miss when restarted after warming up - JeepForum.com
post #1 of 4 Old 05-04-2012, 12:02 PM Thread Starter
mrclark25
1994 ZJ
my 94 JGC with the 5.2 misses, but only under certain conditions.
i started to notice it when i would shut the engine off after letting it warm up and then sit about 10-15 minutes. upon restarting it, it would miss for about 2-4 minutes, and then stop missing. this was with the stock 195 degree thermostat.
i now have a 180 degree thermostat, and the issue hardly ever happens, except when the temperature gets up to 210 degrees or so(usually while out wheeling, but now it is getting up there regularly with the warmer weather), and then i let it sit for 10-15 minutes and restart it.
it never hesitates to start, and it always comes out of it in under 5 minutes.
i am thinking it is something with (or one of) the fuel injectors, but am unsure.
its not a real serious problem, but it would be nice to figure out what it is.
mrclark25 is offline
post #2 of 4 Old 05-05-2012, 03:37 AM
Texas ZJ1
Jeep Jedi Master
Texas ZJ1's Avatar
1994 ZJ
When was the last time you checked or replaced the spark plug wires? If they are burnt through, replace. If they are burnt through, you'll get cross arcing on the motor causing misses. It won't miss at idle or in neutral, just in drive and under load.
Hunter
04 4.7 HO, limited
04 4.7 HO, Overland
08 Z71 Suburban, front leveling kit with rear spacers. 285/65 18s Nitto TerraGrappler G2s
94 5.9 Laredo 6.5 RE lift with 35 Maxxis Bighorns
and 33 Bridgestone Duelers
Detroit and true trac
Red Jeep Club Member
REDNECK JCM
Texas Jeep Owner #6
USN Jeep Club #4
602.841.3355
For your performance needs:
480.998.366
Texas ZJ1 is offline
post #3 of 4 Old 05-07-2012, 08:04 AM Thread Starter
mrclark25
1994 ZJ
it could easily be the plug wires... but would that explain it only missing when restarted after warming up?
i have also noticed the miss goes away when over 2000rpm or so.
post #4 of 4 Old 05-15-2012, 11:58 AM Thread Starter
mrclark25
1994 ZJ
any ideas?
Trying to stall out while warming up zeejay92 ZJ Grand Cherokee Forum 21 01-21-2012 08:32 AM
94 GC 4.0 stalling after warming up Jeepskate64 ZJ Grand Cherokee Forum 4 10-17-2009 09:57 PM
Nav voice prompting has to be restarted everytime ToastedSpider WK Grand Cherokee & XK Commander Forum 5 05-27-2008 11:10 AM
99 No Heat after warming up -Joe- ZJ Grand Cherokee Forum 2 11-12-2005 08:59 AM
For those with warming problems.... bnhcooper ZJ Grand Cherokee Forum 3 12-22-2004 07:08 PM
