Max tire size on Bone Stock 03 WJ 4.0 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > ZJ Grand Cherokee Forum > Max tire size on Bone Stock 03 WJ 4.0
Offset Tie Rod Kit From RuffStuff!The Original 3/8" Ruffstuff Diff Cover!Introducing MONSTALINER™ UV Permanent DIY Roll On Bed Line
Unread 12-03-2009, 06:14 PM   #1
SteveA1992
2003 WJ
I was looking at tires online and was wondering what the largest tire size i could put on the stock 16 inch rims without any rubbing. Any help would be greatly appreciated! Thanks.
SteveA1992 is offline   Reply With Quote
Unread 12-03-2009, 06:36 PM   #2
4x4jeepcrew
biggest tire size on stock wj = 30"
4x4jeepcrew is offline   Reply With Quote
Unread 12-03-2009, 06:43 PM   #3
SteveA1992
2003 WJ
would that be somewhere near a 245/70r16
Unread 12-03-2009, 07:58 PM   #4
RoadWarriorWJ
I have 245/70/16 on mine with no rubbing. Came on the Jeep when I bought it. I also believe that is the size some of the jeeps came with.
RoadWarriorWJ is offline   Reply With Quote
Unread 12-03-2009, 08:12 PM   #5
lloyd877
I like the size 245/70 16 because it is bigger than stock (for a laredo) and it does not rub.
WJ 2001 4.0L http://www.jeepforum.com/forum/f197/lloyds-modest-wj-build-1099854/ (Sold) 5.9 ZJ AKA Race Jeep 30" BFGoodrich ATs (Sold)
lloyd877 is offline   Reply With Quote
Unread 12-03-2009, 08:29 PM   #6
GraKee99
Rapist Wit
245/75/16 will fit some minor rubbing on the front bumper cover. Some trimming can easily fix this.
Brian
WJ, WK, CJ5
[CENTER][URL="http://staythetrail.org/"][COLOR="Navy"]Stay the Trail[/COLOR][/URL][/CENTER]
[CENTER][COLOR="DarkGreen"]Colorado Jeep Club Member #188[/COLOR][/CENTER]
GraKee99 is offline   Reply With Quote
Unread 12-04-2009, 06:49 PM   #7
SteveA1992
2003 WJ
it says on the inner door panel that the tires are 225/75r16 came stock, did they change what size tires to put on from year to year?
Unread 12-05-2009, 12:19 PM   #8
JJAMISON_
I believe the 225 is stock but i have as others 245 on mine and it doesn't present any problems. The diff is only about .8" total. I have seen while searching on Google about some Jeeps Gran Cher's coming with 245's factory.
JJAMISON_ is offline   Reply With Quote
Unread 12-05-2009, 12:21 PM   #9
g-off70
245/70/16 was a factory option for the dubs
g-off70 is offline   Reply With Quote
Unread 12-06-2009, 07:53 AM   #10
JeepsOLot
Location: Stuart, 30 miles north of West Palm Beach, Florida
I think the WJ's that came stock with the 245/70R16's probably had the Up Country suspension. Am I right on this? If so, what would be the biggest tire I could shove under there with that suspension? Thanks
Jerry
1992 Jeep "CJ9" (YJ with '78 CJ front clip, '80 CJ Tailgate, Custom CJ Dash with '76 CJ Gauges) AX-15 from a '93 YJ, 2.5" Rancho SL, 5/8" MORE booms, 1" BL, and 33"x10.50" SS TSL's
JeepsOLot is offline   Reply With Quote
Unread 12-06-2009, 08:05 AM   #11
cmonson
My 2000 grand cherokee limited came stock from the factory with 245/70/16. I believe that all limited recieved this option. I do not have an upcounty suspension.
It was an option and there is lots of room. Could probably even go with a larger tire.
at the bottom of this sheet it will show all of the tire sizes from the factory
cmonson is offline   Reply With Quote
Unread 12-07-2009, 01:09 PM   #12
JJAMISON_
Steve the 245/70-16 is the largest w/o a lift.
[QUOTE=threeb]My wieners are hard and black now brb gotta eat.[/QUOTE]
Unread 12-07-2009, 02:27 PM   #13
ezflip
Theme Park Dinosaur Head
ezflip's Avatar
2002 Overland - 4.7 HO, "Select-Drive", 4" RC long arms, TAG front winch bumper, 32" BFG KM's, Kolak 3" exhaust, Flowmaster 50 series
Build Thread
KCCO
ezflip is offline   Reply With Quote
Unread 12-07-2009, 03:50 PM   #14
EisBlade
EisBlade's Avatar
Originally Posted by ezflip View Post
LOL. x2!
10char
JT
owner Harley-Davidson Touring Group (facebook)
LIFTs, TIREs, SPRINGs & GEARs:
WJ Spring Rate Chart
Tire Size vs Lift
Tire Size vs Gear Ratio
WJ Noob Lift Chart
Driveshaft Angles & Pics of Rear Diff Pumpkins:
Correct Pinion Angles
Correct Driveline Geometry 101
Differential Covers; What They Look Like
Death Wobble (DW):IRO DW Checklist'. .JK Forum DW Notes
WJ E-Brake Reset Procedure:PDF Instructions
WJ Headers:Doug Thorley Header pics for 4.0L 99-01 WJ's ($499)
If you seek cheap thrills then battle Racine below. Doubtful, but
let me know if you beat her.
Raunchy Racine
DISCLAIMER: Not responsible for men of weak character.
EisBlade is offline   Reply With Quote
Unread 12-07-2009, 06:03 PM   #15
JeepsOLot
NIIICE, never saw that one before,
Jerry
