Missing Catalytic converter? Need it?? - JeepForum.com
post #1 of 14 Old 09-20-2013, 01:34 AM Thread Starter
rcpjeep
I just picked up my 1996 jeep Grand Cherokee Laredo 5.2l full time 4x4 from storage to complete my suspension, tires and brakes.
It ran great, but we moved and I had to put it into outdoor storage for spring and summer 2013.
went under the rig to put the new shocks in , and my exhaust is completely cut out.
from about trans to the gas tank, cat and muffler are gone, they didn't cut off the O2 sensor wire thank goodness.. but ... now what should I do?
Can I run it with a 26" Thrust Glasspack?
Can it run without the Catalytic Converter and down O2 sensor?
Do I really need the muffler, Cat and down O2 sensor?
rcpjeep is offline
post #2 of 14 Old 09-20-2013, 02:40 AM
jabba974
If your state requires emmissions testing, you will need a cat and muffler....If not, then that depends on what you want to do, how much you want to spend, and how loud you like your exhaust... No muffler and cat will be loud as hell... I have a 5.9L in my 2500 ram with a Flowmaster and I like the sound, but when I am towing it does get a little loud... Not running a cat may throw a check engine light... My suggestion is to replace the cat, and put a good free flowing muffler on it...Good sound and better mileage and power...
jabba974 is offline
post #3 of 14 Old 09-20-2013, 08:42 AM
Myusername1674
I'll post before a mod does. Since removing your cat is illegal, they don't entertain talking about it on these forums. It's their policy. That being said it's not your fault there's no cat.
I'd suggest finishing the exhaust out the back, maybe with a high flow cat. I did this and it did help mpg some.
95 FiveTwo ZJ, DD, Lifted, Locked on 35s,
(in progress)
Myusername1674 is offline
post #4 of 14 Old 09-20-2013, 09:46 AM
RagTagSoldier
Before Texas sees this ill give some advice. Do what you want to your taste but put a cat in. It's frowned upon the forums and can get you banned. It's not your fault it's gone I'm just informing. I have a super 44 on mine and love it
Sent from my iPhone using JeepForum so it probably looks goofy.
RagTagSoldier is offline
post #5 of 14 Old 09-20-2013, 09:50 AM
JeepNicholson
Federal law requires a cat, regardless of whether your state or locality does emissions testing.
JeepNicholson is offline
post #6 of 14 Old 09-20-2013, 11:21 AM
dusterdude
Yea,you damn sure dont want the nsa crawling under your jeep
dusterdude is offline
post #7 of 14 Old 09-20-2013, 11:30 AM
zj97ltd
A little back-pressure is your friend.
zj97ltd is offline
post #8 of 14 Old 09-20-2013, 01:43 PM Thread Starter
rcpjeep
So .... I get it about the cat...thanks for your responses.
So can I run a CAT with a Glasspack ?
rcpjeep is offline
post #9 of 14 Old 09-20-2013, 01:52 PM
zj97ltd
Sure. It doesn't care what's behind it.
zj97ltd is offline
post #10 of 14 Old 09-20-2013, 02:46 PM
sebian
Sounds like they have already been crawling under his Jeep!
1995 ZJ 5.2L V8 318. 230,000 miles and still rollin.
List of parts not replaced yet:
sebian is offline
post #11 of 14 Old 09-20-2013, 07:45 PM Thread Starter
rcpjeep
So.....With a new Stock CAT, and a 25" Thrust GlassPack Behind it,will it be very loud?
or will the stock CAT Calm it down a little?
rcpjeep is offline
post #12 of 14 Old 09-20-2013, 08:00 PM
zj97ltd
I ran a stock cat with no muffler and side exit in front of the rear wheel. It was cool for about an hour then it just got annoying. Lots of droning while cruising, and just a "trashy" sound when accelerating hard. A glass pack may take some of that out of it but I'm not sure. I currently have a free flowing cat and a 40 series Flowmaster running through the stock tail pipe. Has a great rumble to it and doesn't annoy you when cruising. You definitely know it's there.
zj97ltd is offline
post #13 of 14 Old 09-20-2013, 08:01 PM
cbr900
1993 XJ Cherokee
Will it run hell yes plenty of deer lease trucks runs straight pipes is it legal....no
cbr900 is offline
post #14 of 14 Old 09-20-2013, 08:37 PM
Texas ZJ1
Jeep Jedi Master
Texas ZJ1's Avatar
1994 ZJ
If it isn't legal, don't do it.
Thanks for closing the thread.
Hunter
04 4.7 HO, limited
08 Z71 Suburban, front leveling kit with rear spacers. 285/65 18s Nitto TerraGrappler G2s
94 5.9 Laredo 6.5 RE lift with 35 Maxxis Bighorns
and 33 Bridgestone Duelers
Detroit and true trac
Red Jeep Club Member
REDNECK JCM
Texas Jeep Owner #6
USN Jeep Club #4
602.841.3355
For your performance needs:
480.998.366
Texas ZJ1 is offline
Closed Thread
