Mixed tires sizes - whats broke up front? - Page 3 - JeepForum.com
post #31 of 53 Old 08-25-2013, 07:01 PM
tucsonzj
Originally Posted by PolkaPower View Post
It's only really 2wd with the front shaft out. Other than that you are turning everything in the front. Burnouts and racing are childish.
Yup its a jeep not a camaro
His:00 TJ "Fiona" stuff/stuff/stuff
95 ZJ 3.5" w/242 swap-Sold
Hers: 15 JK Sahara-3" Teraflex
tucsonzj is offline
post #32 of 53 Old 08-25-2013, 08:38 PM
drobes34
Mud and crud!!!
drobes34 is offline
post #33 of 53 Old 08-31-2013, 03:37 PM Thread Starter
Rmvr53
parts came - parts wrong.
I spoke with the guy at the 4x4 shop - I told him I needed a 3.73 R&P for a 98 Jeep Grand Chreokee 5.2 with factory towing pkg. The Pinion that came is about 3/4" longer than the one I took out. He says this is the only part number showing for this Jeep. So...what do I have?
thanks
Rmvr53 is offline
post #34 of 53 Old 08-31-2013, 05:24 PM
dusterdude
Probably for an iron dana 44
dusterdude is offline
post #35 of 53 Old 08-31-2013, 05:28 PM
PolkaPower
thanks
Front axle is D30. Rear axle is D44HD.
PolkaPower is online now
post #36 of 53 Old 08-31-2013, 06:14 PM
Snowfan2
You need the 'short' pinion.
Snowfan2 is offline
post #37 of 53 Old 08-31-2013, 07:46 PM Thread Starter
Rmvr53
so...when I go the the junk yard tomorrow to pull a front R&P out of a 98ZJ, will the three that they say they have in the yard be the same as mine?...if not, what am I looking for (externally) without taking it apart
Rmvr53 is offline
post #38 of 53 Old 08-31-2013, 08:19 PM
PolkaPower
All ZJ's got a D30 in the front. In the rear 93-95 got D35. 96-98 got D44a v8 only.
post #39 of 53 Old 08-31-2013, 08:36 PM
Red-ZJ
Not to threadjack, but this story of mismatched tires has me worried. I made the same mistake, with some worn-to-baldness 235/75/15 tires on the front, and some new 235/75/15 tires on the rear. Started to make strange noises halfway home, popping and jump around. Once I realized what was happening I put both of the new tires on the passenger side, and bought two new tires. AWD is still working... How does one check the VC?
Red-ZJ is offline
post #40 of 53 Old 08-31-2013, 09:03 PM
1stblack97ZJ
Do figure 8s in a parking lot.
Youll know.
1997 ZJ Laredo
4" Lift
32s
Plenty of lights
1stblack97ZJ is offline
post #41 of 53 Old 09-02-2013, 11:53 AM Thread Starter
Rmvr53
I just love a successful yard raid. Got the correct pinion and complete diff for $60; got dang near new rotors and pads for $16.00 (total for both sides - rotors mic out at .999); now...whats the diff run-out set to so I know what shims to put back in...or do I just put in the shim pack I took out of the donor ZJ and run with it?
Rmvr53 is offline
post #42 of 53 Old 09-02-2013, 04:13 PM Thread Starter
Rmvr53
well...small setback with a question. I put the new pinion in, went to bolt it up, the yoke won't seat. Took it off to check and it will slide about 1/2 way on the splines then sticks. Is this just the difference in yokes Old yoke new Pinion)? I did try to put the yoke (old) on the old Pinion and it went 3/4 of the way on but still didn't slide all the way. Now I know it didn't shrink, but am I missing something. I put a lot of umph on the nut and it just won't make it "slide" on. Also - end play for the yoke - anyone know now much it should be or just set with pre-load?
thanks
Rmvr53 is offline
post #43 of 53 Old 09-06-2013, 11:22 AM
Snowfan2
I'd help but don't have the knowledge. Someone will chime in I'm sure.
We need ratmonkey...RIP
Snowfan2 is offline
post #44 of 53 Old 09-06-2013, 02:24 PM Thread Starter
Rmvr53
got the yoke on - put it back on the old pinion in a different position then gave it a good whack - drove it on. Took it off and it went right on the new pinion. Plan is currently to set preload and not worry about actual torque although I have seen a few posts in other locations on the forum about 180-220 ftlb. Working on setting carrier bearings now - done screwed up one bearing not looking forward to doing it again...
Rmvr53 is offline
post #45 of 53 Old 09-14-2013, 07:59 PM Thread Starter
Rmvr53
finished -
used 3rd member from junkyard - $60 (actually only used the R&P)
new pinion seal - $ 4
new pinion nut - $ 4
new dif seal - $ 6
misc costs -
new inch-pound torque wrench that would read under 25in-pounds to set pinion preload - $40 (1/2 price sale at Sears)
new 1/2 shaft CV boot - $ 9
lube - $ 5
4 new tires that all match - $436 (ouch)
total invested in Jeep so far - $564 - (can't complain since I only paid $800 for it!)
gleaning the minds of the people who take time to respond to posts - priceless
thanks all
Bill
Rmvr53 is offline
