Mechanical Fan Blade - JeepForum.com
post #1 of 21 Old 09-20-2009, 10:28 AM Thread Starter
tjf1980
I posted the other week asking about doing a mechanical fan swap on a 2001 Jeep Grand Cherokee w/ 4.0L. I am not having any luck finding a fan blade that will fit and clear the engine pulleys. 93-98 JGC fan blades hit. I have tried ordering it using factory Jeep part numbers but no one has one becuase it is discontinued. And all the aftermarket parts stores don't even list a mechanical fan even though it was a towing package option. Anyone know where I can get one or an aftermarket part number? I would really like a 7 blade fan.
7 blade - #55037650AA
5 blade - #52079984AA
tjf1980 is offline
post #2 of 21 Old 09-20-2009, 10:58 AM
owenswj
owenswj is offline
post #3 of 21 Old 09-20-2009, 11:31 AM Thread Starter
tjf1980
I have tried several mopar sites but I will give them a shot too. Always comes back saying part discontinued. Maybe this one will be different. Thanks.
tjf1980 is offline
post #4 of 21 Old 09-23-2009, 04:52 PM Thread Starter
tjf1980
It took a few days for them to process my order but it looks like they had it and it's headed my way. Thanks.
tjf1980 is offline
post #5 of 21 Old 09-23-2009, 07:37 PM
owenswj
5 blade or 7? I think you can get a clutch from Autozone.
owenswj is offline
post #6 of 21 Old 09-24-2009, 07:14 AM Thread Starter
tjf1980
I grabbed a clutch from the zone last week for about $55. I ordered the 7 blade that was referenced in the mech fan swap post. Hopefully it fits. I should know Monday when it comes in.
tjf1980 is offline
post #7 of 21 Old 09-24-2009, 08:55 AM
LordHobbit
I don't know, but a dakota fan may be a possibility also. I'd check for that. I went to the dealership the other day asking for certain parts and it looks like the ZJ parts are becoming obsolete. It's as bad as my '66 Dodge pickup!
93 red ZJ 190k 4.0. Spent more money than I should have ...
Isn't red the only color a vehicle should be?
If at first you don't succeed, use more speed.
LordHobbit is offline
post #8 of 21 Old 09-24-2009, 12:26 PM Thread Starter
tjf1980
Yeah a lot of dakota stuff is the same. Seems like the problem on my 01' JGC is the water pump. It just sits to close to the engine to use any fan that has any kind of blade offset towards the engine. I got a new 93-98 JGC seven blade fan that wouldn't fit if anyone ever needs one.
tjf1980 is offline
post #9 of 21 Old 09-24-2009, 03:51 PM
trail-rated
The fan blades are discontinued??? I thought they were just on backorder (like a lot of Chrysler parts).
[ ]IIIIIII[ ] |2001 WJ|4.0L|42re|Quadra-trac II| Too many mods to list|
trail-rated is offline
post #10 of 21 Old 09-24-2009, 03:59 PM
iluvtruenos
Are you on ultimaterc?
My Jeep is a chick magnet with reverse polarity.
2000 WJ, 4.5l, AX15, 242 D60/14b, 5.5" lift front, 7.5" rear. Ford Expedition rear coils, Ram 350 shocks, JKS, IRO Long Arms, cool Badlands flag thingy.
1987 XJ - Gone but not forgotten
iluvtruenos is offline
post #11 of 21 Old 09-24-2009, 04:02 PM
iluvtruenos
Use the non-symmetrical 5 bladed fan. It moves more air than the 7 bladed unit.
post #12 of 21 Old 09-24-2009, 04:03 PM
trail-rated
No, I have had both, the 7-blade definitely moves more air.
post #13 of 21 Old 09-26-2009, 10:40 AM Thread Starter
tjf1980
Got a mopar 7 blade fan in yesterday. Still doesn't fit. I am starting to think that it has an aftermarket water pump or something with a shorter shaft because it still doesn't fit. It's closer and threads on but still doesn't clear the power steering pump pulley before it gets tight. I am heading to the jeep salvage yard to see what I can find today. Would be so much easier if it used an old style mount so I could use any fan and a spacer to get it away from the engine.
tjf1980 is offline
post #14 of 21 Old 09-26-2009, 11:23 AM
Redbob
Are you using a fan clutch or are you going direct-drive?
If it's direct, what you need is a fan spacer to locate the fan forward so the blades will clear things. All older cars and trucks with direct-drive fans used spacers of one length or another to clear things, while fan-clutch models basically had the spacer function built into the body of the clutch.
Fan spacers are pretty universal, though; they're often made of an aluminum extrusion and then are cut to length, so they can be found (just not everywhere) in virtually any length.
(in a former life, I was the guy who tested new fan packages for noise quality at a major auto company, and I did more fan changes than I care to think about...)
- R
Redbob is offline
post #15 of 21 Old 09-26-2009, 01:35 PM
owenswj
Post #6 states that he got a clutch from the Zone.
owenswj is offline
help! i need a mechanical fan blade for my 01 WJ with a 4.0 PJNovinskee27 ZJ Grand Cherokee Forum 7 01-25-2009 08:41 AM
ZJ Fan shroud/Fan Blade Miller97 ZJ Grand Cherokee Forum 1 12-08-2008 05:20 PM
What size Sazall Blade... PR1AWRet ZJ Grand Cherokee Forum 15 05-24-2007 06:27 AM
Fan blade safety recall??? ///BHRpowered ZJ Grand Cherokee Forum 13 10-01-2006 03:29 PM
Wiper blade mystery??? sdog30 ZJ Grand Cherokee Forum 10 01-10-2006 11:59 PM
