Might be electrical problem? fuel pump? - JeepForum.com
post #1 of 5 Old 06-30-2010, 09:04 PM Thread Starter
Airman_G
ok so this past monday i was picking my gf up from work wen i hit a bump or dip. the radio and stuff cut off for a minute and then came back on. but my jeep had shut comepletly off. i was able to pull into a gas station. luckaily there was a machanic there. i guess i wasnt geting any fuel cuz the guage said i had no gas even tho i had just put some in. come to find out the fuse for the fuel pump had gone out. so we just replaced it and it started up in a jiffy. well yesterday the same senerio, picking up gf from work and the same **** happens! had to get towed to a shop. they couldnt figure out wat was cuasing the problem. they drove it around and nothing happend. they think its something electrical. they advised me if it happend again to either take it to the dealer or go to a special shop. could it be something to do with the fuel pump? has anyone every had a similar situation or may have any ideas? 1996, Jeep Grand Cherokee Laredo,4x4 6 cyl
Airman_G is offline
post #2 of 5 Old 06-30-2010, 09:30 PM
davemcd
Inspect the wires that lead to and from the fuel pump. Make sure there aren't any loose connections.
Second, try replacing the fuel pump relay. It's located under the hood, behind the battery in the power distribution center. I'm fairly certain they're cheap to replace, so it's worth a shot.
Next up try replacing the ASD (automatic shutdown) relay. When this relay shorts out, the engine can stall or not start. It might be triggered by the fuel pump (a short perhaps) also...
So, lastly, then we get to the fuel pump itself, that's probably crapping out somewhere. That's a costly part, so, if it gets to that stop there and take it to a real shop to diagnose it.
There might be other reasons, but this comes up first in my head.
davemcd is offline
post #3 of 5 Old 07-05-2010, 03:00 PM Thread Starter
Airman_G
cool thx for the help! i think it may have to do with the air condition now?.. both times it happend i had turned the air on. i drove it few days without it and nothing happend.
yesterday i had turned it on and sure enough it did it again.. replaced the fuse and started right up. could there be a leak or something thts cuasing the shortage?
Airman_G is offline
post #4 of 5 Old 07-05-2010, 04:37 PM
Elkaholic
NMElkaholic
Elkaholic's Avatar
Thanx for the response, Airman G is my son and If I was close to his base I would be over there helping him.
troubelshooting from a long ways a way can be very hard!! any other suggestions would be greatly appreciated..
Airman....., davemcd hit it.. trace those wires to make sure they are not pinched or bare wire touching metal.. also check your ground to your battery and make sure it is tight., a bad ground can cause all kinds of issues..
98 5.9, Platinum 4.5 RE SF all adjustable arms, RE Monotube Shocks, Carolina front drive shaft, Pro Comp Extream Alloys Stryker's, 285/75/16 BFG's KM2's,Stage 1 rock sliders,Confer roof rack,Warn XD9000i winch, 3" Kolak exhaust system, Addco front swaybar and lot's more goodies.. 79 CJ5 AMC 304 33x12.5 Pro Comp X-tream mud tires on 15x12 MT classics. 3" lift.
Elkaholic is offline
post #5 of 5 Old 07-05-2010, 08:23 PM
ZeeJay1997
The fuel pump has a dedicated fuse so it may just be a coincidence about the AC.
Are you sure it's fuse 16 that blowing and not fuse 20
If you want to shake the fuel pump wire, from the fuel pump relay in PDC, the wire travels around the front of the engine, down the drivers fender, through the firewall and to a gray plug under the dash above the left foot of the driver. It will be a dark green and white wire. From there it goes down the drivers side floor along the trim then under the back seat and out to the undercarriage.
ZeeJay1997 is offline
electrical , fuel pump , fuses
Is this a Fuel pump problem? RedTabE ZJ Grand Cherokee Forum 72 07-08-2010 06:26 PM
Fuel Pump/Fuel Tank Problem ma-usa1 ZJ Grand Cherokee Forum 18 04-09-2008 07:28 PM
Fuel Pump Problem????? Jay1982 ZJ Grand Cherokee Forum 1 07-26-2006 07:37 PM
fuel shut-off/security?? electrical problem need HELP robsampson ZJ Grand Cherokee Forum 1 09-29-2003 08:48 AM
Fuel Pump/Fuel Tank Problem ma-usa1 ZJ Grand Cherokee Forum 0 02-05-2003 06:02 PM
