51 of 53 Old 09-15-2013, 05:26 PM
Scopez
1994 ZJ
I tried that ****. I have a 15" wheel as my spare tire. Completely different tire size aswell. It's still the factory one. I called Chrysler and they said well thats the right full size spare. I'm like I have ****ing 16" wheels. This tire will ruin my Vicious Coupler. They said its only meant for 10miles to find the closest dealership. I dislike stupidity.
94 ZJ Laredo. 5.2 Crate engine. 6in JKS SA Lift. 33in Destination MTs. ARB Front Bumper.
Scopez is offline
post #52 of 53 Old 09-15-2013, 05:58 PM
stageninja
That Rigger Guy
stageninja's Avatar
You should be able to find a matching wheel @ your local jy. I advocate buying 5 new tires when it's time & run a 5 tire rotation schedule. Then your spare is in the mix and all tires wear evenly. Then when you have a road hazard & have to put on the spare its not a problem.
post #53 of 53 Old 09-15-2013, 06:16 PM
Scopez
1994 ZJ
That's what I plan on doing eventually. Ill be ordering soft 8s pretty soon so ill order 5. Even though my spare wheel looks like a soft 8 almost...
Scopez is offline
