metal on metal sound coming from the rear of my jeep - JeepForum.com
post #1 of 13 Old 02-02-2013, 06:22 PM Thread Starter
jeep93zj
There is a metal on metal sound coming from the rear. It sounded like the gears were going bad so I put new gears in it today and the sound is still there I can't figure it out. It is loudest when I'm pressing the gas. I can't figure it out. Thanks in advanced for the help.
jeep93zj is offline
post #2 of 13 Old 02-02-2013, 06:42 PM
SAR-Swimmer
Brakes hanging up, or bearings going bad, would be my guess.
SAR-Swimmer is offline
post #3 of 13 Old 02-02-2013, 06:52 PM
newfieZJ
Bad e-brakes or pinion/carrier/axle bearing . From what you say , pinion is my thought .
What gears ? C&P or spider ?
newfieZJ is offline
post #4 of 13 Old 02-02-2013, 06:58 PM Thread Starter
jeep93zj
I just put a Detroit true track in, and all new bearings and a new ring and pinion gear.
jeep93zj is offline
post #5 of 13 Old 02-02-2013, 07:41 PM
newfieZJ
That's a tough one . Did you check the u-joints . I'm doubting you missed much connected to the diff rebuild . Everything I can think of was exposed during the work , u-joints , having to pull the axles . The e-brakes were also in plain view .
You did the side axle bearings also ? Just confirming
Times like this you need those "mouse" ears . They stick on parts(magnet) and measure noise levels .
newfieZJ is offline
post #6 of 13 Old 02-02-2013, 08:03 PM Thread Starter
jeep93zj
Yes replace all bearings and about A month ago I replaced all my u joints on both front and rear drive shafts. And after I was done I cleaned and adjusted the teaser breaks. And is been making this noise for a while now.
jeep93zj is offline
post #7 of 13 Old 02-02-2013, 08:16 PM
4Slow9erHybrid
Is it lifted?
1997 JGC Laredo 4.0 4x4 99900mi * 0W30 German Castrol since 75k * 225/75/R15 Firestone Destination AT on Ravine rims * winter 235/75/R15 Bridgestone Blizzak DM-V1 * UC suspension * Monroe Reflex Monotube shocks * factory skids * KOR steering brace * rear Addco SB * Magnaflow cat and cat back system * complete 5.9 interior
4Slow9erHybrid is offline
post #8 of 13 Old 02-02-2013, 08:23 PM Thread Starter
jeep93zj
Yes it is 3.5 inches
jeep93zj is offline
post #9 of 13 Old 02-02-2013, 08:25 PM
4Slow9erHybrid
Pinion angle adjusted within 1 degree?
post #10 of 13 Old 02-02-2013, 08:34 PM Thread Starter
jeep93zj
It was lifted when I got it and it was not making the noise when I got it.
jeep93zj is offline
post #11 of 13 Old 02-03-2013, 05:56 PM Thread Starter
jeep93zj
Bump
jeep93zj is offline
post #12 of 13 Old 02-04-2013, 04:54 AM
Rich93ZJ
when I lifted mine, my sway bar links were hitting the inside of the wheel until i got my t/b installed...Maybe something to look at
Rich93ZJ is offline
post #13 of 13 Old 02-04-2013, 07:04 AM Thread Starter
jeep93zj
I have 3.75 offset wheels so it won't do that. I can't figure this noise out.
jeep93zj is offline
