Metal fragment stuck to d30 fill plug, what should I do? Questions inside. - JeepForum.com
post #1 of 5 Old 08-14-2009, 10:52 PM Thread Starter
phant0omx
2012 WK
So, my front diff, D30, has been leaking out the side for several months now as the inner axle seal needs replacing. I go to fill it up and I find a metal shaving/fragment on the magnetic fill plug.
The Jeep is a 2000 WJ with quadra drive.
1. What should I look at?
2. What can I expect in terms of replacing things? Rebuild needed?
3. How does this effect quadra drive down the road as I want to keep it.
4. Should I stop driving the Jeep and get it looked at or repaired asap?
I didn't have the time to pop the diff cover so I'm kind of asking as a preliminary to when I can pop the cover off and take a look at the gears and so forth. I'm not well versed in the innards of the D30/quadra drive either...
I have ordered 4.56 gears for my WJ from Kolak, but the gears have been backordered/out of stock for 5 months now and I have no idea as to when the gears will be restocked.
What do I do? Anything to add?
The picture of the metal.
phant0omx is offline
post #2 of 5 Old 08-15-2009, 06:46 AM
skiebuster
Looks like a spacer.
does that front axle got a loud whine ?
skiebuster is offline
post #3 of 5 Old 08-15-2009, 10:00 AM Thread Starter
phant0omx
2012 WK
Yes, I would say it has a loud whine. Like a rough loud whine, if that makes any sense.
post #4 of 5 Old 08-15-2009, 10:45 AM
skiebuster
My rear end in my 98 Limited with the 35 had a bad spacer, cause the axle to move back and forth and cause it to wine big time. I could turn my steering a little to the left, in a back and forth motion, and it would be louder turning it to the left than to the right while going down the highway.
Luckily, my father had a xtra rear end from 1 that had bad gears and we was able to use the spacers from it to get it correct.
Good luck, I know they can be a pain. But not to costly to repair if you have any knowledge on axles.
post #5 of 5 Old 08-17-2009, 10:57 AM Thread Starter
phant0omx
2012 WK
Thanks for the input. I don't know much about gears, so this will have to be taken to a shop to handle.
Any others have any input?
D35 fill plug MEinSoCal ZJ Grand Cherokee Forum 25 03-18-2009 07:17 AM
Cannot get fill plug off. Windowsrookie ZJ Grand Cherokee Forum 43 06-27-2008 08:08 PM
TC case fill plug Diehard ZJ Grand Cherokee Forum 9 04-28-2008 11:28 PM
stripped TC (247) fill plug mailforjon ZJ Grand Cherokee Forum 11 03-16-2008 05:25 PM
247 fill/empty plug key Arkansas_WJ ZJ Grand Cherokee Forum 5 01-25-2007 07:10 PM
