Mechanical Fan Swap on 5.9 - JeepForum.com
post #1 of 10 Old 07-16-2011, 10:57 PM Thread Starter
1998zj59
So i have not posted in awhile. I have not been driving or working on my jeep for awhile but i am now getting it ready for summer. since I've had my 5.9 i have replaced headlight, turn signals and fog light lenses, blacked out the tail lights, put a magnaflow cat and flowmaster super 44 muffler on, 180* thermostat and throttle body spacer, but just the other day i charged up the a/c at work and with the a/c on it builds up way too much pressure on the high side it maxes out the gauge at like 450-500 psi so the blow off valve keeps opening up. found out the rad fan is not running (which would also explain why it gets hot when i beat on it a lil) tapped the fan motor and it attempts to turn at about 100 rpm lol so anyone ever try to find a electric fan for a 5.9 lol so i turned to you guys on the forum and i read about the taurus fans and other options but im not a fan of swapping parts from completely different cars so i went with the mechanical fan swap off a 5.2. i got a used fan and shroud for 75 bucks from a local yard put it all on today wow very easy swap, swapped the shroud brackets and everything cleaned it all up. if you didn't know it was suppose to have a electric fan you would never notice anything was changed and now it actually pulls air threw the rad lol took it for a drive and i didn't notice any power loss what so ever i fully recommend this swap (especially if you want the extra towing capacity) and thank you guys for pointing me in the right direction
1998zj59 is offline
post #2 of 10 Old 07-16-2011, 11:36 PM
Nickell80
1997 XJ Cherokee
I never thought about that situation and somebody thinking about doing a M(?) fan swap.
That's really cool though.
I wish there was a way for the ZJ's to have both an electric and mechanical fan together like the XJ's.
Just from driving my work vans where we sit idle with A/C running for a good amount of time, I realized how much of a difference it makes having something to push the extra air (so I don't have to keep giving it gas) for the ac to get colder.
White 97 2 Door 4.0 5 Speed XJ
Nickell80 is offline
post #3 of 10 Old 07-17-2011, 11:26 AM
98mopar
I read on a TSB that the 5.9 has a 5000 lb towing capacity, and it is because of the electric fan. And it says on the TSB it can be swapped over with a clutch fan and then the 5.9 will have a 6500 lb towing capacity, just like the 5.2
--- 1998 ZJ 5.9 Limited - 4" lift, 31 x 10.50 15, Jet chip, Kenwood Excelon everything, current DD
--- 1996 ZJ Laredo - Parts parts and more parts
--- 1993 ZJ Laredo - 4.0 Bone stock for now (New to me)
98mopar is offline
post #4 of 10 Old 07-17-2011, 12:38 PM
jforse
The Ford fan is EXACTLY the same as the Jeep fan. Same part numbers, same, same, same. All your doing is losing power by switch to a manual fan.
1997 TJ - Build in process.
2004 WJ Freedom Edition 4.7HO
jforse is offline
post #5 of 10 Old 07-17-2011, 06:53 PM
gopherblaster
Yea but not much, and hes gaining cooler engine bay temp for towing and his other adventures which i think should be more important compared to the low hp loss
gopherblaster is offline
post #6 of 10 Old 07-17-2011, 07:20 PM
jforse
If your using the 5.9 ZJ for towing you need to retune the ecu for a lower timing advance.
jforse is offline
post #7 of 10 Old 07-17-2011, 07:32 PM
onyx
i had an extra m fan from my 5.2 and someone to me it would kill the radiator (not enough room they said so i used the taurus fan) works better that the original never get to 210 but whatever i hope i did the wireing right its the same as the orig right?
onyx is offline
post #8 of 10 Old 07-17-2011, 07:32 PM
onyx
told me sorry im on a phone
onyx is offline
post #9 of 10 Old 07-17-2011, 09:59 PM
Candymancan
5.9 also doesnt have a aux cooler for the radiator. Thats another reason for the towing rating. Get a good aux cooler and i wouldnt think twice. The electric fan cools better then a mechanical fan anyway the problem is its just not on the all the time unless its really hot out.. this is one reason the 5.9 stays cooler then a 5.2 does
Candymancan is offline
post #10 of 10 Old 07-17-2011, 10:06 PM
Newb1995jeepgc
1994 ZJ
My 5.2 never gets hot... but one very hot day out when it was about 105 outside i left the jeep running in a parking lot for about 20 miniutes with the a/c on and it did get really hotter then it should. But the Efan on my grandmas tauras lets her car almost overheat quicker then mine did. So i will stay with the Mfan.
Also efans arent great in water. LOL
1995 Jeep ZJ Limited V8- 213k- sold
2000 Jeep WJ I6- 185xxx-sold
1994 Jeep ZJ Limited Red I6- 210k
Newb1995jeepgc is offline
5.9l , fan , swap
Mechanical fan asatxj WK Grand Cherokee & XK Commander Forum 17 02-16-2010 02:03 PM
ZJ mechanical problem's? 96ekhatch ZJ Grand Cherokee Forum 18 02-07-2009 05:25 PM
mechanical fan: which tool? QuadraTokn ZJ Grand Cherokee Forum 28 12-18-2008 08:27 AM
Add a Mechanical Fan? NewJeepFever ZJ Grand Cherokee Forum 6 09-01-2008 09:25 PM
Mechanical Fan for 4.0 on wj? PJNovinskee27 ZJ Grand Cherokee Forum 0 08-29-2008 12:58 AM
