Mixed tires sizes - whats broke up front? - JeepForum.com
post #1 of 53 Old 08-20-2013, 09:20 PM Thread Starter
Rmvr53
Just bought a 98 ZJ 5.2 that has new 235 75 15's on the rear...wait for it...
and 215's on the front. 4H or 4L transfer case. Oh...and the front end "pops" as it rolls forward. I'm hoping its just axle hop from the different sized tires but worst case what am I looking at to fix if its not?
Bill
Rmvr53 is offline
post #2 of 53 Old 08-20-2013, 09:47 PM
drobes34
Was gonna do this with 235 up front and 31's in back and tire barn said No!!! So I didn't lol not sure man hope it don't rip the front end out
drobes34 is offline
post #3 of 53 Old 08-20-2013, 09:54 PM
Scopez
1994 ZJ
I'd pull the front driveshaft before you drive it anywhere else. The Vicious Coupler in the transfer case is probably burned up from different tire sizes($300 part). There's probably a front end rebuild in the future....
94 ZJ Laredo. 5.2 Crate engine. 6in JKS SA Lift. 33in Destination MTs. ARB Front Bumper.
Scopez is offline
post #4 of 53 Old 08-20-2013, 10:55 PM
JohnnyZJ
Hope ya got a good deal......
07' JKUR rollin on 35s
JohnnyZJ is offline
post #5 of 53 Old 08-20-2013, 10:57 PM Thread Starter
Rmvr53
200k, Limited, really nice paint/body and interior and runs fine - seems to go through the gears ok (didn't want to drive it till I check it out) $800
Rmvr53 is offline
post #6 of 53 Old 08-20-2013, 11:07 PM
LoveHate
yup the vc is toast. also open up the front diff and check the gears and fluid. and remove the front drive shaft til you get it fixed. if the popping continues with the driveshaft out then check the axle shaft u joints or cv joints.
Just Enjoying Every Puddle
Built Not Bought #693
LoveHate is offline
post #7 of 53 Old 08-21-2013, 04:23 AM
zj97ltd
It's almost irrelevant but, any idea how long it's had mis-matched tires?
zj97ltd is offline
post #8 of 53 Old 08-21-2013, 05:50 AM
newfieZJ
Originally Posted by Scopez View Post
I'd pull the front driveshaft before you drive it anywhere else. .
^^ This ! Might as well and take it for a drive to see if anything is hooped . You may get lucky
1995 Orvis build
1988 MJ build
1998 Slate 5.9 build
1998 Platinum 5.9 build
newfieZJ is offline
post #9 of 53 Old 08-21-2013, 06:39 AM Thread Starter
Rmvr53
miss-matched tires were supposedly on it for just a couple of days. Per the receipt in the glove box the guy had the new tires put on the rear Friday, and listed on CL Monday
Rmvr53 is offline
post #10 of 53 Old 08-21-2013, 08:44 AM
PolkaPower
Even for just a couple days it's guaranteed the VC is gone.
PolkaPower is online now
post #11 of 53 Old 08-21-2013, 11:04 AM
tucsonzj
no kidding, some people I swear. The info is out there, and what tire shop said yea i'll throw on different size tires in the rear!
But yea vc is toast so doesn't matter, pull the front ds and make sure it drives ok besides that. Crack open the diff and see what it looks like. Hopefully when you get some correct tires it'll be ok up there, but things could be destroyed pretty easily. Good luck.
His:00 TJ "Fiona" stuff/stuff/stuff
95 ZJ 3.5" w/242 swap-Sold
Hers: 15 JK Sahara-3" Teraflex
tucsonzj is offline
post #12 of 53 Old 08-21-2013, 03:28 PM
JohnnyZJ
if it drove fine on the road then the transfer case is probably alredy shot. if the VC was shot it would be locked in 4wd and he'd have a hell of a time moving the jeep let alone driving it.
bet the chains gone. last ZJ i gutted had that problem.
JohnnyZJ is offline
post #13 of 53 Old 08-21-2013, 03:37 PM Thread Starter
Rmvr53
took a long lunch and did some playing - dropped the forward drive shaft and the problem still exists. Hooked it back up, jacked up the left side and everything was good and tight. Jacked up the right side and it sounds nice and "crunchy" plus it will free-wheel when spun...and crunches while doing so. I'm guessing something ain't kosher inside the great pumpkin....
Rmvr53 is offline
post #14 of 53 Old 08-21-2013, 10:09 PM
LoveHate
Sound like a broken shaft.
LoveHate is offline
post #15 of 53 Old 08-24-2013, 11:23 AM Thread Starter
Rmvr53
oh the joy....
just pulled the front cover - no teeth on the pinon. Ok - there are a few teeth, thats whats catching when you try and drive it....
Rmvr53 is offline
